设备反复退网并加网多次后,出现设备无法入网的现象
Other Parts Discussed in Thread: Z-STACK
使用Z-Stack Home 1.2.2a.44539协议栈时发现,当我的设备反复退网并加网多次后,出现设备无法入网的现象,在准备入网的时候,会收到协调器发送的Remove Device指令,导致设备无法加网,
我在协议栈里作了如下修改:
void ZDSecMgrUpdateDeviceInd( ZDO_UpdateDeviceInd_t* ind )
  ZDSecMgrDevice_t device;
  device.nwkAddr    = ind->devAddr;
  device.extAddr    = ind->devExtAddr;
  device.parentAddr = ind->srcAddr;
  device.devStatus  = DEV_SEC_INIT_STATUS;
  device.secure     = FALSE;
  // Trust Center should identify the type of JOIN/REJOIN and
  // Transport the NWK key accordingly, it will only be transported for:
  //              APSME_UD_STANDARD_UNSECURED_JOIN
  //   OR         APSME_UD_STANDARD_TRUST_CENTER_REJOIN
  if ( ind->status != APSME_UD_DEVICE_LEFT )
    if ( ind->status == APSME_UD_STANDARD_SECURED_REJOIN )
      device.devStatus &= ~DEV_SEC_INIT_STATUS;
      device.devStatus |=  DEV_SEC_AUTH_STATUS;
      device.secure = TRUE;
    ZDSecMgrDeviceJoin( &device );
  +else
   + // remove the TCLK NV entry for a device which has left the network
   + APSME_TCLinkKeyInit(TRUE);
