CC2530芯片,开始修改Z-Stack 3.0.2中的SampleSwitch和SampleLight例程,去掉UI和按键建网/入网,让协调器上电自己建立网络,终端上电自行入网。
1. 首先修改协调器,使用SampleLight例程提供的工程代码
1)去掉UI相关文件和代码行,编译无误;
2)在zcl_samplelight.c文件之zclSampleLight_Init()函数的最后添加协调器建网代码:
//GP_UPDATE #if (ZG_BUILD_RTR_TYPE) gp_RegisterCommissioningModeCB(gp_CommissioningMode); gp_RegisterGPChangeChannelReqCB(gp_ChangeChannelReq); #endif zdpExternalStateTaskID = zclSampleLight_TaskID; // Add on 5 Jan 2021 #if defined( ZDO_COORDINATOR ) bdb_StartCommissioning(BDB_COMMISSIONING_MODE_NWK_FORMATION); #else bdb_StartCommissioning(BDB_COMMISSIONING_MODE_NWK_STEERING); #endif // UI_Init(zclSampleLight_TaskID, SAMPLEAPP_LCD_AUTO_UPDATE_EVT, SAMPLEAPP_KEY_AUTO_REPEAT_EVT, &zclSampleLight_IdentifyTime, APP_TITLE, &zclSampleLight_UiUpdateLcd, zclSampleLight_UiStatesMain); // UI_UpdateLcd();
3) 在zcl_samplelight.c文件之zclSampleLight_ProcessCommissioningStatus()函数添加网络状态打印:
switch(bdbCommissioningModeMsg->bdbCommissioningMode)
case BDB_COMMISSIONING_FORMATION:
if(bdbCommissioningModeMsg->bdbCommissioningStatus == BDB_COMMISSIONING_SUCCESS)
//After formation, perform nwk steering again plus the remaining commissioning modes that has not been process yet
bdb_StartCommissioning(BDB_COMMISSIONING_MODE_NWK_STEERING | bdbCommissioningModeMsg->bdbRemainingCommissioningModes);
printf("nwk is ready\r\n");
else
//Want to try other channels?
//try with bdb_setChannelAttribute
printf("nwk failed\r\n");
break;
case BDB_COMMISSIONING_NWK_STEERING:
//YOUR JOB:
//We are on the nwk, what now?
else
//See the possible errors for nwk steering procedure
//No suitable networks found
break;
4) 上电测试,复位后查看串口打印,均打印nwk failed,偶尔打印nwk is ready。
2. 其次修改终端,使用SampleSwitch工程来修改。
1)去掉UI,编译无误;
2)在zclSampleSw_Init()函数的末尾添加如下代码:
3)在zclSampleSw_ProcessCommissioningStatus()函数中添加网络状态打印:
//YOUR JOB:
printf("We are on the nwk\r\n");
else
printf("No suitable networks found\r\n");
break;
4) 测试结果,在协调器偶尔出现nwk is ready后,给终端上电,但是发现还是打印No suitable networks found
