Hi 目前用CC2652P作为网关ZNP进行测试过程中发现,终端设备在入网一段时间后会偶尔出现被移除出网络现象(此时终端设备还在线),以下是linux_gateway与ZNP通信的log,请问一下是什么原因下会出现这种现象呢?
[16:33:44.847,834] [Z_STACK/LSTN] INFO : !Done
[UART] npi_parseframe: found frame, going to npi_procframe
[UART] npi_procframe, subsys: 0x45, Cmd ID: 0xC9, length: 13
[16:33:48.262,279] [NPISRVR/U_RX] PKT_HEX: [SOCZIGB>>NPISRVR ] [ASNC] 0D:45:C9:7E:84:10:12:AA:21:00:4B:12:00:00:00:00
[UART] npi_procframe signal areq callback thread (invoked by read loop)
[-->] 13 bytes, subSys 0x45, cmdId 0xC9, pData: 0x7E 0x84 0x10 0x12 0xAA 0x21 0x00 0x4B 0x12 0x00 0x00 0x00 0x00
Dispatch AREQ to all active connections: #5.
[16:33:48.264,132] [NPISRVR/ACBK] PKT_HEX: [ NPISRVR>>Z_STACK ] [bcst] 0D:45:C9:7E:84:10:12:AA:21:00:4B:12:00:00:00:00
[16:33:48.265,013] [Z_STACK/READ] INFO : Received 13 bytes, subSys 0x45, cmdId 0xC9
[16:33:48.265,509] [Z_STACK/READ] INFO : RPC_CMD_AREQ cmdId: 0xC9
[16:33:48.265,966] [Z_STACK/READ] INFO : [DBG] Allocated @ 0x77D999F0 (received 121 messages)...
...sent 16 bytes to Client #5
[16:33:48.266,417] [Z_STACK/READ] INFO : Filling new message (@ 0x77D999F0)...
[16:33:48.268,961] [Z_STACK/HNDL] INFO : [MUTEX] Mutex for AREQ unlocked
[16:33:48.269,475] [Z_STACK/HNDL] INFO : [DBG] Processing @ 0x77D999F0
[16:33:48.270,079] [Z_STACK/HNDL] INFO : [MUTEX] AREQ Calling asynchMsgCback (Handle)...
[16:33:48.270,527] [Z_STACK/HNDL] INFO : [DBG] asyncCB: subSys:0x00000005, cmdId:0x000000C9, len:0x0000000D, pData:0x77D999F8
[16:33:48.272,467] [Z_STACK/HNDL] INFO : zstackpb Rcvd ZDO Leave Ind
[16:33:48.274,368] [Z_STACK/HNDL] PKT_HEX: [ Z_STACK>>NWK_MGR ] [ucst] 16:00:51:86:08:86:01:10:FE:88:02:19:10:12:AA:21:00:4B:12:00:20:00:28:00:30:00
[16:33:48.276,314] [Z_STACK/HNDL] PKTTYPE: [ Z_STACK>>NWK_MGR ] zdoLeaveInd
[16:33:48.299,657] [Z_STACK/HNDL] PKTBODY: cmdID = <NOT_FOUND>
[16:33:48.301,512] [Z_STACK/HNDL] PKTBODY: srcAddr = 0x0000847E (33918)
[16:33:48.307,308] [Z_STACK/HNDL] PKTBODY: extendedAddr = 00:12:4B:00:21:AA:12:10
[16:33:48.311,912] [Z_STACK/HNDL] PKTBODY: request = 0x00000000 (0)
[16:33:48.313,643] [Z_STACK/HNDL] PKTBODY: removeChildren = 0
[16:33:48.315,508] [Z_STACK/HNDL] PKTBODY: rejoin = 0
[16:33:48.324,215] [NWK_MGR/READ] INFO : Received 22 bytes, subSys 0x51, cmdId 0x86
[16:33:48.324,734] [NWK_MGR/READ] INFO : RPC_CMD_AREQ cmdId: 0x86
[16:33:48.325,172] [NWK_MGR/READ] INFO : [DBG] Allocated @ 0x77DECEA0 (received 5 messages)...
[16:33:48.325,620] [NWK_MGR/READ] INFO : Filling new message (@ 0x77DECEA0)...
[16:33:48.326,116] [NWK_MGR/HNDL] INFO : [MUTEX] Mutex for AREQ unlocked
[16:33:48.326,563] [NWK_MGR/HNDL] INFO : [DBG] Processing @ 0x77DECEA0
[16:33:48.327,180] [NWK_MGR/HNDL] INFO : [MUTEX] AREQ Calling asynchMsgCback (Handle)...
[16:33:48.327,633] [NWK_MGR/HNDL] INFO : [DBG] asyncCB: subSys:0x00000011, cmdId:0x00000086, len:0x00000016, pData:0x77DECEA8
[16:33:48.328,117] [NWK_MGR/HNDL] MISC1 : Received ZDO Leave Indication: NwkAddr: 847E
[16:33:48.328,562] [NWK_MGR/HNDL] INFO :
- Halting State Machine IeeeAddr: 00124B0021AA1210
[16:33:48.329,012] [NWK_MGR/HNDL] INFO : zNwkSrv_AD_FreeStateMachine: Entered pState=0x77dd7330
[16:33:48.329,454] [NWK_MGR/HNDL] INFO : zNwkSrv_AD_FreeStateMachine: State machine freed
[16:33:48.329,893] [NWK_MGR/HNDL] INFO : nwkMgrDb_FreeDeviceInfo: Entered pDeviceInfo=0x77decf00
[16:33:48.330,332] [NWK_MGR/HNDL] INFO : nwkMgrDb_FreeDeviceInfoSubstructures: Entered pDeviceInfo=0x77decf00
[16:33:48.335,143] [Z_STACK/HNDL] INFO : ...sent 26 bytes to Client
[16:33:48.342,503] [Z_STACK/HNDL] INFO : [MUTEX] AREQ (Handle) (message @ 0x77D999F0)...
[16:33:48.347,841] [Z_STACK/HNDL] INFO : [DBG] Clearing @ 0x77D999F0 (processed 121 messages)...
[16:33:48.349,545] [NWK_MGR/HNDL] INFO : nwkMgrDb_FreeDeviceInfoSubstructures: Exit
[16:33:48.359,051] [NWK_MGR/HNDL] INFO : zNwkSrv_AD_FreeStateMachine: Exit
[16:33:48.351,525] [Z_STACK/HNDL] INFO : [MUTEX] Wait for AREQ semaphore
[16:33:48.360,420] [NWK_MGR/HNDL] MISC1 : NwkMgr sendNwkZigbeeDeviceInd:
[16:33:48.371,412] [NWK_MGR/HNDL] PKT_HEX: [ NWK_MGR>>>>>>>>>>>GW-APP] [bcst] 36:00:52:15:08:15:12:32:08:FE:88:02:11:10:12:AA:21:00:4B:12:00:19:9D:B0:5B:21:00:4B:12:00:20:00:2A:16:08:08:10:84:02:18:0B:20:00:28:03:28:00:30:03:30:05:30:04:30:81:02:30:02
[16:33:48.382,427] [NWK_MGR/HNDL] PKTTYPE: [ NWK_MGR>>>>>>>>>>>GW-APP] NwkZigbeeDeviceInd
[16:33:48.384,167] [NWK_MGR/HNDL] PKTBODY: cmdId = NWK_ZIGBEE_DEVICE_IND
[16:33:48.390,979] [NWK_MGR/HNDL] PKTBODY: deviceInfo :
[16:33:48.400,541] [NWK_MGR/HNDL] PKTBODY: networkAddress = 0x0000847E (33918)
[16:33:48.405,159] [NWK_MGR/HNDL] PKTBODY: ieeeAddress = 00:12:4B:00:21:AA:12:10
[16:33:48.414,996] [NWK_MGR/HNDL] PKTBODY: parentIeeeAddress = 00:12:4B:00:21:5B:B0:9D
[16:33:48.417,058] [NWK_MGR/HNDL] PKTBODY: manufacturerId = 0x00000000 (0)
[16:33:48.420,975] [NWK_MGR/HNDL] PKTBODY: simpleDescList :
[16:33:48.425,893] [NWK_MGR/HNDL] PKTBODY: [000] :
[16:33:48.429,781] [NWK_MGR/HNDL] PKTBODY: endpointId = 0x00000008 (8)
[16:33:48.436,734] [NWK_MGR/HNDL] PKTBODY: profileId = 0x00000104 (260)
[16:33:48.440,409] [NWK_MGR/HNDL] PKTBODY: deviceId = 0x0000000B (11)
[16:33:48.444,819] [NWK_MGR/HNDL] PKTBODY: deviceVer = 0x00000000 (0)
[16:33:48.449,104] [NWK_MGR/HNDL] PKTBODY: inputClusters :
[16:33:48.454,826] [NWK_MGR/HNDL] PKTBODY: [000] = 0x00000003 (3)
[16:33:48.463,694] [NWK_MGR/HNDL] PKTBODY: [001] = 0x00000000 (0)
[16:33:48.464,583] [NWK_MGR/HNDL] PKTBODY: outputClusters :
[16:33:48.470,962] [NWK_MGR/HNDL] PKTBODY: [000] = 0x00000003 (3)
[16:33:48.485,327] [NWK_MGR/HNDL] PKTBODY: [001] = 0x00000005 (5)
[16:33:48.487,147] [NWK_MGR/HNDL] PKTBODY: [002] = 0x00000004 (4)
[16:33:48.488,778] [NWK_MGR/HNDL] PKTBODY: [003] = 0x00000101 (257)
[16:33:48.495,011] [NWK_MGR/HNDL] PKTBODY: deviceStatus = DEVICE_REMOVED
[16:33:48.513,374] [NWK_MGR/HNDL] PKT_HEX: [ NWK_MGR>>OTASRVR ] [bcst] 36:00:52:15:08:15:12:32:08:FE:88:02:11:10:12:AA:21:00:4B:12:00:19:9D:B0:5B:21:00:4B:12:00:20:00:2A:16:08:08:10:84:02:18:0B:20:00:28:03:28:00:30:03:30:05:30:04:30:81:02:30:02
[16:33:48.522,380] [NWK_MGR/HNDL] PKTTYPE: [ NWK_MGR>>OTASRVR ] NwkZigbeeDeviceInd
[16:33:48.535,116] [NWK_MGR/HNDL] PKTBODY: cmdId = NWK_ZIGBEE_DEVICE_IND
[16:33:48.546,723] [NWK_MGR/HNDL] PKTBODY: deviceInfo :
[16:33:48.549,511] [NWK_MGR/HNDL] PKTBODY: networkAddress = 0x0000847E (33918)
[16:33:48.553,805] [NWK_MGR/HNDL] PKTBODY: ieeeAddress = 00:12:4B:00:21:AA:12:10
[16:33:48.556,981] [NWK_MGR/HNDL] PKTBODY: parentIeeeAddress = 00:12:4B:00:21:5B:B0:9D
[16:33:48.561,234] [NWK_MGR/HNDL] PKTBODY: manufacturerId = 0x00000000 (0)
[16:33:48.565,835] [NWK_MGR/HNDL] PKTBODY: simpleDescList :
[16:33:48.570,478] [NWK_MGR/HNDL] PKTBODY: [000] :
[16:33:48.574,177] [NWK_MGR/HNDL] PKTBODY: endpointId = 0x00000008 (8)
[16:33:48.578,311] [NWK_MGR/HNDL] PKTBODY: profileId = 0x00000104 (260)
[16:33:48.582,166] [NWK_MGR/HNDL] PKTBODY: deviceId = 0x0000000B (11)
[16:33:48.585,425] [NWK_MGR/HNDL] PKTBODY: deviceVer = 0x00000000 (0)
[16:33:48.588,571] [NWK_MGR/HNDL] PKTBODY: inputClusters :
[16:33:48.591,864] [NWK_MGR/HNDL] PKTBODY: [000] = 0x00000003 (3)
[16:33:48.594,904] [NWK_MGR/HNDL] PKTBODY: [001] = 0x00000000 (0)
[16:33:48.598,121] [NWK_MGR/HNDL] PKTBODY: outputClusters :
[16:33:48.601,106] [NWK_MGR/HNDL] PKTBODY: [000] = 0x00000003 (3)
[16:33:48.604,340] [NWK_MGR/HNDL] PKTBODY: [001] = 0x00000005 (5)
[16:33:48.611,956] [NWK_MGR/HNDL] PKTBODY: [002] = 0x00000004 (4)
[16:33:48.615,220] [NWK_MGR/HNDL] PKTBODY: [003] = 0x00000101 (257)
[16:33:48.618,320] [NWK_MGR/HNDL] PKTBODY: deviceStatus = DEVICE_REMOVED
[16:33:48.621,858] [OTASRVR/READ] INFO : Received 54 bytes, subSys 0x52, cmdId 0x15
[16:33:48.622,386] [OTASRVR/READ] INFO : RPC_CMD_AREQ cmdId: 0x15
[16:33:48.623,171] [OTASRVR/READ] INFO : [DBG] Allocated @ 0x77D6BC00 (received 2 messages)...
[16:33:48.625,162] [OTASRVR/READ] INFO : Filling new message (@ 0x77D6BC00)...
[16:33:48.627,280] [OTASRVR/HNDL] INFO : [MUTEX] Mutex for AREQ unlocked
[16:33:48.627,782] [OTASRVR/HNDL] INFO : [DBG] Processing @ 0x77D6BC00
[16:33:48.628,227] [OTASRVR/HNDL] INFO : [MUTEX] AREQ Calling asynchMsgCback (Handle)...
[16:33:48.628,666] [OTASRVR/HNDL] INFO : [DBG] asyncCB: subSys:0x00000012, cmdId:0x00000015, len:0x00000036, pData:0x77D6BC08
[16:33:48.629,120] [OTASRVR/HNDL] INFO : [MUTEX] AREQ (Handle) (message @ 0x77D6BC00)...
[16:33:48.629,564] [OTASRVR/HNDL] INFO : [DBG] Clearing @ 0x77D6BC00 (processed 2 messages)...
[16:33:48.630,024] [OTASRVR/HNDL] INFO : [MUTEX] Wait for AREQ semaphore
[16:33:48.637,470] [NWK_MGR/HNDL] PKT_HEX: [ NWK_MGR>>GATEWAY ] [bcst] 36:00:52:15:08:15:12:32:08:FE:88:02:11:10:12:AA:21:00:4B:12:00:19:9D:B0:5B:21:00:4B:12:00:20:00:2A:16:08:08:10:84:02:18:0B:20:00:28:03:28:00:30:03:30:05:30:04:30:81:02:30:02
[16:33:48.666,459] [NWK_MGR/HNDL] PKTTYPE: [ NWK_MGR>>GATEWAY ] NwkZigbeeDeviceInd
[16:33:48.670,536] [NWK_MGR/HNDL] PKTBODY: cmdId = NWK_ZIGBEE_DEVICE_IND
[16:33:48.673,634] [NWK_MGR/HNDL] PKTBODY: deviceInfo :
[16:33:48.677,100] [NWK_MGR/HNDL] PKTBODY: networkAddress = 0x0000847E (33918)
[16:33:48.680,404] [NWK_MGR/HNDL] PKTBODY: ieeeAddress = 00:12:4B:00:21:AA:12:10
[16:33:48.684,309] [NWK_MGR/HNDL] PKTBODY: parentIeeeAddress = 00:12:4B:00:21:5B:B0:9D
[16:33:48.687,809] [NWK_MGR/HNDL] PKTBODY: manufacturerId = 0x00000000 (0)
[16:33:48.692,549] [NWK_MGR/HNDL] PKTBODY: simpleDescList :
[16:33:48.695,817] [NWK_MGR/HNDL] PKTBODY: [000] :
[16:33:48.699,544] [NWK_MGR/HNDL] PKTBODY: endpointId = 0x00000008 (8)
[16:33:48.703,026] [NWK_MGR/HNDL] PKTBODY: profileId = 0x00000104 (260)
[16:33:48.706,254] [NWK_MGR/HNDL] PKTBODY: deviceId = 0x0000000B (11)
[16:33:48.709,823] [NWK_MGR/HNDL] PKTBODY: deviceVer = 0x00000000 (0)
[16:33:48.713,189] [NWK_MGR/HNDL] PKTBODY: inputClusters :
[16:33:48.716,680] [NWK_MGR/HNDL] PKTBODY: [000] = 0x00000003 (3)
[16:33:48.719,721] [NWK_MGR/HNDL] PKTBODY: [001] = 0x00000000 (0)
[16:33:48.723,269] [NWK_MGR/HNDL] PKTBODY: outputClusters :
[16:33:48.726,824] [NWK_MGR/HNDL] PKTBODY: [000] = 0x00000003 (3)
[16:33:48.729,965] [NWK_MGR/HNDL] PKTBODY: [001] = 0x00000005 (5)
[16:33:48.733,068] [NWK_MGR/HNDL] PKTBODY: [002] = 0x00000004 (4)
[16:33:48.736,448] [NWK_MGR/HNDL] PKTBODY: [003] = 0x00000101 (257)
[16:33:48.739,783] [NWK_MGR/HNDL] PKTBODY: deviceStatus = DEVICE_REMOVED
[16:33:48.743,582] [GATEWAY/READ] INFO : Received 54 bytes, subSys 0x52, cmdId 0x15
[16:33:48.744,116] [GATEWAY/READ] INFO : RPC_CMD_AREQ cmdId: 0x15
[16:33:48.744,554] [GATEWAY/READ] INFO : [DBG] Allocated @ 0x77EA0B30 (received 2 messages)...
[16:33:48.744,998] [GATEWAY/READ] INFO : Filling new message (@ 0x77EA0B30)...
[16:33:48.745,493] [GATEWAY/HNDL] INFO : [MUTEX] Mutex for AREQ unlocked
[16:33:48.745,936] [GATEWAY/HNDL] INFO : [DBG] Processing @ 0x77EA0B30
[16:33:48.746,375] [GATEWAY/HNDL] INFO : [MUTEX] AREQ Calling asynchMsgCback (Handle)...
[16:33:48.747,134] [GATEWAY/HNDL] INFO : [DBG] asyncCB: subSys:0x00000012, cmdId:0x00000015, len:0x00000036, pData:0x77EA0B38
[16:33:48.748,402] [GATEWAY/HNDL] INFO : [MUTEX] AREQ (Handle) (message @ 0x77EA0B30)...
[16:33:48.749,864] [GATEWAY/HNDL] INFO : [DBG] Clearing @ 0x77EA0B30 (processed 2 messages)...
[16:33:48.751,745] [GATEWAY/HNDL] INFO : [MUTEX] Wait for AREQ semaphore
[16:33:48.753,502] [NWK_MGR/HNDL] CUSTOM : GUN freePbDeviceInfoList entered with pDeviceInfo = 0x77dd7540
[16:33:48.757,351] [NWK_MGR/HNDL] DEBUG : Freeing inputclusters 0x77dd75c0
[16:33:48.846,688] [NWK_MGR/HNDL] MISC1 : NwkAddr: 847E removed from device list
[16:33:48.850,473] [NWK_MGR/HNDL] INFO : nwkMgrDb_FreeDeviceInfo: Entered pDeviceInfo=0x77deced0
[16:33:48.854,929] [NWK_MGR/HNDL] INFO : nwkMgrDb_FreeDeviceInfoSubstructures: Entered pDeviceInfo=0x77deced0
[16:33:48.859,011] [NWK_MGR/HNDL] INFO : nwkMgrDb_FreeDeviceInfoSubstructures: Exit
[16:33:48.864,013] [NWK_MGR/HNDL] INFO : [MUTEX] AREQ (Handle) (message @ 0x77DECEA0)...
[16:33:48.869,810] [NWK_MGR/HNDL] INFO : [DBG] Clearing @ 0x77DECEA0 (processed 5 messages)...
[16:33:48.873,812] [NWK_MGR/HNDL] INFO : [MUTEX] Wait for AREQ semaphore
[16:33:49.993,566] [NWK_MGR/LSTN] INFO : Receive message...
[16:33:49.994,229] [NWK_MGR/LSTN] PKT_HEX: [ NWK_MGR<<<<<<<<<<<GW-APP] [read] 02:00:12:21:08:21
[16:33:49.995,634] [NWK_MGR/LSTN] PKTTYPE: [ NWK_MGR<<<<<<<<<<<GW-APP] NwkGetGwEndpointInfoReq
[16:33:49.997,571] [NWK_MGR/LSTN] PKTBODY: cmdId = NWK_GET_GW_ENDPOINT_INFO_REQ
[16:33:49.999,311] [NWK_MGR/LSTN] MISC1 : NWK_GET_GW_ENDPOINT_INFO_REQ:
[16:33:50.011,963] [NWK_MGR/LSTN] PKT_HEX: [ NWK_MGR>>>>>>>>>>>GW-APP] [ucst] 44:00:72:22:08:22:12:40:08:00:11:9D:B0:5B:21:00:4B:12:00:20:07:2A:20:08:04:10:84:02:18:07:20:00:28:00:28:03:28:81:0A:30:06:30:04:30:05:30:80:0A:30:09:30:81:02:30:20:2A:0D:08:F2:01:10:E0:C3:02:18:61:20:00:30:21:30:01
[16:33:50.019,352] [NWK_MGR/LSTN] PKTTYPE: [ NWK_MGR>>>>>>>>>>>GW-APP] NwkGetGwEndpointInfoCnf
[16:33:50.022,847] [NWK_MGR/LSTN] PKTBODY: cmdId = NWK_GET_GW_ENDPOINT_INFO_CNF
[16:33:50.025,988] [NWK_MGR/LSTN] PKTBODY: deviceInfoList :
[16:33:50.028,926] [NWK_MGR/LSTN] PKTBODY: networkAddress = 0x00000000 (0)
[16:33:50.032,400] [NWK_MGR/LSTN] PKTBODY: ieeeAddress = 00:12:4B:00:21:5B:B0:9D
[16:33:50.035,441] [NWK_MGR/LSTN] PKTBODY: manufacturerId = 0x00000007 (7)
[16:33:50.038,650] [NWK_MGR/LSTN] PKTBODY: simpleDescList :
[16:33:50.041,896] [NWK_MGR/LSTN] PKTBODY: [000] :
[16:33:50.044,997] [NWK_MGR/LSTN] PKTBODY: endpointId = 0x00000004 (4)
[16:33:50.048,081] [NWK_MGR/LSTN] PKTBODY: profileId = 0x00000104 (260)
[16:33:50.051,269] [NWK_MGR/LSTN] PKTBODY: deviceId = 0x00000007 (7)
[16:33:50.054,261] [NWK_MGR/LSTN] PKTBODY: deviceVer = 0x00000000 (0)
[16:33:50.057,640] [NWK_MGR/LSTN] PKTBODY: inputClusters :
[16:33:50.060,780] [NWK_MGR/LSTN] PKTBODY: [000] = 0x00000000 (0)
[16:33:50.064,108] [NWK_MGR/LSTN] PKTBODY: [001] = 0x00000003 (3)
[16:33:50.067,155] [NWK_MGR/LSTN] PKTBODY: [002] = 0x00000501 (1281)
[16:33:50.070,310] [NWK_MGR/LSTN] PKTBODY: outputClusters :
[16:33:50.073,470] [NWK_MGR/LSTN] PKTBODY: [000] = 0x00000006 (6)
[16:33:50.076,672] [NWK_MGR/LSTN] PKTBODY: [001] = 0x00000004 (4)
[16:33:50.080,090] [NWK_MGR/LSTN] PKTBODY: [002] = 0x00000005 (5)
[16:33:50.083,185] [NWK_MGR/LSTN] PKTBODY: [003] = 0x00000500 (1280)
[16:33:50.086,144] [NWK_MGR/LSTN] PKTBODY: [004] = 0x00000009 (9)
[16:33:50.089,331] [NWK_MGR/LSTN] PKTBODY: [005] = 0x00000101 (257)
[16:33:50.092,522] [NWK_MGR/LSTN] PKTBODY: [006] = 0x00000020 (32)
[16:33:50.095,683] [NWK_MGR/LSTN] PKTBODY: [001] :
[16:33:50.099,079] [NWK_MGR/LSTN] PKTBODY: endpointId = 0x000000F2 (242)
[16:33:50.102,209] [NWK_MGR/LSTN] PKTBODY: profileId = 0x0000A1E0 (41440)
[16:33:50.105,669] [NWK_MGR/LSTN] PKTBODY: deviceId = 0x00000061 (97)
[16:33:50.109,144] [NWK_MGR/LSTN] PKTBODY: deviceVer = 0x00000000 (0)
[16:33:50.113,878] [NWK_MGR/LSTN] PKTBODY: outputClusters :
[16:33:50.117,501] [NWK_MGR/LSTN] PKTBODY: [000] = 0x00000021 (33)
[16:33:50.120,800] [NWK_MGR/LSTN] PKTBODY: deviceStatus = DEVICE_ON_LINE
[16:33:50.128,666] [NWK_MGR/LSTN] INFO : ...sent 72 bytes to Client
[16:33:50.132,496] [NWK_MGR/LSTN] INFO : !Done
