Other Parts Discussed in Thread: Z-STACK
这里面就是宏定义,没有编译的问题。。就和你把宏定义写在软件的option里面是一样的~
但是这些宏定义在软件调用是在哪里....在程序中烧写后,我们该怎么去修改这个文件里面的值呢....
- Z-Stack projects specify compile options in two ways: (1) "-D" statements
in f8wConfig.cfg and other *.cfg files, (2) entries in the IDE Compiler
Preprocessor Defined Symbols. When using the EW8051 or EW430 compilers,
settings made in the IDE will override settings in the *.cfg files. When
using the EWARM compiler, settings in the *.cfg files will override any
made in the IDE.
