ZHA设备如何恢复到Factory New状态呢?
请教下各位:
ZHA设备怎么恢复到Factory New状态呢?怎么才能删除NV中所有的网络参数信息呢?
  • uint8 ZDOInitDevice( uint16 startDelay )
    uint8 networkStateNV = ZDO_INITDEV_NEW_NETWORK_STATE;
    uint16 extendedDelay = 0;
    if ( devState == DEV_HOLD )
    // Initialize the RAM items table, in case an NV item has been updated.
    zgInitItems( FALSE );
    ZDConfig_InitDescriptors();
    //devtag.071807.todo - fix this temporary solution
    _NIB.CapabilityFlags = ZDO_Config_Node_Descriptor.CapabilityFlags;
    #if defined ( NV_RESTORE )
    // Hold down the SW_BYPASS_NV key (defined in OnBoard.h)
    // while booting to skip past NV Restore.
    if ( zdappHoldKeys == SW_BYPASS_NV )  上电的时候如果某个按键处于按下并且Hold状态的话,会把NV数据全部擦除,重新启动。
    zdappHoldKeys = 0; // Only once
    else
    // Determine if NV should be restored
    networkStateNV = ZDApp_ReadNetworkRestoreState();
    if ( networkStateNV == ZDO_INITDEV_RESTORED_NETWORK_STATE )
    networkStateNV = ZDApp_RestoreNetworkState();
    else
    // Wipe out the network state in NV
    NLME_InitNV();
    NLME_SetDefaultNV();
    // clear NWK key values
    ZDSecMgrClearNVKeyValues();
    #endif
