Other Parts Discussed in Thread: Z-STACK, CC2530
假设我一个网络里有多个路由器和多个终端,其中有个路由器A和两个终端B,C。我是否可以指定B,C只能通过路由器A入网,而不能通过其他路由器或协调器入网,即使A掉线路,B,C也不能通过其他路由器和协调器入网,请问这样是否可以实现,如果可以实现,我应该从哪方面入手考虑这个问题?
TI有篇文档提到了这个:
In some applications, a more controlled topology may be required. The NLME direct join request in the Z-Stack can be utilized to accomplish this. This design
note describes a particular scenario in which this function might be used. The scenario is to let an end device (RFD) join the network normally, and then provide a means for it to join a specific router (FFD).
地址:http://www.ti.com/lit/an/swru124a/swru124a.pdf
