CC2652R7: 刷写simplink 26x2 znp sdk 失败
Part Number: CC2652R7
在官网下载了simplelink sdk 后,通过CCS导入znp-lp-2652r7-tirtos7-ticlangsdk,通过SYSCFG重新配置了gpio引脚后,使用XDS100V3刷写在自己的板子上(非launchpad),打印了两条异常
Cortex_M4_0: Device revision '0x4' unknown for selected target, Assuming latest known revision: Rev . 1.1.
Cortex_M4_0: Loader: one or more section of your program falls into a memory region that is not writable. these region will not actually be written to the target. check your linker configuration and/or memory map.
如何解决这个异常?是否导致了刷新失败?因为我无法驱动点亮LED灯。
