Other Parts Discussed in Thread: Z-STACK
After I long press the button for 5 seconds, the device will send a device leave request to the coordinator and start to connect to the network again. Now after long press for 5 seconds, the code does run to the place where the device wants to send the leave request code, but the device does not send a leave request and cannot reconnect to the network in the same coordinator, it just returns to the original network of the same coordinator. What should I do in this case
我长按按钮5秒后设备会发送给协调器一个设备离网请求,并重新开始入网,现在长按5秒后代码确实跑到了设备要发送leave请求代码哪里,但是设备没有发送leave请求,也无法在同一个协调器里重新入网,只是回到了相同协调器原来的网络里,请问遇到这种情况怎么办
