怎么我的协议栈找不到zb_ReadConfiguration,带zb_开头的都找不到。急!!!
  • 您可以使用IAR的搜索功能
    Edit-->Find and Replace--->Find in files
    * @fn zb_ReadConfiguration
    * @brief The zb_ReadConfiguration function is used to get a
    * Configuration Protperty from Nonvolatile memory.
    * @param configId - The identifier for the configuration property
    * len - The size of the pValue buffer in bytes
    * pValue - A buffer to hold the configuration property
    * @return none
    extern uint8 zb_ReadConfiguration( uint8 configId, uint8 len, void *pValue );
    该函数在sapi.h
