Other Parts Discussed in Thread: Z-STACK
/mnt/nfs/Z-Stack_Linux_Gateway-1.0.1/z-stack_linux_gateway_arm_binaries/servers # ./zigbeeHAgw bbb
running zigbeegw.scr on an ARM
resetting beaglebone black
../tools/bbb_usbreset.bin: line 1: syntax error: unexpected word (expecting ")")
sleeping 6 seconds after reset... ../tools/gw_soc_fw_version_query.bin: line 1: syntax error: unexpected word (expecting ")")
done
stty: /dev/ttyACM0: Inappropriate ioctl for device
Starting the ZigBee gateway subsystem
./NPI_lnx_arm_server: line 1: syntax error: unexpected word (expecting ")")
NPI started (pid 564) at Fri Aug 28 09:04:59 UTC 2015
./ZLSZNP_arm: line 1: syntax error: unexpected word (expecting ")")
ZLSZNP started (pid 571) at Fri Aug 28 09:05:03 UTC 2015
./NWKMGR_SRVR_arm: line 1: syntax error: unexpected word (expecting ")")
NETWORK MANAGER started (pid 578) at Fri Aug 28 09:05:04 UTC 2015
./GATEWAY_SRVR_arm: line 1: syntax error: unexpected word (expecting ")")
GATEWAY SERVER started (pid 585) at Fri Aug 28 09:05:06 UTC 2015
./OTA_SRVR_arm: line 1: syntax error: unexpected word (expecting ")")
OTA SERVER started (pid 592) at Fri Aug 28 09:05:08 UTC 2015
starting tracker with our pid ./zigbeeHAgw and pid list 564 571 585 592
./zigbeeHAgw: line 1036: ./track_servers: not found
NETWORK MANAGER exited with code 2 at Fri Aug 28 09:05:08 UTC 2015
sh: can't kill pid 603: No such process
killall: GATEWAY_SRVR_arm: no process killed
killall: OTA_SRVR_arm: no process killed
killall: ZLSZNP_arm: no process killed
killall: NPI_lnx_arm_server: no process killed
done
NPI started (pid 676) at Fri Aug 28 09:05:27 UTC 2015
ZLSZNP started (pid 683) at Fri Aug 28 09:05:31 UTC 2015
NETWORK MANAGER started (pid 690) at Fri Aug 28 09:05:33 UTC 2015
GATEWAY SERVER started (pid 697) at Fri Aug 28 09:05:35 UTC 2015
OTA SERVER started (pid 704) at Fri Aug 28 09:05:37 UTC 2015
starting tracker with our pid ./zigbeeHAgw and pid list 676 683 697 704
./zigbeeHAgw: line 1149: ./track_servers: not found
