Other Parts Discussed in Thread: TIMAC, CC2630, CC2650, SYSBIOS
1.现在TImac不支持cc2630吗? 为什么我在配置里面的device里面找不到cc2630的选项?
2.在选择core为core-M3之后,编译 出现以下错误:(协议栈安装在默认位置)
Changed settings forces a full rebuild...
Building configuration: msa_cc2650 - CC2650-PG2-RFD
Updating build tree...
1 file(s) deleted.
Performing Pre-Build Action
Error while running "c:\ti\xdctools_3_30_06_67_core/xs" --xdcpath="C:\ti\tirtos_simplelink_2_11_01_09\packages;C:\ti\
tirtos_simplelink_2_11_01_09\products\bios_6_41_02_41\packages;C:\ti\tirtos_simplelink_2_11_01_09\products\
cc26xxware_2_20_06_14829\inc;C:\ti\tirtos_simplelink_2_11_01_09\products\cc26xxware_2_20_06_14829\driverlib;C:\ti\
tirtos_simplelink_2_11_01_09\products\cc26xxware_2_20_06_14829" iar.tools.configuro -c "E:\Program Files (x86)\IAR
Systems\Embedded Workbench 7.0\arm" --cc "E:\Program Files (x86)\IAR Systems\Embedded Workbench 7.0\arm\
bin\iccarm.exe" --device "Default" --compileOptions "-D ewarm -D USE_ICALL -D xUSE_FPGA -D
HEAPMGR_SIZE=2048 -D FEATURE_MAC_SECURITY -D FEATURE_GREEN_POWER -D
FEATURE_ENHANCED_BEACON -D FEATURE_BEACON_MODE -D xFEATURE_EXTENDED_CHAN29 -D
ICALL_HOOK_ABORT_FUNC=halAssertHandler -D xdc_runtime_Log_DISABLE_ALL -D
xdc_runtime_Assert_DISABLE_ALL -D MODULE_CC26XX_7X7 -D xNV_RESTORE --diag_suppress Pa050 -o \"C:\ti\
simplelink\timac_1_05_02_43299\Projects\mac\Sample\cc26xx_RTOS\IAR Projects\Application\CC2650\
CC2650-PG2-RFD\Obj\\\" --debug --endian=little --cpu=Cortex-M3 -f \"C:\ti\simplelink\timac_1_05_02_43299\Projects\
mac\Sample\cc26xx_RTOS\IAR Projects\Application\CC2650/configPkg/compiler.opt.defs\" -e --fpu=None
--dlib_config \"E:\Program Files (x86)\IAR Systems\Embedded Workbench 7.0\arm\INC\c\DLib_Config_Normal.h\" -I \
"C:\ti\simplelink\timac_1_05_02_43299\Projects\mac\Sample\cc26xx_RTOS\IAR Projects\Application\CC2650\\\" -I \
CC2650/../Source\\\" -I \"C:\ti\simplelink\timac_1_05_02_43299\Projects\mac\Sample\cc26xx_RTOS\IAR Projects\
Application\CC2650/../../../../../Stack/cc26xx_RTOS/include\\\" -I \"C:\ti\simplelink\timac_1_05_02_43299\Projects\mac\
Sample\cc26xx_RTOS\IAR Projects\Application\CC2650/../../../../../Stack/cc26xx_RTOS/include/CC2650\\\" -I \"C:\ti\
CC2650/../../../../../../../Components/applib/heap\\\" -I \"C:\ti\simplelink\timac_1_05_02_43299\Projects\mac\Sample\
cc26xx_RTOS\IAR Projects\Application\CC2650/../../../../../../../Components/hal/include\\\" -I \"C:\ti\simplelink\
CC2650/../../../../../../../Components/hal/target/_common/cc26xx\\\" -I \"C:\ti\simplelink\timac_1_05_02_43299\Projects\
mac\Sample\cc26xx_RTOS\IAR Projects\Application\CC2650/../../../../../../../Components/hal/target/CC2650/rom\\\" -I \
CC2650/../../../../../../../Components/hal/target/CC2650TIRTOS\\\" -I \"C:\ti\simplelink\timac_1_05_02_43299\Projects\
mac\Sample\cc26xx_RTOS\IAR Projects\Application\CC2650/../../../../../../../Components/osal/include\\\" -I \"C:\ti\
cc26xx_RTOS\IAR Projects\Application\CC2650/../../../../../../../Components/services/sdata\\\" -I \"C:\ti\simplelink\
CC2650/../../../../../../../Components/services/saddr\\\" -I \"C:\ti\simplelink\timac_1_05_02_43299\Projects\mac\Sample\
cc26xx_RTOS\IAR Projects\Application\CC2650/../../../../../../../Components/icall/include\\\" -I \"C:\ti\simplelink\
CC2650/../../../../../../../Components/mac/include\\\" -I \"C:\ti\simplelink\timac_1_05_02_43299\Projects\mac\Sample\
cc26xx_RTOS\IAR Projects\Application\CC2650/../../../../../../../Components/mac/include/cc26xx\\\" -I \"C:\ti\simplelink\
CC2650/../../../../../../../Components/services/nv\\\" -I \"C:\ti\simplelink\timac_1_05_02_43299\Projects\mac\Sample\
cc26xx_RTOS\IAR Projects\Application\CC2650/../../../../../../../Components/services/nv/cc26xx\\\" -I \"C:\ti\simplelink\
CC2650/../../../../../../../Components/stack/icall\\\" -I C:\ti\tirtos_simplelink_2_11_01_09\products\
cc26xxware_2_20_06_14829/\ -I C:\ti\tirtos_simplelink_2_11_01_09\products\cc26xxware_2_20_06_14829/inc\ -I C:\ti\
tirtos_simplelink_2_11_01_09\products\cc26xxware_2_20_06_14829/driverlib\ -Ohz" --linkOptions "-o \"C:\ti\simplelink\
timac_1_05_02_43299\Projects\mac\Sample\cc26xx_RTOS\IAR Projects\Application\CC2650\CC2650-PG2-RFD\Exe\
msa_cc2650.out\" --config_def CC2650=1 --config_def USE_SYSBIOS_IN_ROM=1 --config_def
ICALL_STACK0_ADDR=0xB000 --map \"C:\ti\simplelink\timac_1_05_02_43299\Projects\mac\Sample\cc26xx_RTOS\
IAR Projects\Application\CC2650\CC2650-PG2-RFD\List\msa_cc2650.map\" --config \"C:\ti\simplelink\
timac_1_05_02_43299\Projects\mac\Sample\cc26xx_RTOS\IAR Projects\Application\CC2650\cc26xx_app.icf\" -f \"C:\ti\
CC2650/configPkg/linker.cmd\" --keep __vector_table C:\ti\tirtos_simplelink_2_11_01_09\products\
cc26xxware_2_20_06_14829/driverlib/bin/iar/driverlib.lib --entry __iar_program_start --vfe" --profile release --projFile
msa_cc2650.ewp"
Total number of errors: 1
Total number of warnings: 0
