默认配置是给长距离人员检测的。你可以根据这个cfg对比现有3D 人数统计的cfg,修改一个来尝试。
A chirp configuration for using the fall detection feature with "Long Range People Detection" is included with the visualizer at: mmwave_industrial_toolbox_version\labs\people_counting\visualizer\chirp_configs\FallDetection\LRPD_6m.cfg
This will work with either the "Long Range People Detection" binary, or the "3D People Counting" binary. "3D People Counting" is recommended. A chirp configuration for using the fall detection feature with "3D People Counting" is included with the visualizer at: mmwave_industrial_toolbox_version\labs\people_counting\visualizer\chirp_configs\FallDetection\ISK_6m_default.cfg
1. 我尝试烧写C:\ti\mmwave_industrial_toolbox_4_6_0\labs\people_counting\68xx_3D_people_counting\prebuilt_binaries\3D_people_count_68xx_demo.bin到IWR6843ISK-ODS上。
2. 修改GUI(C:\ti\mmwave_industrial_toolbox_4_6_0\labs\people_counting\visualizer\fallDetection_main.py)line 45
if (0): #set to 1 to save terminal output to logFile, set 0 to show terminal output
3. 运行改GUI,使用参数配置为C:\ti\mmwave_industrial_toolbox_4_6_0\labs\people_counting\visualizer\chirp_configs\3D_People_Counting\ODS_6m_default.cfg。可以正常运行,没有报错。
