cortex m4 触摸屏问题(显示都正常,但控制没有反应(touch_xp/yn/xn/yp 在触控下引脚都有电压变化))
程序代码如下:
TOUCH.C程序:
#include "inc/hw_adc.h"
#include "inc/hw_gpio.h"
#include "inc/hw_ints.h"
#include "inc/hw_memmap.h"
#include "inc/hw_timer.h"
#include "inc/hw_types.h"
#include "driverlib/adc.h"
#include "driverlib/gpio.h"
#include "driverlib/interrupt.h"
#include "driverlib/sysctl.h"
#include "driverlib/timer.h"
#include "grlib/grlib.h"
#include "grlib/widget.h"
#include "drivers/touch.h"
// This driver operates in four different screen orientations.  They are:
// * Portrait - The screen is taller than it is wide, and the flex connector is
//              on the left of the display.  This is selected by defining
//              PORTRAIT.
// * Landscape - The screen is wider than it is tall, and the flex connector is
//               on the bottom of the display.  This is selected by defining
//               LANDSCAPE.
// * Portrait flip - The screen is taller than it is wide, and the flex
//                   connector is on the right of the display.  This is
//                   selected by defining PORTRAIT_FLIP.
// * Landscape flip - The screen is wider than it is tall, and the flex
//                    connector is on the top of the display.  This is
//                    selected by defining LANDSCAPE_FLIP.
// These can also be imagined in terms of screen rotation; if portrait mode is
// 0 degrees of screen rotation, landscape is 90 degrees of counter-clockwise
// rotation, portrait flip is 180 degrees of rotation, and landscape flip is
// 270 degress of counter-clockwise rotation.
// If no screen orientation is selected, "landscape flip" mode will be used.
#if ! defined(PORTRAIT) && ! defined(PORTRAIT_FLIP) && \
    ! defined(LANDSCAPE) && ! defined(LANDSCAPE_FLIP)
#define LANDSCAPE_FLIP
#endif
// The GPIO pins to which the touch screen is connected.
#define TS_P_PERIPH             SYSCTL_PERIPH_GPIOE
#define TS_P_BASE               GPIO_PORTE_BASE
#define TS_N_PERIPH             SYSCTL_PERIPH_GPIOE
#define TS_N_BASE               GPIO_PORTE_BASE
#define TS_XP_PIN               GPIO_PIN_6
#define TS_YP_PIN               GPIO_PIN_7
#define TS_XN_PIN               GPIO_PIN_2
#define TS_YN_PIN               GPIO_PIN_3
// The ADC channels connected to each of the touch screen contacts.
#define ADC_CTL_CH_XP ADC_CTL_CH1
#define ADC_CTL_CH_YP ADC_CTL_CH0
// The coefficients used to convert from the ADC touch screen readings to the
// screen pixel positions.
#ifdef PORTRAIT
#define M0                      480
#define M1                      77856
#define M2                      -22165152
#define M3                      86656
#define M4                      1792
#define M5                      -19209728
#define M6                      199628
#endif
#ifdef LANDSCAPE
#define M0                      86784
#define M1                      -1536
#define M2                      -17357952
#define M3                      -144
#define M4                      -78576
#define M5                      69995856
#define M6                      201804
#endif
#ifdef PORTRAIT_FLIP
#define M0                      -864
#define M1                      -79200
#define M2                      70274016
#define M3                      -85088
#define M4                      1056
#define M5                      80992576
#define M6                      199452
#endif
#ifdef LANDSCAPE_FLIP
#define M0                      -83328
#define M1                      1664
#define M2                      78919456
#define M3                      -336
#define M4                      80328
#define M5                      -22248408
#define M6                      198065
#endif
// The current state of the touch screen driver's state machine.  This is used
// to cycle the touch screen interface through the powering sequence required
// to read the two axes of the surface.
static unsigned long g_ulTSState;
#define TS_STATE_INIT           0
#define TS_STATE_READ_X         1
#define TS_STATE_READ_Y         2
#define TS_STATE_SKIP_X         3
#define TS_STATE_SKIP_Y         4
// The most recent raw ADC reading for the X position on the screen.  This
// value is not affected by the selected screen orientation.
volatile short g_sTouchX;
// The most recent raw ADC reading for the Y position on the screen.  This
volatile short g_sTouchY;
// A pointer to the function to receive messages from the touch screen driver
// when events occur on the touch screen (debounced presses, movement while
// pressed, and debounced releases).
static long (*g_pfnTSHandler)(unsigned long ulMessage, long lX, long lY);
// The current state of the touch screen debouncer.  When zero, the pen is up.
// When three, the pen is down.  When one or two, the pen is transitioning from
// one state to the other.
static unsigned char g_cState = 0;
// The queue of debounced pen positions.  This is used to slightly delay the
// returned pen positions, so that the pen positions that occur while the pen
// is being raised are not send to the application.
static short g_psSamples[8];
// The count of pen positions in g_psSamples.  When negative, the buffer is
// being pre-filled as a result of a detected pen down event.
static signed char g_cIndex = 0;
//! Debounces presses of the touch screen.
//! This function is called when a new X/Y sample pair has been captured in
//! order to perform debouncing of the touch screen.
//! \return None.
static void
TouchScreenDebouncer(void)
    long lX, lY, lTemp;
    // Convert the ADC readings into pixel values on the screen.
    lX = g_sTouchX;
    lY = g_sTouchY;
    lTemp = ((lX * M0) + (lY * M1) + M2) / M6;
    lY = ((lX * M3) + (lY * M4) + M5) / M6;
    lX = lTemp;
    // See if the touch screen is being touched.
    if((g_sTouchX < TOUCH_MIN) || (g_sTouchY < TOUCH_MIN))
        // See if the pen is not up right now.
        if(g_cState != 0x00)
            // Decrement the state count.
            g_cState--;
            // See if the pen has been detected as up three times in a row.
            if(g_cState == 0x80)
                // Indicate that the pen is up.
                g_cState = 0x00;
                // See if there is a touch screen event handler.
                if(g_pfnTSHandler)
                    // Send the pen up message to the touch screen event
                    // handler.
                    g_pfnTSHandler(WIDGET_MSG_PTR_UP, g_psSamples[g_cIndex],
                                   g_psSamples[g_cIndex + 1]);
    else
        // See if the pen is not down right now.
        if(g_cState != 0x83)
            // Increment the state count.
            g_cState++;
            // See if the pen has been detected as down three times in a row.
            if(g_cState == 0x03)
                g_cState = 0x83;
                // Set the index to -8, so that the next 3 samples are stored
                // into the sample buffer before sending anything back to the
                // touch screen event handler.
                g_cIndex = -8;
                // Store this sample into the sample buffer.
                g_psSamples[0] = lX;
                g_psSamples[1] = lY;
        else
            // See if the sample buffer pre-fill has completed.
            if(g_cIndex == -2)
                if(g_pfnTSHandler)
                    // Send the pen down message to the touch screen event
                    // handler.
                    g_pfnTSHandler(WIDGET_MSG_PTR_DOWN, g_psSamples[0],
                                   g_psSamples[1]);
                // Set the index to the next sample to send.
                g_cIndex = 2;
            // Otherwise, see if the sample buffer pre-fill is in progress.
            else if(g_cIndex < 0)
                g_psSamples[g_cIndex + 10] = lX;
                g_psSamples[g_cIndex + 11] = lY;
                // Increment the index.
                g_cIndex += 2;
            // Otherwise, the sample buffer is full.
            else
                if(g_pfnTSHandler)
                    // Send the pen move message to the touch screen event
                    // handler.
                    g_pfnTSHandler(WIDGET_MSG_PTR_MOVE, g_psSamples[g_cIndex],
                g_psSamples[g_cIndex] = lX;
                g_psSamples[g_cIndex + 1] = lY;
                g_cIndex = (g_cIndex + 2) & 7;
//! Handles the ADC interrupt for the touch screen.
//! This function is called when the ADC sequence that samples the touch screen
//! has completed its acquisition.  The touch screen state machine is advanced
//! and the acquired ADC sample is processed appropriately.
//! It is the responsibility of the application using the touch screen driver
//! to ensure that this function is installed in the interrupt vector table for
//! the ADC3 interrupt.
//! \return None.
void
TouchScreenIntHandler(void)
    // Clear the ADC sample sequence interrupt.
    HWREG(ADC0_BASE + ADC_O_ISC) = 1 << 3;
    // Determine what to do based on the current state of the state machine.
    switch(g_ulTSState)
        // The new sample is an X axis sample that should be discarded.
        case TS_STATE_SKIP_X:
            // Read and throw away the ADC sample.
            HWREG(ADC0_BASE + ADC_O_SSFIFO3);
            // Set the analog mode select for the YP pin.
            HWREG(TS_P_BASE + GPIO_O_AMSEL) =
                HWREG(TS_P_BASE + GPIO_O_AMSEL) | TS_YP_PIN;
            // Configure the Y axis touch layer pins as inputs.
            HWREG(TS_P_BASE + GPIO_O_DIR) =
                HWREG(TS_P_BASE + GPIO_O_DIR) & ~TS_YP_PIN;
            HWREG(TS_N_BASE + GPIO_O_DIR) =
                HWREG(TS_N_BASE + GPIO_O_DIR) & ~TS_YN_PIN;
            // The next sample will be a valid X axis sample.
            g_ulTSState = TS_STATE_READ_X;
            // This state has been handled.
            break;
        // The new sample is an X axis sample that should be processed.
        case TS_STATE_READ_X:
            // Read the raw ADC sample.
            g_sTouchX = HWREG(ADC0_BASE + ADC_O_SSFIFO3);
            // Clear the analog mode select for the YP pin.
                HWREG(TS_P_BASE + GPIO_O_AMSEL) & ~TS_YP_PIN;
            // Configure the X and Y axis touch layers as outputs.
                HWREG(TS_P_BASE + GPIO_O_DIR) | TS_XP_PIN | TS_YP_PIN;
                HWREG(TS_N_BASE + GPIO_O_DIR) | TS_XN_PIN | TS_YN_PIN;
            // Drive the positive side of the Y axis touch layer with VDD and
            // the negative side with GND.  Also, drive both sides of the X
            // axis layer with GND to discharge any residual voltage (so that
            // a no-touch condition can be properly detected).
            HWREG(TS_N_BASE + GPIO_O_DATA + ((TS_XN_PIN | TS_YN_PIN) << 2)) =
                0;
            HWREG(TS_P_BASE + GPIO_O_DATA + ((TS_XP_PIN | TS_YP_PIN) << 2)) =
                TS_YP_PIN;
            // Configure the sample sequence to capture the X axis value.
            HWREG(ADC0_BASE + ADC_O_SSMUX3) = ADC_CTL_CH_XP;
            // The next sample will be an invalid Y axis sample.
            g_ulTSState = TS_STATE_SKIP_Y;
            break;
        // The new sample is a Y axis sample that should be discarded.
        case TS_STATE_SKIP_Y:
            // Set the analog mode select for the XP pin.
                HWREG(TS_P_BASE + GPIO_O_AMSEL) | TS_XP_PIN;
            // Configure the X axis touch layer pins as inputs.
                HWREG(TS_P_BASE + GPIO_O_DIR) & ~TS_XP_PIN;
                HWREG(TS_N_BASE + GPIO_O_DIR) & ~TS_XN_PIN;
            // The next sample will be a valid Y axis sample.
            g_ulTSState = TS_STATE_READ_Y;
            break;
        // The new sample is a Y axis sample that should be processed.
        case TS_STATE_READ_Y:
            g_sTouchY = HWREG(ADC0_BASE + ADC_O_SSFIFO3);
            // The next configuration is the same as the initial configuration.
            // Therefore, fall through into the initialization state to avoid
            // duplicating the code.
        // The state machine is in its initial state
        case TS_STATE_INIT:
            // Clear the analog mode select for the XP pin.
                HWREG(TS_P_BASE + GPIO_O_AMSEL) & ~TS_XP_PIN;
            // Drive one side of the X axis touch layer with VDD and the other
            // with GND.  Also, drive both sides of the Y axis layer with GND
            // to discharge any residual voltage (so that a no-touch condition
            // can be properly detected).
                TS_XP_PIN;
                0;
            // Configure the sample sequence to capture the Y axis value.
            HWREG(ADC0_BASE + ADC_O_SSMUX3) = ADC_CTL_CH_YP;
            // If this is the valid Y sample state, then there is a new X/Y
            // sample pair.  In that case, run the touch screen debouncer.
            if(g_ulTSState == TS_STATE_READ_Y)
                TouchScreenDebouncer();
            // The next sample will be an invalid X axis sample.
            g_ulTSState = TS_STATE_SKIP_X;
            break;
//! Initializes the touch screen driver.
//! This function initializes the touch screen driver, beginning the process of
//! reading from the touch screen.  This driver uses the following hardware
//! resources:
//! - ADC sample sequence 3
//! - Timer 1 subtimer A
//! \return None.
void
TouchScreenInit(void)
    // Set the initial state of the touch screen driver's state machine.
    g_ulTSState = TS_STATE_INIT;
    // There is no touch screen handler initially.
    g_pfnTSHandler = 0;
    // Enable the peripherals used by the touch screen interface.
    SysCtlPeripheralEnable(SYSCTL_PERIPH_ADC0);
    SysCtlPeripheralEnable(TS_P_PERIPH);
    SysCtlPeripheralEnable(TS_N_PERIPH);
    SysCtlPeripheralEnable(SYSCTL_PERIPH_TIMER1);
    // Configure the ADC sample sequence used to read the touch screen reading.
    ADCHardwareOversampleConfigure(ADC0_BASE, 4);
    ADCSequenceConfigure(ADC0_BASE, 3, ADC_TRIGGER_TIMER, 0);
    ADCSequenceStepConfigure(ADC0_BASE, 3, 0,
                             ADC_CTL_CH_YP | ADC_CTL_END | ADC_CTL_IE);
    ADCSequenceEnable(ADC0_BASE, 3);
    // Enable the ADC sample sequence interrupt.
    ADCIntEnable(ADC0_BASE, 3);
    IntEnable(INT_ADC3);
    // Configure the GPIOs used to drive the touch screen layers.
    GPIOPinTypeGPIOOutput(TS_P_BASE, TS_XP_PIN | TS_YP_PIN);
    GPIOPinTypeGPIOOutput(TS_N_BASE, TS_XN_PIN | TS_YN_PIN);
    GPIOPinWrite(TS_P_BASE, TS_XP_PIN | TS_YP_PIN, 0x00);
    GPIOPinWrite(TS_N_BASE, TS_XN_PIN | TS_YN_PIN, 0x00);
    // See if the ADC trigger timer has been configured, and configure it only
    // if it has not been configured yet.
    if((HWREG(TIMER1_BASE + TIMER_O_CTL) & TIMER_CTL_TAEN) == 0)
        // Configure the timer to trigger the sampling of the touch screen
        // every millisecond.
        TimerConfigure(TIMER1_BASE, (TIMER_CFG_16_BIT_PAIR |
                                     TIMER_CFG_A_PERIODIC |
                                     TIMER_CFG_B_PERIODIC));
        TimerLoadSet(TIMER1_BASE, TIMER_A, (SysCtlClockGet() / 1000) - 1);
        TimerControlTrigger(TIMER1_BASE, TIMER_A, true);
        // Enable the timer.  At this point, the touch screen state machine
        // will sample and run once per millisecond.
        TimerEnable(TIMER1_BASE, TIMER_A);
//! Sets the callback function for touch screen events.
//! \param pfnCallback is a pointer to the function to be called when touch
//! screen events occur.
//! This function sets the address of the function to be called when touch
//! screen events occur.  The events that are recognized are the screen being
//! touched (``pen down''), the touch position moving while the screen is
//! touched (``pen move''), and the screen no longer being touched (``pen
//! up'').
//! \return None.
void
TouchScreenCallbackSet(long (*pfnCallback)(unsigned long ulMessage, long lX,
                                           long lY))
    // Save the pointer to the callback function.
    g_pfnTSHandler = pfnCallback;
// Close the Doxygen group.
HELLO WIDGET.C程序:
#include "grlib/canvas.h"
#include "grlib/pushbutton.h"
#include "drivers/kitronix320x240x16_ssd2119_8bit.h"
#include "drivers/set_pinout.h"
//! \addtogroup example_list
//! <h1>Hello using Widgets (hello_widget)</h1>
//! A very simple ``hello world'' example written using the Stellaris Graphics
//! Library widgets.  It displays a button which, when pressed, toggles
//! display of the words ``Hello World!'' on the screen.  This may be used as
//! a starting point for more complex widget-based applications.
// Forward reference to various widget structures.
extern tCanvasWidget g_sBackground;
extern tPushButtonWidget g_sPushBtn;
// Forward reference to the button press handler.
void OnButtonPress(tWidget *pWidget);
// The heading containing the application title.
Canvas(g_sHeading, &g_sBackground, 0, &g_sPushBtn,
       &g_sKitronix320x240x16_SSD2119, 0, 0, 320, 23,
       (CANVAS_STYLE_FILL | CANVAS_STYLE_OUTLINE | CANVAS_STYLE_TEXT),
       ClrDarkBlue, ClrWhite, ClrWhite, &g_sFontCm20, "hello-widget", 0, 0);
// The canvas widget acting as the background to the display.
Canvas(g_sBackground, WIDGET_ROOT, 0, &g_sHeading,
       &g_sKitronix320x240x16_SSD2119, 0, 23, 320, (240 - 23),
       CANVAS_STYLE_FILL, ClrBlack, 0, 0, 0, 0, 0, 0);
// The button used to hide or display the "Hello World" message.
RectangularButton(g_sPushBtn, &g_sHeading, 0, 0,
                  &g_sKitronix320x240x16_SSD2119, 60, 60, 200, 40,
                  (PB_STYLE_OUTLINE | PB_STYLE_TEXT_OPAQUE | PB_STYLE_TEXT |
                   PB_STYLE_FILL | PB_STYLE_RELEASE_NOTIFY),
                   ClrDarkBlue, ClrBlue, ClrWhite, ClrWhite,
                   &g_sFontCmss22b, "Show Welcome", 0, 0, 0, 0, OnButtonPress);
// The canvas widget used to display the "Hello!" string.  Note that this
// is NOT hooked into the active widget tree (by making it a child of the
// g_sPushBtn widget above) yet since we do not want the widget to be displayed
// until the button is pressed.
Canvas(g_sHello, &g_sPushBtn, 0, 0,
       &g_sKitronix320x240x16_SSD2119, 0, 150, 320, 40,
       (CANVAS_STYLE_FILL | CANVAS_STYLE_TEXT),
       ClrBlack, 0, ClrWhite, &g_sFontCm40, "Hello World!", 0, 0);
// A global we use to keep track of whether or not the "Hello" widget is
// currently visible.
tBoolean g_bHelloVisible = false;
// The error routine that is called if the driver library encounters an error.
#ifdef DEBUG
void
__error__(char *pcFilename, unsigned long ulLine)
#endif
// This function is called by the graphics library widget manager in the
// context of WidgetMessageQueueProcess whenever the user releases the
// "Press Me!" button.  We use this notification to display or hide the
// "Hello!" widget.
// This is actually a rather inefficient way to accomplish this but it's
// a good example of how to add and remove widgets dynamically.  In
// normal circumstances, you would likely leave the g_sHello widget
// linked into the tree and merely add or remove the text by changing
// its style then repainting.
// If using this dynamic add/remove strategy, another useful optimization
// is to use a black canvas widget that covers the same area of the screen
// as the widgets that you will be adding and removing.  If this is the used
// as the point in the tree where the subtree is added or removed, you can
// repaint just the desired area by repainting the black canvas rather than
// repainting the whole tree.
void
    g_bHelloVisible = !g_bHelloVisible;
    if(g_bHelloVisible)
        // Add the Hello widget to the tree as a child of the push
        // button.  We could add it elsewhere but this seems as good a
        // place as any.  It also means we can repaint from g_sPushBtn and
        // this will paint both the button and the welcome message.
        WidgetAdd((tWidget *)&g_sPushBtn, (tWidget *)&g_sHello);
        // Change the button text to indicate the new function.
        PushButtonTextSet(&g_sPushBtn, "Hide Welcome");
        // Repaint the pushbutton and all widgets beneath it (in this case,
        // the welcome message).
        WidgetPaint((tWidget *)&g_sPushBtn);
    else
        // Remove the Hello widget from the tree.
        WidgetRemove((tWidget *)&g_sHello);
        PushButtonTextSet(&g_sPushBtn, "Show Welcome");
        // Repaint the widget tree to remove the Hello widget from the
        // display.  This is rather inefficient but saves having to use
        // additional widgets to overpaint the area of the Hello text (since
        // disabling a widget does not automatically erase whatever it
        // previously displayed on the screen).
        WidgetPaint(WIDGET_ROOT);
// Print "Hello World!" to the display on the Intelligent Display Module.
int
main(void)
    // Set the system clock to run at 50MHz from the PLL
    SysCtlClockSet(SYSCTL_SYSDIV_4 | SYSCTL_USE_PLL | SYSCTL_OSC_MAIN |
                       SYSCTL_XTAL_16MHZ);
    // Set the device pinout appropriately for this board.
    PinoutSet();
    // Enable Interrupts
    IntMasterEnable();
    // Initialize the display driver.
    Kitronix320x240x16_SSD2119Init();
    // Initialize the touch screen driver.
    TouchScreenInit();
    // Set the touch screen event handler.
    TouchScreenCallbackSet(WidgetPointerMessage);
    // Add the compile-time defined widgets to the widget tree.
    WidgetAdd(WIDGET_ROOT, (tWidget *)&g_sBackground);
    // Paint the widget tree to make sure they all appear on the display.
    // Loop forever, processing widget messages.
    while(1)
        // Process any messages from or for the widgets.
        WidgetMessageQueueProcess();
  • cortex m4 触摸屏问题(显示都正常,但控制没有反应(touch_xp/yn/xn/yp 在触控下引脚都有电压变化))
    1 Follower 0 回复 | 此帖子有 0 确认答案 |
  • cortex m4 触摸屏问题(显示都正常,但触摸控制没有反应(touch_xp/yn/xn/yp 在触控下引脚都有电压变化(电压正常)))
  • 程序代码如下:
    TOUCH.C程序:
    //              PORTRAIT.
    //               LANDSCAPE.
    #endif
    #ifdef PORTRAIT
    #define M0                      480
    #define M1                      77856
    #define M3                      86656
    #define M4                      1792
    #define M6                      199628
    #endif
    #ifdef LANDSCAPE
    #define M0                      86784
    #define M1                      -1536
    #define M3                      -144
    #define M4                      -78576
    #define M5                      69995856
    #define M6                      201804
    #endif
    #define M0                      -864
    #define M1                      -79200
    #define M2                      70274016
    #define M3                      -85088
    #define M4                      1056
    #define M5                      80992576
    #define M6                      199452
    #endif
    #define M0                      -83328
    #define M1                      1664
    #define M2                      78919456
    #define M3                      -336
    #define M4                      80328
    #define M6                      198065
    #endif
    //! \return None.
    static void
       long lX, lY, lTemp;
       lX = g_sTouchX;
       lY = g_sTouchY;
       lX = lTemp;
               g_cState--;
                   g_cState = 0x00;
                   if(g_pfnTSHandler)
                       // handler.
       else
               g_cState++;
                   g_cState = 0x83;
                   g_cIndex = -8;
           else
               if(g_cIndex == -2)
                   if(g_pfnTSHandler)
                       // handler.
                                      g_psSamples[1]);
                   g_cIndex = 2;
                   g_cIndex += 2;
               else
                   if(g_pfnTSHandler)
                       // handler.
    //! \return None.
    void
       switch(g_ulTSState)
               break;
                   0;
                   TS_YP_PIN;
               break;
               break;
           case TS_STATE_INIT:
                   TS_XP_PIN;
                   0;
               break;
    //! resources:
    //! \return None.
    void
       g_pfnTSHandler = 0;
    //! up'').
    //! \return None.
    void
                                              long lY))
    HELLO WIDGET.C程序:
    #ifdef DEBUG
    void
    #endif
    // "Hello!" widget.
    void
       if(g_bHelloVisible)
       else
    int
    main(void)
                          SYSCTL_XTAL_16MHZ);
       PinoutSet();
       IntMasterEnable();
       TouchScreenInit();
       while(1)
