cortex m4 触摸屏问题(显示都正常,但控制没有反应(touch_xp/yn/xn/yp 在触控下引脚都有电压变化))
这个程序是从CORTEX M3 LM3S9B96开发板改过来的
// touch.c - Touch screen driver for the Tempest EAC board.
// Copyright (c) 2008-2009 Luminary Micro, Inc.  All rights reserved.
// Software License Agreement
// Luminary Micro, Inc. (LMI) is supplying this software for use solely and
// exclusively on LMI's microcontroller products.
// The software is owned by LMI and/or its suppliers, and is protected under
// applicable copyright laws.  All rights are reserved.  You may not combine
// this software with "viral" open-source software in order to form a larger
// program.  Any use in violation of the foregoing restrictions may subject
// the user to criminal sanctions under applicable laws, as well as to civil
// liability for the breach of the terms and conditions of this license.
// THIS SOFTWARE IS PROVIDED "AS IS".  NO WARRANTIES, WHETHER EXPRESS, IMPLIED
// OR STATUTORY, INCLUDING, BUT NOT LIMITED TO, IMPLIED WARRANTIES OF
// MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE APPLY TO THIS SOFTWARE.
// LMI SHALL NOT, IN ANY CIRCUMSTANCES, BE LIABLE FOR SPECIAL, INCIDENTAL, OR
// CONSEQUENTIAL DAMAGES, FOR ANY REASON WHATSOEVER.
// This is part of revision 4652 of the DK-LM3S9B96 Firmware Package.
//! \addtogroup touch_api
#include "inc/hw_adc.h"
#include "inc/hw_gpio.h"
#include "inc/hw_ints.h"
#include "inc/hw_memmap.h"
#include "inc/hw_timer.h"
#include "inc/hw_types.h"
#include "driverlib/adc.h"
#include "driverlib/gpio.h"
#include "driverlib/interrupt.h"
#include "driverlib/sysctl.h"
#include "driverlib/timer.h"
#include "grlib/grlib.h"
#include "grlib/widget.h"
#include "drivers/touch.h"
// This driver operates in four different screen orientations.  They are:
// * Portrait - The screen is taller than it is wide, and the flex connector is
//              on the left of the display.  This is selected by defining
//              PORTRAIT.
// * Landscape - The screen is wider than it is tall, and the flex connector is
//               on the bottom of the display.  This is selected by defining
//               LANDSCAPE.
// * Portrait flip - The screen is taller than it is wide, and the flex
//                   connector is on the right of the display.  This is
//                   selected by defining PORTRAIT_FLIP.
// * Landscape flip - The screen is wider than it is tall, and the flex
//                    connector is on the top of the display.  This is
//                    selected by defining LANDSCAPE_FLIP.
// These can also be imagined in terms of screen rotation; if portrait mode is
// 0 degrees of screen rotation, landscape is 90 degrees of counter-clockwise
// rotation, portrait flip is 180 degrees of rotation, and landscape flip is
// 270 degress of counter-clockwise rotation.
// If no screen orientation is selected, "landscape flip" mode will be used.
#if ! defined(PORTRAIT) && ! defined(PORTRAIT_FLIP) && \
   ! defined(LANDSCAPE) && ! defined(LANDSCAPE_FLIP)
#define LANDSCAPE_FLIP
#endif
// The GPIO pins to which the touch screen is connected.
#define TS_P_PERIPH             SYSCTL_PERIPH_GPIOK
#define TS_P_BASE               GPIO_PORTK_BASE
#define TS_N_PERIPH             SYSCTL_PERIPH_GPIOK
#define TS_N_BASE               GPIO_PORTK_BASE
#define TS_XP_PIN               GPIO_PIN_0
#define TS_YP_PIN               GPIO_PIN_3
#define TS_XN_PIN               GPIO_PIN_2
#define TS_YN_PIN               GPIO_PIN_1
// The ADC channels connected to each of the touch screen contacts.
#define ADC_CTL_CH_XP  ADC_CTL_CH16
#define ADC_CTL_CH_YP  ADC_CTL_CH19
// The coefficients used to convert from the ADC touch screen readings to the
// screen pixel positions.
#ifdef PORTRAIT
#define M0                      480
#define M1                      77856
#define M2                      -22165152
#define M3                      86656
#define M4                      1792
#define M5                      -19209728
#define M6                      199628
#endif
#ifdef LANDSCAPE
#define M0                      86784
#define M1                      -1536
#define M2                      -17357952
#define M3                      -144
#define M4                      -78576
#define M5                      69995856
#define M6                      201804
#endif
#ifdef PORTRAIT_FLIP
#define M0                      -864
#define M1                      -79200
#define M2                      70274016
#define M3                      -85088
#define M4                      1056
#define M5                      80992576
#define M6                      199452
#endif
#ifdef LANDSCAPE_FLIP
#define M0                      -83328
#define M1                      1664
#define M2                      78919456
#define M3                      -336
#define M4                      80328
#define M5                      -22248408
#define M6                      198065
#endif
// The current state of the touch screen driver's state machine.  This is used
// to cycle the touch screen interface through the powering sequence required
// to read the two axes of the surface.
static unsigned long g_ulTSState;
#define TS_STATE_INIT           0
#define TS_STATE_READ_X         1
#define TS_STATE_READ_Y         2
#define TS_STATE_SKIP_X         3
#define TS_STATE_SKIP_Y         4
// The most recent raw ADC reading for the X position on the screen.  This
// value is not affected by the selected screen orientation.
volatile short g_sTouchX;
// The most recent raw ADC reading for the Y position on the screen.  This
volatile short g_sTouchY;
// A pointer to the function to receive messages from the touch screen driver
// when events occur on the touch screen (debounced presses, movement while
// pressed, and debounced releases).
static long (*g_pfnTSHandler)(unsigned long ulMessage, long lX, long lY);
// The current state of the touch screen debouncer.  When zero, the pen is up.
// When three, the pen is down.  When one or two, the pen is transitioning from
// one state to the other.
static unsigned char g_cState = 0;
// The queue of debounced pen positions.  This is used to slightly delay the
// returned pen positions, so that the pen positions that occur while the pen
// is being raised are not send to the application.
static short g_psSamples[8];
// The count of pen positions in g_psSamples.  When negative, the buffer is
// being pre-filled as a result of a detected pen down event.
static signed char g_cIndex = 0;
//! Debounces presses of the touch screen.
//! This function is called when a new X/Y sample pair has been captured in
//! order to perform debouncing of the touch screen.
//! \return None.
static void
TouchScreenDebouncer(void)
   long lX, lY, lTemp;
   // Convert the ADC readings into pixel values on the screen.
   lX = g_sTouchX;
   lY = g_sTouchY;
   lTemp = ((lX * M0) + (lY * M1) + M2) / M6;
   lY = ((lX * M3) + (lY * M4) + M5) / M6;
   lX = lTemp;
   // See if the touch screen is being touched.
   if((g_sTouchX < TOUCH_MIN) || (g_sTouchY < TOUCH_MIN))
       // See if the pen is not up right now.
       if(g_cState != 0x00)
           // Decrement the state count.
           g_cState--;
           // See if the pen has been detected as up three times in a row.
           if(g_cState == 0x80)
               // Indicate that the pen is up.
               g_cState = 0x00;
               // See if there is a touch screen event handler.
               if(g_pfnTSHandler)
                   // Send the pen up message to the touch screen event
                   // handler.
                   g_pfnTSHandler(WIDGET_MSG_PTR_UP, g_psSamples[g_cIndex],
                                  g_psSamples[g_cIndex + 1]);
   else
       // See if the pen is not down right now.
       if(g_cState != 0x83)
           // Increment the state count.
           g_cState++;
           // See if the pen has been detected as down three times in a row.
           if(g_cState == 0x03)
               g_cState = 0x83;
               // Set the index to -8, so that the next 3 samples are stored
               // into the sample buffer before sending anything back to the
               // touch screen event handler.
               g_cIndex = -8;
               // Store this sample into the sample buffer.
               g_psSamples[0] = lX;
               g_psSamples[1] = lY;
       else
           // See if the sample buffer pre-fill has completed.
           if(g_cIndex == -2)
               if(g_pfnTSHandler)
                   // Send the pen down message to the touch screen event
                   // handler.
                   g_pfnTSHandler(WIDGET_MSG_PTR_DOWN, g_psSamples[0],
                                  g_psSamples[1]);
               // Set the index to the next sample to send.
               g_cIndex = 2;
           // Otherwise, see if the sample buffer pre-fill is in progress.
           else if(g_cIndex < 0)
               g_psSamples[g_cIndex + 10] = lX;
               g_psSamples[g_cIndex + 11] = lY;
               // Increment the index.
               g_cIndex += 2;
           // Otherwise, the sample buffer is full.
           else
               if(g_pfnTSHandler)
                   // Send the pen move message to the touch screen event
                   // handler.
                   g_pfnTSHandler(WIDGET_MSG_PTR_MOVE, g_psSamples[g_cIndex],
               g_psSamples[g_cIndex] = lX;
               g_psSamples[g_cIndex + 1] = lY;
               g_cIndex = (g_cIndex + 2) & 7;
//! Handles the ADC interrupt for the touch screen.
//! This function is called when the ADC sequence that samples the touch screen
//! has completed its acquisition.  The touch screen state machine is advanced
//! and the acquired ADC sample is processed appropriately.
//! It is the responsibility of the application using the touch screen driver
//! to ensure that this function is installed in the interrupt vector table for
//! the ADC3 interrupt.
//! \return None.
void
TouchScreenIntHandler(void)
   // Clear the ADC sample sequence interrupt.
   HWREG(ADC0_BASE + ADC_O_ISC) = 1 << 3;
   // Determine what to do based on the current state of the state machine.
   switch(g_ulTSState)
       // The new sample is an X axis sample that should be discarded.
       case TS_STATE_SKIP_X:
           // Read and throw away the ADC sample.
           HWREG(ADC0_BASE + ADC_O_SSFIFO3);
           // Set the analog mode select for the YP pin.
           HWREG(TS_P_BASE + GPIO_O_AMSEL) =
               HWREG(TS_P_BASE + GPIO_O_AMSEL) | TS_YP_PIN;
           // Configure the Y axis touch layer pins as inputs.
           HWREG(TS_P_BASE + GPIO_O_DIR) =
               HWREG(TS_P_BASE + GPIO_O_DIR) & ~TS_YP_PIN;
           HWREG(TS_N_BASE + GPIO_O_DIR) =
               HWREG(TS_N_BASE + GPIO_O_DIR) & ~TS_YN_PIN;
           // The next sample will be a valid X axis sample.
           g_ulTSState = TS_STATE_READ_X;
           // This state has been handled.
           break;
       // The new sample is an X axis sample that should be processed.
       case TS_STATE_READ_X:
           // Read the raw ADC sample.
           g_sTouchX = HWREG(ADC0_BASE + ADC_O_SSFIFO3);
           // Clear the analog mode select for the YP pin.
               HWREG(TS_P_BASE + GPIO_O_AMSEL) & ~TS_YP_PIN;
           // Configure the X and Y axis touch layers as outputs.
               HWREG(TS_P_BASE + GPIO_O_DIR) | TS_XP_PIN | TS_YP_PIN;
               HWREG(TS_N_BASE + GPIO_O_DIR) | TS_XN_PIN | TS_YN_PIN;
           // Drive the positive side of the Y axis touch layer with VDD and
           // the negative side with GND.  Also, drive both sides of the X
           // axis layer with GND to discharge any residual voltage (so that
           // a no-touch condition can be properly detected).
           HWREG(TS_N_BASE + GPIO_O_DATA + ((TS_XN_PIN | TS_YN_PIN) << 2)) =
               0;
           HWREG(TS_P_BASE + GPIO_O_DATA + ((TS_XP_PIN | TS_YP_PIN) << 2)) =
               TS_YP_PIN;
           // Configure the sample sequence to capture the X axis value.
           HWREG(ADC0_BASE + ADC_O_SSMUX3) = ADC_CTL_CH_XP;
           // The next sample will be an invalid Y axis sample.
           g_ulTSState = TS_STATE_SKIP_Y;
           break;
       // The new sample is a Y axis sample that should be discarded.
       case TS_STATE_SKIP_Y:
           // Set the analog mode select for the XP pin.
               HWREG(TS_P_BASE + GPIO_O_AMSEL) | TS_XP_PIN;
           // Configure the X axis touch layer pins as inputs.
               HWREG(TS_P_BASE + GPIO_O_DIR) & ~TS_XP_PIN;
               HWREG(TS_N_BASE + GPIO_O_DIR) & ~TS_XN_PIN;
           // The next sample will be a valid Y axis sample.
           g_ulTSState = TS_STATE_READ_Y;
           break;
       // The new sample is a Y axis sample that should be processed.
       case TS_STATE_READ_Y:
           g_sTouchY = HWREG(ADC0_BASE + ADC_O_SSFIFO3);
           // The next configuration is the same as the initial configuration.
           // Therefore, fall through into the initialization state to avoid
           // duplicating the code.
       // The state machine is in its initial state
       case TS_STATE_INIT:
           // Clear the analog mode select for the XP pin.
               HWREG(TS_P_BASE + GPIO_O_AMSEL) & ~TS_XP_PIN;
           // Drive one side of the X axis touch layer with VDD and the other
           // with GND.  Also, drive both sides of the Y axis layer with GND
           // to discharge any residual voltage (so that a no-touch condition
           // can be properly detected).
               TS_XP_PIN;
               0;
           // Configure the sample sequence to capture the Y axis value.
           HWREG(ADC0_BASE + ADC_O_SSMUX3) = ADC_CTL_CH_YP;
           // If this is the valid Y sample state, then there is a new X/Y
           // sample pair.  In that case, run the touch screen debouncer.
           if(g_ulTSState == TS_STATE_READ_Y)
               TouchScreenDebouncer();
           // The next sample will be an invalid X axis sample.
           g_ulTSState = TS_STATE_SKIP_X;
           break;
//! Initializes the touch screen driver.
//! This function initializes the touch screen driver, beginning the process of
//! reading from the touch screen.  This driver uses the following hardware
//! resources:
//! - ADC sample sequence 3
//! - Timer 1 subtimer A
//! \return None.
void
TouchScreenInit(void)
   // Set the initial state of the touch screen driver's state machine.
   g_ulTSState = TS_STATE_INIT;
   // There is no touch screen handler initially.
   g_pfnTSHandler = 0;
   // Enable the peripherals used by the touch screen interface.
   GPIOPinTypeADC(GPIO_PORTK_BASE, GPIO_PIN_3);
   SysCtlPeripheralEnable(SYSCTL_PERIPH_ADC0);
   SysCtlPeripheralEnable(TS_P_PERIPH);
   SysCtlPeripheralEnable(TS_N_PERIPH);
   SysCtlPeripheralEnable(SYSCTL_PERIPH_TIMER1);
   // Configure the ADC sample sequence used to read the touch screen reading.
   ADCHardwareOversampleConfigure(ADC0_BASE, 4);
   ADCSequenceConfigure(ADC0_BASE, 3, ADC_TRIGGER_TIMER, 0);
   ADCSequenceStepConfigure(ADC0_BASE, 3, 0,
                            ADC_CTL_CH_YP | ADC_CTL_END | ADC_CTL_IE);
   ADCSequenceEnable(ADC0_BASE, 3);
   // Enable the ADC sample sequence interrupt.
   ADCIntEnable(ADC_BASE, 3);
   IntEnable(INT_ADC3);
   // Configure the GPIOs used to drive the touch screen layers.
   GPIOPinTypeGPIOOutput(TS_P_BASE, TS_XP_PIN | TS_YP_PIN);
   GPIOPinTypeGPIOOutput(TS_N_BASE, TS_XN_PIN | TS_YN_PIN);
   GPIOPinWrite(TS_P_BASE, TS_XP_PIN | TS_YP_PIN, 0x00);
   GPIOPinWrite(TS_N_BASE, TS_XN_PIN | TS_YN_PIN, 0x00);
   // See if the ADC trigger timer has been configured, and configure it only
   // if it has not been configured yet.
   if((HWREG(TIMER1_BASE + TIMER_O_CTL) & TIMER_CTL_TAEN) == 0)
       // Configure the timer to trigger the sampling of the touch screen
       // every millisecond.
       TimerConfigure(TIMER1_BASE, (TIMER_CFG_16_BIT_PAIR |
                                    TIMER_CFG_A_PERIODIC |
                                    TIMER_CFG_B_PERIODIC));
       TimerLoadSet(TIMER1_BASE, TIMER_A, (SysCtlClockGet() / 1000) - 1);
       TimerControlTrigger(TIMER1_BASE, TIMER_A, true);
       // Enable the timer.  At this point, the touch screen state machine
       // will sample and run once per millisecond.
       TimerEnable(TIMER1_BASE, TIMER_A);
//! Sets the callback function for touch screen events.
//! \param pfnCallback is a pointer to the function to be called when touch
//! screen events occur.
//! This function sets the address of the function to be called when touch
//! screen events occur.  The events that are recognized are the screen being
//! touched (``pen down''), the touch position moving while the screen is
//! touched (``pen move''), and the screen no longer being touched (``pen
//! up'').
//! \return None.
void
TouchScreenCallbackSet(long (*pfnCallback)(unsigned long ulMessage, long lX,
                                          long lY))
   // Save the pointer to the callback function.
   g_pfnTSHandler = pfnCallback;
// Close the Doxygen group.
