请教专家关于CORTEX M4技术问题
cortex m4里怎么没有set_pinout.c和set_pinout.h文件?
我用PK0..3作为触摸屏的引脚(touch_xp/touch_yn/touch_xn/touch_yp)应该怎么去设定?
以下是我从LM3S9B96里提出来的set_pinout.c程序,配置如下:(问题现象是:触摸屏控制无反应)
void
PinoutSet(void)
   // Enable all GPIO banks.
   SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOA);
   SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOB);
   SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOC);
   SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOD);
   SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOE);
   SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOF);
   SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOG);
   SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOH);
   SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOJ);
   SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOK);
   SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOL);
   SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOM);
   SysCtlPeripheralEnable(SYSCTL_PERIPH_GPION);
   SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOP);
  HWREG(GPIO_PORTD_BASE + GPIO_O_PCTL) = GPIO_PCTL_PD0_I2C3SCL |
                                          GPIO_PCTL_PD1_I2C3SDA |
                                          GPIO_PCTL_PD2_SSI1Rx |
                                          GPIO_PCTL_PD3_SSI1Tx |
                                          GPIO_PCTL_PD4_U6Rx |
                                          GPIO_PCTL_PD5_U6Tx |
                                          GPIO_PCTL_PD6_U2Rx |
                                          GPIO_PCTL_PD7_U2Tx;
   HWREG(GPIO_PORTK_BASE + GPIO_O_PCTL) =                                         GPIO_PCTL_PK0_SSI3CLK |
                                          GPIO_PCTL_PK1_SSI3FSS |
                                          GPIO_PCTL_PK2_SSI3RX |
                                          GPIO_PCTL_PK3_SSI3TX |
                                          GPIO_PCTL_PK4_RTCCLK |
                                          GPIO_PCTL_PK5_U7TX |
                                          GPIO_PCTL_PK6_WT1CCP0 |
                                          GPIO_PCTL_PK7_WT1CCP1;
  • Pinout set这个只是使能相应的外设,楼主只需要根据你用到的外设使能相应器件就可以了。touch这个部分实际上是先用IO设置相应的电平,然后用AD分别测量x y方向电平以确定屏幕某一点是不是有按下。
    在touch两个文件里有设置管脚以及ADC通道的宏定义,楼主可以检查一下。同时有用到中断处理函数,需要指定ADC Sequencer 3的中断处理函数到TouchScreenIntHandler
  • 这是我的TOUCH.C程序,您帮忙分析下看看有没有出错的地方,谢!
    //! \addtogroup touch_api
    #include "inc/hw_adc.h"
    #include "inc/hw_gpio.h"
    #include "inc/hw_ints.h"
    #include "inc/hw_memmap.h"
    #include "inc/hw_timer.h"
    #include "inc/hw_types.h"
    #include "driverlib/adc.h"
    #include "driverlib/gpio.h"
    #include "driverlib/interrupt.h"
    #include "driverlib/sysctl.h"
    #include "driverlib/timer.h"
    #include "grlib/grlib.h"
    #include "grlib/widget.h"
    #include "drivers/touch.h"
    // This driver operates in four different screen orientations.  They are:
    // * Portrait - The screen is taller than it is wide, and the flex connector is
    //              on the left of the display.  This is selected by defining
    //              PORTRAIT.
    // * Landscape - The screen is wider than it is tall, and the flex connector is
    //               on the bottom of the display.  This is selected by defining
    //               LANDSCAPE.
    // * Portrait flip - The screen is taller than it is wide, and the flex
    //                   connector is on the right of the display.  This is
    //                   selected by defining PORTRAIT_FLIP.
    // * Landscape flip - The screen is wider than it is tall, and the flex
    //                    connector is on the top of the display.  This is
    //                    selected by defining LANDSCAPE_FLIP.
    // These can also be imagined in terms of screen rotation; if portrait mode is
    // 0 degrees of screen rotation, landscape is 90 degrees of counter-clockwise
    // rotation, portrait flip is 180 degrees of rotation, and landscape flip is
    // 270 degress of counter-clockwise rotation.
    // If no screen orientation is selected, "landscape flip" mode will be used.
    #if ! defined(PORTRAIT) && ! defined(PORTRAIT_FLIP) && \
       ! defined(LANDSCAPE) && ! defined(LANDSCAPE_FLIP)
    #define LANDSCAPE_FLIP
    #endif
    // The GPIO pins to which the touch screen is connected.
    #define TS_P_PERIPH             SYSCTL_PERIPH_GPIOK
    #define TS_P_BASE               GPIO_PORTK_BASE
    #define TS_N_PERIPH             SYSCTL_PERIPH_GPIOK
    #define TS_N_BASE               GPIO_PORTK_BASE
    #define TS_XP_PIN               GPIO_PIN_0
    #define TS_YP_PIN               GPIO_PIN_3
    #define TS_XN_PIN               GPIO_PIN_2
    #define TS_YN_PIN               GPIO_PIN_1
    // The ADC channels connected to each of the touch screen contacts.
    #define ADC_CTL_CH_XP  ADC_CTL_CH16
    #define ADC_CTL_CH_YP  ADC_CTL_CH19
    // The coefficients used to convert from the ADC touch screen readings to the
    // screen pixel positions.
    #ifdef PORTRAIT
    #define M0                      480
    #define M1                      77856
    #define M2                      -22165152
    #define M3                      86656
    #define M4                      1792
    #define M5                      -19209728
    #define M6                      199628
    #endif
    #ifdef LANDSCAPE
    #define M0                      86784
    #define M1                      -1536
    #define M2                      -17357952
    #define M3                      -144
    #define M4                      -78576
    #define M5                      69995856
    #define M6                      201804
    #endif
    #ifdef PORTRAIT_FLIP
    #define M0                      -864
    #define M1                      -79200
    #define M2                      70274016
    #define M3                      -85088
    #define M4                      1056
    #define M5                      80992576
    #define M6                      199452
    #endif
    #ifdef LANDSCAPE_FLIP
    #define M0                      -83328
    #define M1                      1664
    #define M2                      78919456
    #define M3                      -336
    #define M4                      80328
    #define M5                      -22248408
    #define M6                      198065
    #endif
    // The current state of the touch screen driver's state machine.  This is used
    // to cycle the touch screen interface through the powering sequence required
    // to read the two axes of the surface.
    static unsigned long g_ulTSState;
    #define TS_STATE_INIT           0
    #define TS_STATE_READ_X         1
    #define TS_STATE_READ_Y         2
    #define TS_STATE_SKIP_X         3
    #define TS_STATE_SKIP_Y         4
    // The most recent raw ADC reading for the X position on the screen.  This
    // value is not affected by the selected screen orientation.
    volatile short g_sTouchX;
    // The most recent raw ADC reading for the Y position on the screen.  This
    volatile short g_sTouchY;
    // A pointer to the function to receive messages from the touch screen driver
    // when events occur on the touch screen (debounced presses, movement while
    // pressed, and debounced releases).
    static long (*g_pfnTSHandler)(unsigned long ulMessage, long lX, long lY);
    // The current state of the touch screen debouncer.  When zero, the pen is up.
    // When three, the pen is down.  When one or two, the pen is transitioning from
    // one state to the other.
    static unsigned char g_cState = 0;
    // The queue of debounced pen positions.  This is used to slightly delay the
    // returned pen positions, so that the pen positions that occur while the pen
    // is being raised are not send to the application.
    static short g_psSamples[8];
    // The count of pen positions in g_psSamples.  When negative, the buffer is
    // being pre-filled as a result of a detected pen down event.
    static signed char g_cIndex = 0;
    //! Debounces presses of the touch screen.
    //! This function is called when a new X/Y sample pair has been captured in
    //! order to perform debouncing of the touch screen.
    //! \return None.
    static void
    TouchScreenDebouncer(void)
       long lX, lY, lTemp;
       // Convert the ADC readings into pixel values on the screen.
       lX = g_sTouchX;
       lY = g_sTouchY;
       lTemp = ((lX * M0) + (lY * M1) + M2) / M6;
       lY = ((lX * M3) + (lY * M4) + M5) / M6;
       lX = lTemp;
       // See if the touch screen is being touched.
       if((g_sTouchX < TOUCH_MIN) || (g_sTouchY < TOUCH_MIN))
           // See if the pen is not up right now.
           if(g_cState != 0x00)
               // Decrement the state count.
               g_cState--;
               // See if the pen has been detected as up three times in a row.
               if(g_cState == 0x80)
                   // Indicate that the pen is up.
                   g_cState = 0x00;
                   // See if there is a touch screen event handler.
                   if(g_pfnTSHandler)
                       // Send the pen up message to the touch screen event
                       // handler.
                       g_pfnTSHandler(WIDGET_MSG_PTR_UP, g_psSamples[g_cIndex],
                                      g_psSamples[g_cIndex + 1]);
       else
           // See if the pen is not down right now.
           if(g_cState != 0x83)
               // Increment the state count.
               g_cState++;
               // See if the pen has been detected as down three times in a row.
               if(g_cState == 0x03)
                   g_cState = 0x83;
                   // Set the index to -8, so that the next 3 samples are stored
                   // into the sample buffer before sending anything back to the
                   // touch screen event handler.
                   g_cIndex = -8;
                   // Store this sample into the sample buffer.
                   g_psSamples[0] = lX;
                   g_psSamples[1] = lY;
           else
               // See if the sample buffer pre-fill has completed.
               if(g_cIndex == -2)
                   if(g_pfnTSHandler)
                       // Send the pen down message to the touch screen event
                       // handler.
                       g_pfnTSHandler(WIDGET_MSG_PTR_DOWN, g_psSamples[0],
                                      g_psSamples[1]);
                   // Set the index to the next sample to send.
                   g_cIndex = 2;
               // Otherwise, see if the sample buffer pre-fill is in progress.
               else if(g_cIndex < 0)
                   g_psSamples[g_cIndex + 10] = lX;
                   g_psSamples[g_cIndex + 11] = lY;
                   // Increment the index.
                   g_cIndex += 2;
               // Otherwise, the sample buffer is full.
               else
                   if(g_pfnTSHandler)
                       // Send the pen move message to the touch screen event
                       // handler.
                       g_pfnTSHandler(WIDGET_MSG_PTR_MOVE, g_psSamples[g_cIndex],
                   g_psSamples[g_cIndex] = lX;
                   g_psSamples[g_cIndex + 1] = lY;
                   g_cIndex = (g_cIndex + 2) & 7;
    //! Handles the ADC interrupt for the touch screen.
    //! This function is called when the ADC sequence that samples the touch screen
    //! has completed its acquisition.  The touch screen state machine is advanced
    //! and the acquired ADC sample is processed appropriately.
    //! It is the responsibility of the application using the touch screen driver
    //! to ensure that this function is installed in the interrupt vector table for
    //! the ADC3 interrupt.
    //! \return None.
    void
    TouchScreenIntHandler(void)
       // Clear the ADC sample sequence interrupt.
       HWREG(ADC0_BASE + ADC_O_ISC) = 1 << 3;   //SS3中断清零 INR3置1
       // Determine what to do based on the current state of the state machine.
       switch(g_ulTSState)
           // The new sample is an X axis sample that should be discarded.
           case TS_STATE_SKIP_X:
               // Read and throw away the ADC sample.
               HWREG(ADC0_BASE + ADC_O_SSFIFO3);
               // Set the analog mode select for the YP pin.
               HWREG(TS_P_BASE + GPIO_O_AMSEL) =
                   HWREG(TS_P_BASE + GPIO_O_AMSEL) | TS_YP_PIN; //设置PK3为模拟通道
               // Configure the Y axis touch layer pins as inputs.
               HWREG(TS_P_BASE + GPIO_O_DIR) =
                   HWREG(TS_P_BASE + GPIO_O_DIR) & ~TS_YP_PIN;
               HWREG(TS_N_BASE + GPIO_O_DIR) =
                   HWREG(TS_N_BASE + GPIO_O_DIR) & ~TS_YN_PIN;
               // The next sample will be a valid X axis sample.
               g_ulTSState = TS_STATE_READ_X;
               // This state has been handled.
               break;
           // The new sample is an X axis sample that should be processed.
           case TS_STATE_READ_X:
               // Read the raw ADC sample.
               g_sTouchX = HWREG(ADC0_BASE + ADC_O_SSFIFO3);
               // Clear the analog mode select for the YP pin.
                   HWREG(TS_P_BASE + GPIO_O_AMSEL) & ~TS_YP_PIN;
               // Configure the X and Y axis touch layers as outputs.
                   HWREG(TS_P_BASE + GPIO_O_DIR) | TS_XP_PIN | TS_YP_PIN;
                   HWREG(TS_N_BASE + GPIO_O_DIR) | TS_XN_PIN | TS_YN_PIN;
               // Drive the positive side of the Y axis touch layer with VDD and
               // the negative side with GND.  Also, drive both sides of the X
               // axis layer with GND to discharge any residual voltage (so that
               // a no-touch condition can be properly detected).
               HWREG(TS_N_BASE + GPIO_O_DATA + ((TS_XN_PIN | TS_YN_PIN) << 2)) =
                   0;
               HWREG(TS_P_BASE + GPIO_O_DATA + ((TS_XP_PIN | TS_YP_PIN) << 2)) =
                   TS_YP_PIN;
               // Configure the sample sequence to capture the X axis value.
               HWREG(ADC0_BASE + ADC_O_SSMUX3) = ADC_CTL_CH_XP;
               // The next sample will be an invalid Y axis sample.
               g_ulTSState = TS_STATE_SKIP_Y;
               break;
           // The new sample is a Y axis sample that should be discarded.
           case TS_STATE_SKIP_Y:
               // Set the analog mode select for the XP pin.
                   HWREG(TS_P_BASE + GPIO_O_AMSEL) | TS_XP_PIN;
               // Configure the X axis touch layer pins as inputs.
                   HWREG(TS_P_BASE + GPIO_O_DIR) & ~TS_XP_PIN;
                   HWREG(TS_N_BASE + GPIO_O_DIR) & ~TS_XN_PIN;
               // The next sample will be a valid Y axis sample.
               g_ulTSState = TS_STATE_READ_Y;
               break;
           // The new sample is a Y axis sample that should be processed.
           case TS_STATE_READ_Y:
               g_sTouchY = HWREG(ADC0_BASE + ADC_O_SSFIFO3);
               // The next configuration is the same as the initial configuration.
               // Therefore, fall through into the initialization state to avoid
               // duplicating the code.
           // The state machine is in its initial state
           case TS_STATE_INIT:
               // Clear the analog mode select for the XP pin.
                   HWREG(TS_P_BASE + GPIO_O_AMSEL) & ~TS_XP_PIN;
               // Drive one side of the X axis touch layer with VDD and the other
               // with GND.  Also, drive both sides of the Y axis layer with GND
               // to discharge any residual voltage (so that a no-touch condition
               // can be properly detected).
                   TS_XP_PIN;
                   0;
               // Configure the sample sequence to capture the Y axis value.
               HWREG(ADC0_BASE + ADC_O_SSMUX3) = ADC_CTL_CH_YP;
               // If this is the valid Y sample state, then there is a new X/Y
               // sample pair.  In that case, run the touch screen debouncer.
               if(g_ulTSState == TS_STATE_READ_Y)
                   TouchScreenDebouncer();
               // The next sample will be an invalid X axis sample.
               g_ulTSState = TS_STATE_SKIP_X;
               break;
    //! Initializes the touch screen driver.
    //! This function initializes the touch screen driver, beginning the process of
    //! reading from the touch screen.  This driver uses the following hardware
    //! resources:
    //! - ADC sample sequence 3
    //! - Timer 1 subtimer A
    //! \return None.
    void
    TouchScreenInit(void)
       // Set the initial state of the touch screen driver's state machine.
       g_ulTSState = TS_STATE_INIT;
       // There is no touch screen handler initially.
       g_pfnTSHandler = 0;
       // Enable the peripherals used by the touch screen interface.
         SysCtlPeripheralEnable(SYSCTL_PERIPH_ADC0);   //使能ADC0模块功能
       SysCtlPeripheralEnable(TS_P_PERIPH);
       SysCtlPeripheralEnable(TS_N_PERIPH);
       SysCtlPeripheralEnable(SYSCTL_PERIPH_TIMER1);
       // Configure the ADC sample sequence used to read the touch screen reading.
       ADCHardwareOversampleConfigure(ADC0_BASE, 4);
       ADCSequenceConfigure(ADC0_BASE, 3, ADC_TRIGGER_TIMER, 0);                 //配置ADC0,通道19,基准源为控制器产生
       ADCSequenceStepConfigure(ADC0_BASE, 3, 0,
                                ADC_CTL_CH_YP | ADC_CTL_END | ADC_CTL_IE);     //
       ADCSequenceEnable(ADC0_BASE, 3);                                       //ADC采样使能
       // Enable the ADC sample sequence interrupt.
       ADCIntEnable(ADC_BASE, 3);
       IntEnable(INT_ADC3);
       // Configure the GPIOs used to drive the touch screen layers.
       GPIOPinTypeGPIOOutput(TS_P_BASE, TS_XP_PIN | TS_YP_PIN);   //设置PK0,PK3为输出
       GPIOPinTypeGPIOOutput(TS_N_BASE, TS_XN_PIN | TS_YN_PIN);   //设置PK2,PK1为输出
       GPIOPinWrite(TS_P_BASE, TS_XP_PIN | TS_YP_PIN, 0x00);
       GPIOPinWrite(TS_N_BASE, TS_XN_PIN | TS_YN_PIN, 0x00);
       // See if the ADC trigger timer has been configured, and configure it only
       // if it has not been configured yet.
       if((HWREG(TIMER1_BASE + TIMER_O_CTL) & TIMER_CTL_TAEN) == 0)
           // Configure the timer to trigger the sampling of the touch screen
           // every millisecond.
           TimerConfigure(TIMER1_BASE, (TIMER_CFG_16_BIT_PAIR |
                                        TIMER_CFG_A_PERIODIC |
                                        TIMER_CFG_B_PERIODIC));
           TimerLoadSet(TIMER1_BASE, TIMER_A, (SysCtlClockGet() / 1000) - 1);
           TimerControlTrigger(TIMER1_BASE, TIMER_A, true);
           // Enable the timer.  At this point, the touch screen state machine
           // will sample and run once per millisecond.
           TimerEnable(TIMER1_BASE, TIMER_A);
    //! Sets the callback function for touch screen events.
    //! \param pfnCallback is a pointer to the function to be called when touch
    //! screen events occur.
    //! This function sets the address of the function to be called when touch
    //! screen events occur.  The events that are recognized are the screen being
    //! touched (``pen down''), the touch position moving while the screen is
    //! touched (``pen move''), and the screen no longer being touched (``pen
    //! up'').
    //! \return None.
    void
    TouchScreenCallbackSet(long (*pfnCallback)(unsigned long ulMessage, long lX,
                                              long lY))
       // Save the pointer to the callback function.
       g_pfnTSHandler = pfnCallback;
    // Close the Doxygen group.
  • 不知道你的中断和管脚、通道设置正确没。另外记得调用TouchScreenCallbackSet来设置callback以接收touch驱动的事件
