I am designing an audio circuit, the circuit needs to synchronize the external clock, the clock is a professional audio commonly used WordClock (sampling rate is typically 44.1kHz to 192kHz TTL).
For example, WC48kHz, multiplier 256 times to 12.288MHz
What chip or circuit should I choose?
