TPA3223: Single Ended Input Signal Level
Part Number: TPA3223
Hi TI team
   I designed the circuit diagram using TPA3223 as follows:
The gain is set to 32dB through a resistor, and according to the specifications, the input voltage range is 1VRMS. Why does a fault occur when inputting 0.5RMS?
Output no-load voltage waveform:
