Program TI LMK clock chip Sop.pdf
Hello fellow technical experts.
When I was program LMK03318, I found that I could achieve success by following the steps in the attachment. However, I finally found that after the power was turned off, the data was lost, as if it was not saved. Someone has encountered this problem before, but after reading the discussion, I still can’t understand. In addition to connecting the TI dongle, does the board IC need to be short-circuited somewhere?
