ADS1118: ADS1118 Performance: INL Testing
Part Number: ADS1118
Hope this message finds you well.
I am currently working on a project using the ADS1118 and am trying to characterize its static performance, specifically the Integral Nonlinearity (INL). While reviewing the datasheet, I would like to ensure I follow the correct method to obtain accurate and reliable results.
I was wondering if you could kindly share any recommended test procedures, application notes, or best practices from TI for measuring INL on this device. Any guidance on test setup, configuration, or common pitfalls to avoid would be greatly appreciated.
Thank you very much for your support. I look forward to your reply.
