Other Parts Discussed in Thread: ADS8343, ADS8341
看资料没看出个区别
The ADS8343 is a 4-channel, 16-bit sampling Analog-to-Digital (A/D) converter with a synchronous serial interface. Typical power dissipation is 8mW at a 100kHz throughput rate and a +5V supply. The reference voltage (VREF) can be varied between 500mV and VCC/2, providing a corresponding input voltage range of ±VREF. The device includes a shutdown mode which reduces power dissipation to under 15µW. The ADS8343 is ensured down to 2.7V operation.
The ADS8341 is a 4-channel, 16-bit sampling Analog-to-Digital converter (A/D) with a synchronous serial interface. Typical power dissipation is 8mW at a 100kHz throughput rate and a +5V supply. The reference voltage (VREF ) can be varied between 500mV and VCC , providing a corresponding input voltage range of 0V to VREF . The device includes a shutdown mode that reduces power dissipation to under 15µW. The ADS8341 is tested down to 2.7V operation.
ADS8343是真双极性输入?怎么资料是下面红色字体那样写的?如果这里的±VREF是指参考com端的,即com接VREF,然后输入0-2VREF,那为何ADS8341的输入范围不是这样不同样有com端吗?
ABSOLUTE MAXIMUM RATINGS(1)
+VCC to GND ........................................................................ –0.3V to +6V
Analog Inputs to GND ............................................ –0.3V to +VCC + 0.3V
Digital Inputs to GND ........................................................... –0.3V to +6V
Power Dissipation .......................................................................... 250mW
Maximum Junction Temperature ................................................... +150°C
Operating Temperature Range ........................................–40°C to +85°C
Storage Temperature Range .........................................–65°C to +150°C
Lead Temperature (soldering, 10s) ............................................... +300°C
NOTE: (1) Stresses above those listed under “Absolute Maximum Ratings”
may cause permanent damage to the device. Exposure to absolute maximum
conditions for extended periods may affect device reliability.
至于你说的为什么ADS8341也有同样com端为什么不行,这就涉及到芯片内部的设计,不是说有一样的引脚就是有一样的功能。
因为设计不一样,所以Vref的输入要求不一样,模拟输入信号的范围也不一样,这是针对不用的应用场景设计的。
楼主可以仔细阅读下两个手册中的“ANALOG INPUT” “REFERENCE INPUT”就能明白。
Gavin Ye 说:ADS8343是真双极性输入?怎么资料是下面红色字体那样写的?如果这里的±VREF是指参考com端的,即com接VREF,然后输入0-2VREF,那为何ADS8341的输入范围不是这样不同样有com端吗?
