安全错误代码:TI-API-0429
E2E原帖:e2e.ti.com/.../faq-ti-api-security-error-code-ti-api-0429
具体场景 | 错误详情 | 补救步骤 |
速率限制 |
Fullscreen 1 2 3 4 5 6 7 8 9 10 { "errors": [ { "errorCode": "TI-API-0429", "type": "Security", "reason": "Too many requests", "message": "Rate Limit Quota exceeded. Please reduce the rate of requests. If issue persists, please contact support (https://api-portal.ti.com/support)." } ] } XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX { "errors": [ { "errorCode": "TI-API-0429", "type": "Security", "reason": "Too many requests", "message": "Rate Limit Quota exceeded. Please reduce the rate of requests. If issue persists, please contact support (https://api-portal.ti.com/support)." } ] } |
超出了速率限制配额。 请降低请求率。 如果问题仍然存在,请创建一个E2ECHINA帖子(https://e2echina.ti.com/p/addpost?fn=155)来获取客户支持。 |
