[FAQ] TI-API: 积压 ASN API 错误代码和含义
Part Number: TI-API
ASN API错误代码的含义是什么?
E2E原帖:e2e.ti.com/.../ti-api-backlog-asn-api-error-codes-and-meanings
  •         具体场景
    错误详情
    补救步骤
    缺少标识符
    Fullscreen
    1
    2
    3
    4
    5
    6
    7
    8
    "Errors": [
    "Code": "TI-ASN-40010",
    "Message": "Provide one of the following - Purchase Order, Way Bill or Supplier Order number"
    XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
    客户应在请求中传递至少一个有效的CustomerPurchaseOrderIdentifier或 SupplierWayIdentifier 或 SupplierOrderIdentifier。
    只需一个标识符
    Fullscreen
    1
    2
    3
    4
    5
    6
    7
    8
    "Errors": [
    "Code": "TI-ASN-40020",
    "Message": "Only one of the following can be provided - Purchase Order, Way Bill or Supplier Order number"
    客户应在请求中仅递交一个CustomerPurchaseOrderIdentifier或 SupplierWayBillIdentifier 或 SupplierOrderIdentifier。
    Sold-to号码无效或缺失
    Fullscreen
    1
    2
    3
    4
    5
    6
    7
    8
    "Errors": [
    "Code": "TI-ASN-40030",
    "Message": "The sold-to number is invalid or missing. Provide a valid sold-to number."
    客户应在请求中递交有效的 CustomerSoldToIdentifier。
    PDF 字段值无效
    Fullscreen
    1
    2
    3
    4
    5
    6
    7
    8
    "Errors": [
    "Code": "TI-ASN-40040",
    "Message": "The RequestCommercialInvoicePDF and RequestWaybillPDF fields can only be 'X' or blank. Correct and resubmit. Note: 'X' means to request .pdfs"
    客户应在请求中递交有效的 RequestCommercialInvoicePDF 和 RequestWaybillPDF。 如果您想要接收 PDF,则应在相应字段中递交X,否则字段应留空。
    正在进行服务器维护
    Fullscreen
    1
    2
    3
    4
    5
    6
    7
    8
    "Errors": [
    "Code": "TI-ASN-50000",
    "Message": "TI server maintenance in progress. Contact TI API Support (https://api-portal.ti.com/support) support for more information."
    TI 服务器正在进行维护。 如需更多信息,请联系 TI API 支持  (https://api-portal.ti.com/support)。
    未找到发货数据
    Fullscreen
    1
    2
    3
    4
    5
    6
    7
    8
    "Errors": [
    "Code": "TI-ASN-40410",
    "Message": "Verify and correct the Purchase order OR use the Supplier Order number or WayBill number. Otherwise, there is no shipment data."
    客户应递交有效的 CustomerPurchaseOrderIdentifier,并检查 CustomerPurchaseOrderIdentifier 的状态。 只有已完成的订单才有可用的发货数据。
    未找到发货数据
    Fullscreen
    1
    2
    3
    4
    5
    6
    7
    8
    "Errors": [
    "Code": "TI-ASN-40420",
    "Message": "Verify and correct the Supplier order number OR use your Purchase Order or the Supplier WayBill number. Otherwise, there is no shipment data."
    客户应递交有效的SupplierOrderIdentifier,并检查SupplierOrderIdentifier 的状态。 只有已完成的订单才有可用的发货数据。
    未找到发货数据
    Fullscreen
    1
    2
    3
    4
    5
    6
    7
    8
    "Errors": [
    "Code": "TI-ASN-40430",
    "Message": "Verify and correct the WayBill number OR use your Purchase Order or the Supplier Order number. Otherwise, there is no shipment data."
    客户应递交有效的 SupplierWayBillIdentifier,并检查 SupplierWayBillIdentifier 的状态。 只有已完成的订单才有可用的发货数据。
    标识符无效
    Fullscreen
    1
    2
    3
    4
    5
    6
    7
    8
    "Errors": [
    "Code": "TI-ASN-40440",
    "Message": "Verify and correct the sold-to identifier."
    验证并更正sold-to标识符。
    缺少业务合作伙伴的Sold-to号码
    Fullscreen
    1
    2
    3
    4
    5
    6
    7
    8
    "Errors": [
    "Code": "TI-ASN-40450",
    "Message": "Provide the Business Partner's sold-to identifier."
    请提供业务合作伙伴的sold-to标识符。
    缺少业务合作伙伴
    Fullscreen
    1
    2
    3
    4
    5
    6
    7
    8
    "Errors": [
    "Code": "TI-ASN-40460",
    "Message": "Business Partner is required"
    业务合作伙伴不能为空。 请提供并重新提交。
