[FAQ] TI-API: 积压汇款建议 API 错误代码和含义
Part Number: TI-API
积压汇款建议 API 错误代码的含义是什么?
E2E原帖:e2e.ti.com/.../faq-ti-api-backlog-remittance-advice-api-error-codes-and-meanings
  • 具体场景 错误详情 补救步骤
    无效的JSON 有效载荷
    Fullscreen
    1
    2
    3
    4
    5
    6
    7
    8
    9
    "errors": [
    "Code": "TI-RMA-40002",
    "Type": "ERROR",
    "Message": "Invalid JSON input. Pass a valid json input."
    XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
    请递交有效的 json 输入。
    JSON 有效载荷为空
    Fullscreen
    1
    2
    3
    4
    5
    6
    7
    8
    9
    "errors": [
    "Code": "TI-RMA-40016",
    "Type": "ERROR",
    "Message": "JSON payload cannot be blank. Resubmit request with a valid payload."
    请使用有效载荷重新提交请求。
    缺失CustomerGlobalIdentifier
    Fullscreen
    1
    2
    3
    4
    5
    6
    7
    8
    9
    "errors": [
    "Code": "TI-RMA-40010",
    "Type": "ERROR",
    "Message": "CustomerGlobalIdentifier is required. Contact TI API Support (https://api-portal.ti.com/support)."
    请联系TI API支持 (api-portal.ti.com/support).
    缺失CustomerRemittanceAdviceIdentifier
    Fullscreen
    1
    2
    3
    4
    5
    6
    7
    8
    9
    "errors": [
    "Code": "TI-RMA-40020",
    "Type": "ERROR",
    "Message": "Provide CustomerRemittanceAdviceIdentifier and resubmit the request."
    请提供 CustomerRemitanceAdviseIdentifier 并重新提交请求。
    CustomerRemitanceAdviseIdentifier 的长度超过35个字符
    Fullscreen
    1
    2
    3
    4
    5
    6
    7
    8
    9
    "errors": [
    "Code": "TI-RMA-40030",
    "Type": "ERROR",
    "Message": "CustomerRemittanceAdviceIdentifier cannot exceed 35 characters in length. cannot exceed 35 characters. Check CustomerRemittanceAdviceIdentifier and resubmit the request."
    请检查 CustomerRemitanceAdviseIdentifier 并重新提交请求。
    缺失CustomerPayerIdentifier
    Fullscreen
    1
    2
    3
    4
    5
    6
    7
    8
    9
    "errors": [
    "Code": "TI-RMA-40040",
    "Type": "ERROR",
    "Message": "Provide CustomerPayerIdentifier and resubmit the request."
    请提供 CustomerPayerIdentifier并重新提交请求。
    Fullscreen
    1
    2
    3
    4
    5
    6
    7
    8
    9
    "errors": [
    "Code": "TI-RMA-40050",
    "Type": "ERROR",
    "Message": "CustomerPayerIdentifier cannot exceed 35 characters. Check CustomerPayerIdentifier and resubmit the request."
    请检查 CustomerPayerIdentifier 并重新提交请求。
    无法找到CustomerPayerIdentifier
    Fullscreen
    1
    2
    3
    4
    5
    6
    7
    8
    9
    "errors": [
    "Code": "TI-RMA-40054",
    "Type": "ERROR",
    "Message": "CustomerPayerIdentifier cannot be found. Check CustomerPayerIdentifier and resubmit the request."
    缺失CustomerPaymentAmount
    Fullscreen
    1
    2
    3
    4
    5
    6
    7
    8
    9
    "errors": [
    "Code": "TI-RMA-40060",
    "Type": "ERROR",
    "Message": "Provide CustomerPaymentAmount and resubmit the request."
    请提供 CustomerPaymentAmount 并重新提交请求。
    CustomerPaymentAmount 超过15个字符
    Fullscreen
    1
    2
    3
    4
    5
    6
    7
    8
    9
    "errors": [
    "Code": "TI-RMA-40070",
    "Type": "ERROR",
    "Message": "CustomerPaymentAmount cannot exceed 15 characters. Check CustomerPaymentAmount and resubmit the request."
    请检查CustomerPaymentAmount 并重新提交请求。
    CustomerPaymentAmount为无效的数字格式
    Fullscreen
    1
    2
    3
    4
    5
    6
    7
    8
    9
    "errors": [
    "Code": "TI-RMA-40080",
    "Type": "ERROR",
    "Message": "CustomerPaymentAmount must be a number. Check CustomerPaymentAmount and resubmit the request."
    请检查CustomerPaymentAmount并重新提交请求。
    缺失CustomerCurrency
    Fullscreen
    1
    2
    3
    4
    5
    6
    7
    8
    9
    "errors": [
    "Code": "TI-RMA-40090",
    "Type": "ERROR",
    "Message": "Provide CustomerCurrency and resubmit the request."
    请提供CustomerCurrency并重新提交请求。
    CustomerCurrency长度超过5个字符
    Fullscreen
    1
    2
    3
    4
    5
    6
    7
    8
    9
    "errors": [
    "Code": "TI-RMA-40100",
    "Type": "ERROR",
    "Message": "CustomerCurrency cannot exceed 5 characters in length. Check CustomerCurrency and resubmit the request."
    请检查CustomerCurrency并重新提交请求。
    缺失CustomerNetPaymentAmount
    Fullscreen
    1
    2
    3
    4
    5
    6
    7
    8
    9
    "errors": [
    "Code": "TI-RMA-40110",
    "Type": "ERROR",
    "Message": "Provide CustomerNetPaymentAmount and resubmit the request."
    请提供CustomerNetPaymentAmount并重新提交请求。
    CustomerNetPaymentAmount长度超过15个字符
    Fullscreen
    1
    2
    3
    4
    5
    6
    7
    8
    9
    "errors": [
    "Code": "TI-RMA-40120",
    "Type": "ERROR",
    "Message": "CustomerNetPaymentAmount cannot exceed 15 characters in length. Check CustomerNetPaymentAmount and resubmit the request."
    请检查CustomerNetPaymentAmount并重新提交请求。
    CustomerNetPaymentAmount为无效的数字格式
    Fullscreen
    1
    2
    3
    4
    5
    6
    7
    8
    9
    "errors": [
    "Code": "TI-RMA-40130",
    "Type": "ERROR",
    "Message": "CustomerNetPaymentAmount must be a number. Check CustomerNetPaymentAmount and resubmit the request."
    缺失SupplierFinancialDocumentIdentifier 和 CustomerFinancialDocumentIdentifier
    Fullscreen
    1
    2
    3
    4
    5
    6
    7
    8
    9
    "errors": [
    "Code": "TI-RMA-40140",
    "Type": "ERROR",
    "Message": "Provide either SupplierFinancialDocumentIdentifier or CustomerFinancialDocumentIdentifier and resubmit the request."
    请提供SupplierFinancialDocumentIdentifier或CustomerFinancialDocumentIdentifier并重新提交请求。
    SupplierFinancialDocumentIdentifier超过10个字符
    Fullscreen
    1
    2
    3
    4
    5
    6
    7
    8
    9
    "errors": [
    "Code": "TI-RMA-40150",
    "Type": "ERROR",
    "Message": "SupplierFinancialDocumentIdentifier cannot exceed 10 characters. Check SupplierFinancialDocumentIdentifier and resubmit the request."
    请检查 SupplierFinancialDocumentIdentifier 并重新提交请求。
    CustomerFinancialDocumentIdentifier长度超过16个字符
    Fullscreen
    1
    2
    3
    4
    5
    6
    7
    8
    9
    "errors": [
    "Code": "TI-RMA-40160",
    "Type": "ERROR",
    "Message": "CustomerFinancialDocumentIdentifier cannot exceed 16 characters in length. Check CustomerFinancialDocumentIdentifier and resubmit the request."
    请检查 CustomerFinancialDocumentIdentifier 并重新提交请求。
    发生系统错误
    Fullscreen
    1
    2
    3
    4
    5
    6
    7
    8
    9
    "errors": [
    "Code": "TI-RMA-50000",
    "Type": "ERROR",
    "Message": "System error occurred. Execution ID: execution-... Contact TI API Support (https://api-portal.ti.com/support) with execution ID."
    请使用执行ID联系TI API 支持 (api-portal.ti.com/support)
    按计划维护中,API不可用
    Fullscreen
    1
    2
    3
    4
    5
    6
    7
    8
    9
    "errors": [
    "Code": "TI-RMA-51000",
    "Type": "ERROR",
    "Message": "This API is currently unavailable between ... and ... Retry at a later time."
    请稍后再试。
    访问令牌无效
    Fullscreen
    1
    2
    3
    4
    5
    6
    7
    8
    9
    "errors": [
    "Code": "TI-API-00421",
    "Type": "ERROR",
    "Message": "Invalid Access Token. Check for invalid credentials."
    请检查无效凭据。
    访问令牌已过期
    Fullscreen
    1
    2
    3
    4
    5
    6
    7
    8
    9
    "errors": [
    "Code": "TI-API-00453",
    "Type": "ERROR",
    "Message": "Your Access Token has Expired. Please refresh your token. Check for expired OAuth token."
    请刷新您的 OAuth 令牌。
    未找到请求的 API 端点
    Fullscreen
    1
    2
    3
    4
    5
    6
    7
    8
    9
    "errors": [
    "Code": "TI-API-00221",
    "Type": "ERROR",
    "Message": "No API Endpoint Found. Check API endpoint URL and HTTP method or contact (https://api-portal.ti.com/support)."
    请检查 API 端点 URL 和 HTTP 方法或联系 (api-portal.ti.com/support).
    API 暂不可用
    Fullscreen
    1
    2
    3
    4
    5
    6
    7
    8
    9
    "errors": [
    "Code": "TI-API-00556 ",
    "Type": "ERROR",
    "Message": "This service is temporarily unavailable. Contact (https://api-portal.ti.com/support)."
    请联系 (api-portal.ti.com/support).
    缺少付款人帐号
    Fullscreen
    1
    2
    3
    4
    5
    6
    7
    8
    9
    "errors": [
    "Code": "TI-TXT-001",
    "Type": "ERROR",
    "Message": "Payer account number is missing"
    请递交有效的 CustomerPayerIdentifier .
    付款人帐号无效
    Fullscreen
    1
    2
    3
    4
    5
    6
    7
    8
    9
    "errors": [
    "Code": "TI-TXT-002",
    "Type": "ERROR",
    "Message": "Payer account number is not valid"
    请递交有效的 CustomerPayerIdentifier。 如果问题仍然存在,请联系 TI API 支持  (api-portal.ti.com/support).
    付款金额缺失
    Fullscreen
    1
    2
    3
    4
    5
    6
    7
    8
    9
    "errors": [
    "Code": "TI-TXT-003",
    "Type": "ERROR",
    "Message": "Payment amount is missing"
    请递交有效的 CustomerPaymentAmount。
    发票缺少付款金额
    Fullscreen
    1
    2
    3
    4
    5
    6
    7
    8
    9
    "errors": [
    "Code": "TI-TXT-004",
    "Type": "ERROR",
    "Message": "Payment amount missing for Invoice"
    请递交有效的 CustomerNetPaymentAmount。
    发票编号缺失
    Fullscreen
    1
    2
    3
    4
    5
    6
    7
    8
    9
    "errors": [
    "Code": "TI-TXT-006",
    "Type": "ERROR",
    "Message": "Invoice numbers are missing"
    请递交有效的 SupplierFinancialDocumentIdentifier.
    发票编号无效
    Fullscreen
    1
    2
    3
    4
    5
    6
    7
    8
    9
    "errors": [
    "Code": "TI-TXT-007",
    "Type": "ERROR",
    "Message": "Invoice numbers are not valid"
    请递交一系列有效的 SupplierFinancialDocumentIdentifier。
    发票编号无效
    Fullscreen
    1
    2
    3
    4
    5
    6
    7
    8
    9
    "errors": [
    "Code": "TI-TXT-008009",
    "Type": "ERROR",
    "Message": "Invoice number is not valid"
    请递交有效的 SupplierFinancialDocumentIdentifier。
    缺少参考编号
    Fullscreen
    1
    2
    3
    4
    5
    6
    7
    8
    9
    "errors": [
    "Code": "TI-TXT-010",
    "Type": "ERROR",
    "Message": "Reference Number is missing"
    请递交有效的 CustomerRemittanceAdviceIdentifier。
    更改付款通知时出错
    Fullscreen
    1
    2
    3
    4
    5
    6
    7
    8
    9
    "errors": [
    "Code": "TI-TXT-011",
    "Type": "ERROR",
    "Message": "Error changing payment advice"
    请联系TI API 支持 (api-portal.ti.com/support).
    汇款通知已发布
    Fullscreen
    1
    2
    3
    4
    5
    6
    7
    8
    9
    "errors": [
    "Code": "TI-TXT-012013",
    "Type": "ERROR",
    "Message": "Remittance Advice posted"
    仅供参考。 无需采取任何措施。
    无权创建汇款建议
    Fullscreen
    1
    2
    3
    4
    5
    6
    7
    8
    9
    "errors": [
    "Code": "TI-TXT-014",
    "Type": "ERROR",
    "Message": "Not authorized to create Remittance Advice"
    请递交有效的 CustomerPayerIdentifier。 如问题仍然存在,请联系 TI API 支持  (api-portal.ti.com/support)
