TI-API: TI STORE API SUITE :我提交的申请下单的api,一直处于pending状态,要怎么解决呢?
Part Number: TI-API
我提交的申请下单的api,一直处于pending状态,要怎么解决呢?是需要什么审核条件的吗?
  • Due to high volume of API access request, there is a slight delay for the approval process at this time. In the meantime, please continue to check out using TI.com method until eligibility expands. Alternately, you can contact your local sales representative for escalation.
  • 你好,我的账号申请已经2周了,还没给结果。
  • 由于API访问请求量大,此时审批流程略有延迟。请继续使用 TI.com 方法进行结帐, 或者您可以联系当地的销售代表进行询问,谢谢。
