Part Number: TI-API
客户创建PO#22110-2306280004,POI#3, 填写了错误的TI物料,订单回复文件中只显示TI-TXT-270 ERROR CODE, Message栏位空白。复查TI SAP数据有显示
Reason tiPartNumber &1 has invalid status to order。 请查询未推送TI-TXT-270 具体报错message的原因。
Part Number: TI-API
Hi Hazel,
There is a process of re-vamping error messages for the July release and this might be the reason which not showing error details. Meantime i could check with team if this TI-TXT-270 type error is expected to see in SI4, you may also check below internal thread link which is for another similar case due to re-vamping.
