Hello Team,
Would you please provide PUSH data for FOX-ESS? ASN & Financial Invoice were retriggered on 3/4/2024. Thank you.
Hi Hazel,
I saw below error returned when system try to push INVOICE message, seems like SSL issue on customer side. Would you please ask customer PUSH related setup FAQ and recheck their setups? Thanks.
e2echina.ti.com/.../faq-push-api
"FinancialDocumentNumber" : "5497430102",
"CustomerAPIResponseDateTime" : "2024-03-01 12:22:23",
"CustomerAPIResponseStatus" : "FAIL",
"CustomerAPIResponseMessage" : "javax.net.ssl.SSLException: Received fatal alert: protocol_version",
"CustomerAPIResponseContent" : "[Function: Call Customer API, Scripting]: Error executing custom script: Received fatal alert: protocol_version (in groovy2 script); Caused by: Received fatal alert: protocol_version (in groovy2 script); Caused by: Received fatal alert: protocol_version"
Hi Lecheng,
We've updated the certificate. Could you help to resend the push data? Thanks.
Waybill#424785391 & financial invoice#5497429911 retriggered at CN time 3:14PM, thank you.
Hi Amelie,
I saw there is still same error, are you able to receive PUSH request from TI endpoint?
I've retriggered ASN, please check, thanks.
We've received the ASN data. Thanks.
