Part Number: SN74HCT574
Customer test NXP's 74HCT574PW, 118 and TI's SN74HCT574PW and found that the initial output level of power-on is not the same as that of power-on, everything is normal
The customer connects the OE pin to ground, the output Q level is high at the initial moment of power-up, and the output level becomes low after the program is initialized, how can the output be guaranteed to be low at the initial moment?
What is different between OUTPUT Q0 & Z? The customer connects the OE pin to ground, the output Q level is high at the initial moment of power-up, and the output level becomes low after the program is initialized, how can the output be guaranteed to be low at the initial moment? (can't add pull-down resistor)
