Part Number: SN74HC4060
The period of the waveform output at the DQ signal terminal is not 16 times that of the CLKO terminal.The RC parameters are as follows:R1=56KΩ,R2=240KΩ,C=3400pF.The supply voltage is 5.3V.
Can you share a scope shot please, of two of the signal terminals and the clock signal?
