[参考译文] TMS570LC4357:我们要求在 CAN 节点中配置最大数量的邮箱、以支持应用要求
Guru**** 2914580 points
Other Parts Discussed in Thread: TMS570LC4357
https://e2e.ti.com/support/microcontrollers/arm-based-microcontrollers-group/arm-based-microcontrollers/f/arm-based-microcontrollers-forum/1609263/tms570lc4357-we-require-the-maximum-number-of-mailboxes-to-be-configured-in-the-can-node-to-support-the-application-requirements
器件型号: TMS570LC4357
TMS570LC4357 控制器 CAN 节点仅拥有 64 个邮箱、但我们需要超过 100 个邮箱。 您能分享另一个合适的器件型号吗?
