[参考译文] TM4C1290NCZAD:tm4c129xnczad
Guru**** 2988540 points
Other Parts Discussed in Thread: TM4C1290NCZAD
https://e2e.ti.com/support/microcontrollers/arm-based-microcontrollers-group/arm-based-microcontrollers/f/arm-based-microcontrollers-forum/1031094/tm4c1290nczad-tm4c129xnczad
器件型号:TM4C1290NCZAD
主题中讨论的其他器件: DK-TM4C129X
我正在尝试使用 TM4C1290NCZAD 使 UART_Echo 程序在我们的电路板上正常工作。
我从 TI 获得了 UART0的代码。
但我使用的是 UART5。 但它不起作用。
是否有适用于 TM4C1290的任何其他 UART 代码?
km
    您好 Kiran、
    我想它只是初始化方面的一个小错误、它会一直发生、甚至对我们来说。 您能否发布 UART 代码以便我可以查看它?
    https://e2e.ti.com/support/site-support-group/site-support/f/site-support-forum/812271/faq-how-do-i-add-a-code-snippet-to-my-post
    Ralph Jacobi
    // uart_echo.c - Example for reading data from and writing data to the UART in
    //               an interrupt driven fashion.
    // Copyright (c) 2013-2017 Texas Instruments Incorporated.  All rights reserved.
    // Software License Agreement
    // Texas Instruments (TI) is supplying this software for use solely and
    // exclusively on TI's microcontroller products. The software is owned by
    // TI and/or its suppliers, and is protected under applicable copyright
    // laws. You may not combine this software with "viral" open-source
    // software in order to form a larger program.
    // THIS SOFTWARE IS PROVIDED "AS IS" AND WITH ALL FAULTS.
    // NO WARRANTIES, WHETHER EXPRESS, IMPLIED OR STATUTORY, INCLUDING, BUT
    // NOT LIMITED TO, IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
    // A PARTICULAR PURPOSE APPLY TO THIS SOFTWARE. TI SHALL NOT, UNDER ANY
    // CIRCUMSTANCES, BE LIABLE FOR SPECIAL, INCIDENTAL, OR CONSEQUENTIAL
    // DAMAGES, FOR ANY REASON WHATSOEVER.
    // This is part of revision 2.1.4.178 of the DK-TM4C129X Firmware Package.
    #include <stdint.h>
    #include <stdbool.h>
    #include "inc/hw_ints.h"
    #include "inc/hw_memmap.h"
    #include "inc/hw_types.h"
    #include "driverlib/debug.h"
    #include "driverlib/gpio.h"
    #include "driverlib/interrupt.h"
    #include "driverlib/sysctl.h"
    #include "driverlib/uart.h"
    #include "driverlib/rom.h"
    #include "driverlib/rom_map.h"
    #include "grlib/grlib.h"
    #include "drivers/kentec320x240x16_ssd2119.h"
    #include "drivers/frame.h"
    #include "drivers/pinout.h"
    //! \addtogroup example_list
    //! <h1>UART Echo (uart_echo)</h1>
    //! This example application utilizes the UART to echo text.  The first UART
    //! (connected to the FTDI virtual serial port on the evaluation board) will be
    //! configured in 115,200 baud, 8-n-1 mode.  All characters received on the
    //! UART are transmitted back to the UART.
    // The error routine that is called if the driver library encounters an error.
    #ifdef DEBUG
    void
    __error__(char *pcFilename, uint32_t ui32Line)
    #endif
    // The UART interrupt handler.
    void
    UARTIntHandler(void)
        uint32_t ui32Status;
        // Get the interrrupt status.
        ui32Status = ROM_UARTIntStatus(UART5_BASE, true);
        // Clear the asserted interrupts.
        ROM_UARTIntClear(UART5_BASE, ui32Status);
        // Loop while there are characters in the receive FIFO.
        while(ROM_UARTCharsAvail(UART5_BASE))
            // Read the next character from the UART and write it back to the UART.
            ROM_UARTCharPutNonBlocking(UART5_BASE,
                                       UARTCharGetNonBlocking(UART5_BASE));
    // Send a string to the UART.
    void
    UARTSend(const uint8_t *pui8Buffer, uint32_t ui32Count)
        // Loop while there are more characters to send.
        while(ui32Count--)
            // Write the next character to the UART.
            ROM_UARTCharPutNonBlocking(UART5_BASE, *pui8Buffer++);
    // This example demonstrates how to send a string of data to the UART.
    int
    main(void)
        uint32_t ui32SysClock;
        tContext sContext;
        // Run from the PLL at 120 MHz.
       ui32SysClock = MAP_SysCtlClockFreqSet((SYSCTL_XTAL_25MHZ |
                                               SYSCTL_OSC_MAIN | SYSCTL_USE_PLL |
                                               SYSCTL_CFG_VCO_480), 120000000);
        // Configure the device pins.
        PinoutSet();
        // Initialize the display driver.
        Kentec320x240x16_SSD2119Init(ui32SysClock);
        // Initialize the graphics context.
        GrContextInit(&sContext, &g_sKentec320x240x16_SSD2119);
        // Draw the application frame.
        FrameDraw(&sContext, "uart-echo");
        // Display UART configuration on the display.
        GrStringDraw(&sContext, "Port:",       -1,  70, 70, 0);
        GrStringDraw(&sContext, "Baud:",       -1,  70, 95, 0);
        GrStringDraw(&sContext, "Data:",       -1,  70, 120, 0);
        GrStringDraw(&sContext, "Parity:",     -1,  70, 145, 0);
        GrStringDraw(&sContext, "Stop:",       -1,  70, 170, 0);
        GrStringDraw(&sContext, "Uart 5",      -1, 150, 70, 0);
        GrStringDraw(&sContext, "115,200 bps", -1, 150, 95, 0);
        GrStringDraw(&sContext, "8 Bit",       -1, 150, 120, 0);
        GrStringDraw(&sContext, "None",        -1, 150, 145, 0);
        GrStringDraw(&sContext, "1 Bit",       -1, 150, 170, 0);
        // Enable the (non-GPIO) peripherals used by this example.  PinoutSet()
        // already enabled GPIO Port A.
        ROM_SysCtlPeripheralEnable(SYSCTL_PERIPH_UART5);
        // Enable processor interrupts.
        IntMasterEnable();
        // Configure the UART for 115,200, 8-N-1 operation.
        ROM_UARTConfigSetExpClk(UART5_BASE, ui32SysClock, 115200,
                                (UART_CONFIG_WLEN_8 | UART_CONFIG_STOP_ONE |
                                 UART_CONFIG_PAR_NONE));
        // Enable the UART interrupt.
        ROM_IntEnable(INT_UART5);
        ROM_UARTIntEnable(UART5_BASE, UART_INT_RX | UART_INT_RT);
        // Prompt for text to be entered.
        UARTSend((uint8_t *)"Enter text: ", 12);
        // Loop forever echoing data through the UART.
        while(1)
    // pinout.c - Function to configure the device pins on the DK-TM4C129X.
    #include <stdint.h>
    #include "inc/hw_gpio.h"
    #include "driverlib/pin_map.h"
    //! \addtogroup pinout_api
    //! Configures the device pins for the standard usages on the DK-TM4C129X.
    //! This function enables the GPIO modules and configures the device pins for
    //! the default, standard usages on the DK-TM4C129X.  Applications that require
    //! alternate configurations of the device pins can either not call this
    //! function and take full responsibility for configuring all the device pins,
    //! or can reconfigure the required device pins after calling this function.
    //! \return None.
    void
    PinoutSet(void)
        // Enable all the GPIO peripherals.
        ROM_SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOA);
        ROM_SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOB);
        ROM_SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOC);
        ROM_SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOD);
        ROM_SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOE);
        ROM_SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOF);
        ROM_SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOG);
        ROM_SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOH);
        ROM_SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOJ);
        ROM_SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOK);
        ROM_SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOL);
        ROM_SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOM);
        ROM_SysCtlPeripheralEnable(SYSCTL_PERIPH_GPION);
        ROM_SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOP);
        ROM_SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOQ);
        ROM_SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOR);
        ROM_SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOS);
        ROM_SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOT);
        // PA0-1 are used for UART0.
     //   ROM_GPIOPinConfigure(GPIO_PA0_U0RX);
     //   ROM_GPIOPinConfigure(GPIO_PA1_U0TX);
     //   ROM_GPIOPinTypeUART(GPIO_PORTA_BASE, GPIO_PIN_0 | GPIO_PIN_1);
        // PC6/PH7 are used for UART5.
        ROM_GPIOPinConfigure(GPIO_PC6_U5RX);
        ROM_GPIOPinConfigure(GPIO_PH7_U5TX);
        ROM_GPIOPinTypeUART(GPIO_PORTC_BASE, GPIO_PIN_6);
        ROM_GPIOPinTypeUART(GPIO_PORTH_BASE, GPIO_PIN_7);
        // PA2-5 are used for SSI0 to the second booster pack.
        ROM_GPIOPinConfigure(GPIO_PA2_SSI0CLK);
        ROM_GPIOPinConfigure(GPIO_PA3_SSI0FSS);
        ROM_GPIOPinConfigure(GPIO_PA4_SSI0XDAT0);
        ROM_GPIOPinConfigure(GPIO_PA5_SSI0XDAT1);
        // PB0-1/PD6-7/PL6-7 are used for USB.
        HWREG(GPIO_PORTD_BASE + GPIO_O_LOCK) = GPIO_LOCK_KEY;
        HWREG(GPIO_PORTD_BASE + GPIO_O_CR) = 0xff;
        ROM_GPIOPinConfigure(GPIO_PD6_USB0EPEN);
        ROM_GPIOPinConfigure(GPIO_PD7_USB0PFLT);
        ROM_GPIOPinTypeUSBAnalog(GPIO_PORTB_BASE, GPIO_PIN_0 | GPIO_PIN_1);
        ROM_GPIOPinTypeUSBDigital(GPIO_PORTD_BASE, GPIO_PIN_6 | GPIO_PIN_7);
        ROM_GPIOPinTypeUSBAnalog(GPIO_PORTL_BASE, GPIO_PIN_6 | GPIO_PIN_7);
        // PB2/PD4 are used for the speaker output.
        ROM_GPIOPinConfigure(GPIO_PB2_T5CCP0);
        ROM_GPIOPinTypeTimer(GPIO_PORTB_BASE, GPIO_PIN_2);
        ROM_GPIOPinTypeGPIOOutput(GPIO_PORTD_BASE, GPIO_PIN_4);
        ROM_GPIOPinWrite(GPIO_PORTD_BASE, GPIO_PIN_4, 0);
        // PB6-7 are used for I2C to the TMP100 and the EM connector.
        ROM_GPIOPinConfigure(GPIO_PB6_I2C6SCL);
        ROM_GPIOPinConfigure(GPIO_PB7_I2C6SDA);
        ROM_GPIOPinTypeI2CSCL(GPIO_PORTB_BASE, GPIO_PIN_6);
        ROM_GPIOPinTypeI2C(GPIO_PORTB_BASE, GPIO_PIN_7);
        // PE5/PN3/PP1 are used for the push buttons.
        ROM_GPIOPinTypeGPIOInput(GPIO_PORTE_BASE, GPIO_PIN_5);
        ROM_GPIOPinTypeGPIOInput(GPIO_PORTN_BASE, GPIO_PIN_3);
        ROM_GPIOPinTypeGPIOInput(GPIO_PORTP_BASE, GPIO_PIN_1);
        // PE7/PP7/PT2-3 are used for the touch screen.
        HWREG(GPIO_PORTE_BASE + GPIO_O_LOCK) = GPIO_LOCK_KEY;
        HWREG(GPIO_PORTE_BASE + GPIO_O_CR) = 0xff;
        ROM_GPIOPinTypeGPIOInput(GPIO_PORTE_BASE, GPIO_PIN_7);
        ROM_GPIOPinTypeGPIOInput(GPIO_PORTP_BASE, GPIO_PIN_7);
        ROM_GPIOPinTypeGPIOInput(GPIO_PORTT_BASE, GPIO_PIN_2 | GPIO_PIN_3);
        ROM_GPIOPinTypeGPIOOutput(GPIO_PORTE_BASE, GPIO_PIN_7);
        ROM_GPIOPinWrite(GPIO_PORTE_BASE, GPIO_PIN_7, 0);
        ROM_GPIOPinTypeGPIOOutput(GPIO_PORTP_BASE, GPIO_PIN_7);
        ROM_GPIOPinWrite(GPIO_PORTP_BASE, GPIO_PIN_7, 0);
        ROM_GPIOPinTypeGPIOOutput(GPIO_PORTT_BASE, GPIO_PIN_2 | GPIO_PIN_3);
        ROM_GPIOPinWrite(GPIO_PORTT_BASE, GPIO_PIN_2 | GPIO_PIN_3, 0);
        // PF0/PF4-5/PH4/PQ0-2 are used for the SPI flash (on-board and SD card).
        // PH4 selects the SD card and PQ1 selects the on-board SPI flash.
        ROM_GPIOPinConfigure(GPIO_PF0_SSI3XDAT1);
        ROM_GPIOPinConfigure(GPIO_PF4_SSI3XDAT2);
        ROM_GPIOPinConfigure(GPIO_PF5_SSI3XDAT3);
        ROM_GPIOPinConfigure(GPIO_PQ0_SSI3CLK);
        ROM_GPIOPinConfigure(GPIO_PQ2_SSI3XDAT0);
        ROM_GPIOPinTypeSSI(GPIO_PORTF_BASE, GPIO_PIN_0 | GPIO_PIN_4 | GPIO_PIN_5);
        ROM_GPIOPinTypeGPIOOutput(GPIO_PORTH_BASE, GPIO_PIN_4);
        ROM_GPIOPinWrite(GPIO_PORTH_BASE, GPIO_PIN_4, GPIO_PIN_4);
        ROM_GPIOPinTypeSSI(GPIO_PORTQ_BASE, GPIO_PIN_0 | GPIO_PIN_2);
        ROM_GPIOPinTypeGPIOOutput(GPIO_PORTQ_BASE, GPIO_PIN_1);
        ROM_GPIOPinWrite(GPIO_PORTQ_BASE, GPIO_PIN_1, GPIO_PIN_1);
        // PF1/PK4/PK6 are used for Ethernet LEDs.
        ROM_GPIOPinConfigure(GPIO_PF1_EN0LED2);
        ROM_GPIOPinConfigure(GPIO_PK4_EN0LED0);
        ROM_GPIOPinConfigure(GPIO_PK6_EN0LED1);
        GPIOPinTypeEthernetLED(GPIO_PORTF_BASE, GPIO_PIN_1);
        GPIOPinTypeEthernetLED(GPIO_PORTK_BASE, GPIO_PIN_4);
        GPIOPinTypeEthernetLED(GPIO_PORTK_BASE, GPIO_PIN_6);
        // PF6-7/PJ6/PS4-5/PR0-7 are used for the LCD.
        ROM_GPIOPinConfigure(GPIO_PF7_LCDDATA02);
        ROM_GPIOPinConfigure(GPIO_PJ6_LCDAC);
        ROM_GPIOPinConfigure(GPIO_PR0_LCDCP);
        ROM_GPIOPinConfigure(GPIO_PR1_LCDFP);
        ROM_GPIOPinConfigure(GPIO_PR2_LCDLP);
        ROM_GPIOPinConfigure(GPIO_PR3_LCDDATA03);
        ROM_GPIOPinConfigure(GPIO_PR4_LCDDATA00);
        ROM_GPIOPinConfigure(GPIO_PR5_LCDDATA01);
        ROM_GPIOPinConfigure(GPIO_PR6_LCDDATA04);
        ROM_GPIOPinConfigure(GPIO_PR7_LCDDATA05);
        ROM_GPIOPinConfigure(GPIO_PS4_LCDDATA06);
        ROM_GPIOPinConfigure(GPIO_PS5_LCDDATA07);
        ROM_GPIOPinTypeGPIOOutput(GPIO_PORTF_BASE, GPIO_PIN_6);
        ROM_GPIOPinWrite(GPIO_PORTF_BASE, GPIO_PIN_6, GPIO_PIN_6);
        GPIOPinTypeLCD(GPIO_PORTF_BASE, GPIO_PIN_7);
        GPIOPinTypeLCD(GPIO_PORTJ_BASE, GPIO_PIN_6);
        GPIOPinTypeLCD(GPIO_PORTR_BASE,
                           (GPIO_PIN_0 | GPIO_PIN_1 | GPIO_PIN_2 | GPIO_PIN_3 |
                            GPIO_PIN_4 | GPIO_PIN_5 | GPIO_PIN_6 | GPIO_PIN_7));
        GPIOPinTypeLCD(GPIO_PORTS_BASE, GPIO_PIN_4 | GPIO_PIN_5);
        // PQ7 is used for the user LED.
        ROM_GPIOPinTypeGPIOOutput(GPIO_PORTQ_BASE, GPIO_PIN_7);
        ROM_GPIOPinWrite(GPIO_PORTQ_BASE, GPIO_PIN_7, 0);
    //! Configures the USB pins for ULPI connection to an external USB PHY.
    //! This function configures the USB ULPI pins to connect the DK-TM4C129X board
    //! to an external USB PHY in ULPI mode.  This allows the external PHY to act
    //! as an external high-speed phy for the DK-TM4C129X.  This function must be
    //! called after the call to PinoutSet() to properly configure the pins.
    //! \return None.
    #ifdef USE_ULPI
    void
    USBULPIPinoutSet(void)
        // Enable all the peripherals that are used by the ULPI interface.
        // ULPI Port B pins.
        ROM_GPIOPinConfigure(GPIO_PB2_USB0STP);
        ROM_GPIOPinConfigure(GPIO_PB3_USB0CLK);
        ROM_GPIOPinTypeUSBDigital(GPIO_PORTB_BASE, GPIO_PIN_2 | GPIO_PIN_3);
        GPIOPadConfigSet(GPIO_PORTB_BASE, GPIO_PIN_2 | GPIO_PIN_3,
                         GPIO_STRENGTH_12MA, GPIO_PIN_TYPE_STD);
        // ULPI Port P pins.
        ROM_GPIOPinConfigure(GPIO_PP2_USB0NXT);
        ROM_GPIOPinConfigure(GPIO_PP3_USB0DIR);
        ROM_GPIOPinConfigure(GPIO_PP4_USB0D7);
        ROM_GPIOPinConfigure(GPIO_PP5_USB0D6);
        ROM_GPIOPinTypeUSBDigital(GPIO_PORTP_BASE, GPIO_PIN_2 | GPIO_PIN_3 |
        GPIOPadConfigSet(GPIO_PORTP_BASE,
                         GPIO_PIN_2 | GPIO_PIN_3 | GPIO_PIN_4 | GPIO_PIN_5,
        // ULPI Port L pins.
        ROM_GPIOPinConfigure(GPIO_PL5_USB0D5);
        ROM_GPIOPinConfigure(GPIO_PL4_USB0D4);
        ROM_GPIOPinConfigure(GPIO_PL3_USB0D3);
        ROM_GPIOPinConfigure(GPIO_PL2_USB0D2);
        ROM_GPIOPinConfigure(GPIO_PL1_USB0D1);
        ROM_GPIOPinConfigure(GPIO_PL0_USB0D0);
        ROM_GPIOPinTypeUSBDigital(GPIO_PORTL_BASE, GPIO_PIN_0 | GPIO_PIN_1 |
        GPIOPadConfigSet(GPIO_PORTL_BASE,
        // ULPI Port M pins used to control the external USB oscillator and the
        // external USB phy on the DK-TM4C129X-DPHY board.
        // PM1 - Enables the USB oscillator on the DK-TM4C129X-DPHY board.
        // PM3 - Enables the USB phy on the DK-TM4C129X-DPHY board.
        ROM_GPIOPinTypeGPIOOutput(GPIO_PORTM_BASE, GPIO_PIN_1 | GPIO_PIN_3);
        ROM_GPIOPinWrite(GPIO_PORTM_BASE, GPIO_PIN_1 | GPIO_PIN_3, GPIO_PIN_1 |
        GPIO_PIN_3);
    #endif
    // Close the Doxygen group.
    您好 Kiran、
    当您为 UART 使用中断时、您是否已在   startup_ccs.c 文件中将 UARTIntHandler 从 UART0更改为 UART5?
    Ralph Jacobi
    您好、Ralph、
    我没有更改 startup_ccs.c 文件。
    我更改的唯一内容是主文件和引脚分配文件。
    Kiran
    您好 Kiran、
    这就是 问题所在、那么您的 UARTIntHandler 仍会路由到 UART0。 进行该调整、它应该起作用。
    Ralph Jacobi
    您好、Ralph、
    我更改了以下两行
       IntDefaultHandler、                        // UART0 Rx 和 Tx
       UARTIntHandler、                     // UART5 Rx 和 Tx
    但我在 MCU 的 TX 线上看不到任何东西。
    我出了什么问题?
    即使我的 Tera Term 没有针对以下代码执行任何操作;
       UARTSend (((uint8_t *)"输入文本:"、12);
    Kiran
    您好 Kiran、
    嗯... 我觉得配置还可以。 您的硬件设置如何? 您是否正在使用 FTDI 适配器?
    您是否能够使用逻辑状态分析器检查信号输出?
    我将 DK-TM4C129X 的 UART_ECHO 项目更改为使用 UART5和引脚 PH6 & pH7、它在输出方面工作正常。
    Ralph Jacobi
    您好、Ralph、
    我正在使用 FTDI 适配器。 对于 UART5、我使用的是 PC6和 pH7。 由于 BGA 器件、无法访问 PH6。 我们的布里斯班办事处使用了 PC6、我不得不继续使用它。 我使用示波器检查了信号。 当我按下笔记本电脑键盘上的键时、我会在 MCU (PC6)的 RX 引脚上看到一个良好的信号、即 FTDI 适配器的 TX。 但我在 MCU 的 TX 引脚(pH7)上看不到任何东西、即 FTDI 适配器的 RX。
    这是一个非常简单的电路板。 它具有 CAN 总线、UART、5个输入开关、3个 LED 和一个12V 至3.3V 直流/直流转换器。 除 UART 外、电路板上的所有器件均正常工作。
    Kiran
    您好 Kiran、
    我继续操作、获取您的确切代码并将其运行在我的板上、我可以看到 pH7上的输出。 因此、这不是代码问题、必须与硬件相关。
    要在 pH7引脚上查看信号、您需要在代码首次执行时进行监听、或在 while (1)循环中放入 UARTSend 语句。
    Ralph Jacobi
    您好、Ralph、
    使用另一个程序、我可以同时切换 PC6和 pH7。 我的硬件连接很好。 我已经在 while (1)循环中尝试过 UARTSend 语句。 但运气不好。 接下来、我将尝试使用 UART1。 这些引脚由 CAN 总线使用。 但我的老板说可以尝试一下。
    Kiran
    您好 Kiran、
    您能描述一下其他计划吗?
    同样、我复制粘贴了上面提供的准确代码、它在我的板上工作正常、我不知道在这里还有什么建议...
    Ralph Jacobi
    这里是我测试开关和 LED 的另一个程序。
    // blinky.c - Simple example to blink the on-board LED.
    // Copyright (c) 2013-2020 Texas Instruments Incorporated.  All rights reserved.
    // This is part of revision 2.2.0.295 of the DK-TM4C129X Firmware Package.
    #include <stdint.h>
    //! <h1>Blinky (blinky)</h1>
    //! A very simple example that blinks the on-board LED.
    #ifdef DEBUG
    void
        while(1);
    #endif
    // Blink the on-board LED.
    int
    main(void)
        volatile uint32_t ui32Loop;
        // Enable the GPIO port that is used for the on-board LED.
    //    SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOQ);
        // Check if the peripheral access is enabled.
    //    while(!SysCtlPeripheralReady(SYSCTL_PERIPH_GPIOQ))
         while(!SysCtlPeripheralReady(SYSCTL_PERIPH_GPIOM))
         while(!SysCtlPeripheralReady(SYSCTL_PERIPH_GPIOJ))
        // Enable the GPIO pin for the LED (PQ7).  Set the direction as output, and
        // enable the GPIO pin for digital function.
    //    GPIOPinTypeGPIOOutput(GPIO_PORTQ_BASE, GPIO_PIN_7);
         GPIOPinTypeGPIOOutput(GPIO_PORTM_BASE, GPIO_PIN_0); //LED-GRN
         GPIOPinTypeGPIOOutput(GPIO_PORTM_BASE, GPIO_PIN_1); //LED-RED
         GPIOPinTypeGPIOOutput(GPIO_PORTM_BASE, GPIO_PIN_2); //LED-AUTO
         GPIOPinTypeGPIOInput(GPIO_PORTJ_BASE, GPIO_PIN_2); //SWITCH-AUTO
         GPIOPinTypeGPIOInput(GPIO_PORTJ_BASE, GPIO_PIN_3); //SWITCH-INC
         GPIOPinTypeGPIOInput(GPIO_PORTJ_BASE, GPIO_PIN_4); //SWITCH-DEC
         GPIOPinTypeGPIOInput(GPIO_PORTJ_BASE, GPIO_PIN_6); //SWITCH-FUNCTION
         GPIOPinTypeGPIOInput(GPIO_PORTJ_BASE, GPIO_PIN_7); //SWITCH-MATCH
         GPIOPinTypeGPIOOutput(GPIO_PORTH_BASE, GPIO_PIN_7); //UART-TX
         GPIOPinTypeGPIOInput(GPIO_PORTC_BASE, GPIO_PIN_6); //UART-RX
         int S1_pressed = (!(GPIOPinRead(GPIO_PORTJ_BASE, GPIO_PIN_2)));   // True if PJ.2 low (button pressed)
         int S2_pressed = (!(GPIOPinRead(GPIO_PORTJ_BASE, GPIO_PIN_3)));   // True if PJ.3 low (button pressed)
         int S3_pressed = (!(GPIOPinRead(GPIO_PORTJ_BASE, GPIO_PIN_4)));   // True if PJ.4 low (button pressed)
         int S4_pressed = (!(GPIOPinRead(GPIO_PORTJ_BASE, GPIO_PIN_6)));   // True if PJ.6 low (button pressed)
         int S5_pressed = (!(GPIOPinRead(GPIO_PORTJ_BASE, GPIO_PIN_7)));   // True if PJ.7 low (button pressed)
         int SRx_pressed = (!(GPIOPinRead(GPIO_PORTC_BASE, GPIO_PIN_6)));   // True if RX low (button pressed)
        // Loop forever.
        while(1)
            // Turn on the LED.
    //        GPIOPinWrite(GPIO_PORTQ_BASE, GPIO_PIN_7, GPIO_PIN_7);
    //        GPIOPinWrite(GPIO_PORTM_BASE, GPIO_PIN_0, GPIO_PIN_0); //LED-GRN ON
            GPIOPinWrite(GPIO_PORTM_BASE, GPIO_PIN_1, GPIO_PIN_1); //LED-RED ON
            GPIOPinWrite(GPIO_PORTM_BASE, GPIO_PIN_0, 0x0); //LED-GRN OFF
            GPIOPinWrite(GPIO_PORTM_BASE, GPIO_PIN_2, GPIO_PIN_2); //LED-AUTO OFF
            GPIOPinWrite(GPIO_PORTH_BASE, GPIO_PIN_7, GPIO_PIN_7); //UART-TX OFF
    //       GPIOPinWrite(GPIO_PORTC_BASE, GPIO_PIN_6, GPIO_PIN_6); //UART-RX OFF
            // Delay for a bit.
            if (S1_pressed){
                for(ui32Loop = 0; ui32Loop < 1340000; ui32Loop++) // 1 second ON
            else if (S2_pressed){
                   for(ui32Loop = 0; ui32Loop < 2680000; ui32Loop++) // 2 second ON
            else if (S3_pressed){
                   for(ui32Loop = 0; ui32Loop < 4020000; ui32Loop++) // 3 second ON
            else if (S4_pressed){
                   for(ui32Loop = 0; ui32Loop < 5360000; ui32Loop++) // 4 second ON
            else if (S5_pressed){
                   for(ui32Loop = 0; ui32Loop < 6700000; ui32Loop++) // 5 second ON
            else if (SRx_pressed){
                   for(ui32Loop = 0; ui32Loop < 350000; ui32Loop++) // 5 second ON
            else
                for(ui32Loop = 0; ui32Loop < 670000; ui32Loop++) // 0.5 second ON
            // Turn off the LED.
    //        GPIOPinWrite(GPIO_PORTQ_BASE, GPIO_PIN_7, 0x0);
    //        GPIOPinWrite(GPIO_PORTM_BASE, GPIO_PIN_0, 0x0); //LED-GRN OFF
            GPIOPinWrite(GPIO_PORTM_BASE, GPIO_PIN_1, 0x0); //LED-RED OFF
            GPIOPinWrite(GPIO_PORTM_BASE, GPIO_PIN_2, 0x0); //LED-AUTO ON
            GPIOPinWrite(GPIO_PORTH_BASE, GPIO_PIN_7, 0x0); //UART-TX ON
    //        GPIOPinWrite(GPIO_PORTC_BASE, GPIO_PIN_6, 0x0); //UART-RX ON
            // Delay for a bit.
            if (S1_pressed){
            else
    您好 Kiran、
    您是否在连接了 FTDI 的情况下运行了该项目并看到了当时的切换? 表明 FTDI 不会导致任何问题。
    当配置为 GPIO 时、I/O 切换很好、但它仍然不能真正解释为什么 UART 不能正常工作。
    我现在唯一能想到的另一件事是:
    • 在 UARTSend 语句上设置断点
    • 进入 UART 寄存器以确保配置正确
    • 进入 GPIO 寄存器、验证是否为 UART 正确配置了 pH7
    不确定您是否有第二个 FTDI、您只需进行完整性检查即可进行测试。
    Ralph Jacobi
    您好、Ralph、
    切换时、我没有连接 FTDI 适配器。 我将在下一次尝试。
    我尝试了第二个 FTDI 适配器、它有相同的问题。
    在检查 UART 寄存器和 GPIO 寄存器的值方面、我得到了软件工程师的帮助。
    当我在调试会话中打开"Registers"窗口时、我在该窗口中看不到任何寄存器。
    断点窗口工作正常、我可以在这里看到我的断点。
    Kiran
    您好、Ralph、
    根据您的建议、我在 while 循环中添加了一个断点。
    但 UART5寄存器显示启用读取。 有什么想法吗?
    我得到以下结果。 还插入了我更改的3个文件。
    Kiran
    #include <stdint.h>
    #ifdef DEBUG
    void
    #endif
    void
    void
        while(ui32Count--)
    int
    main(void)
        tContext sContext;
        PinoutSet();
        IntMasterEnable();
        while(1)
    #include <stdint.h>
    //! \return None.
    void
    PinoutSet(void)
        // PB0-1 are used for UART1.
    //    ROM_GPIOPinConfigure(GPIO_PB0_U1RX);
    //    ROM_GPIOPinConfigure(GPIO_PB1_U1TX);
    //    ROM_GPIOPinTypeUART(GPIO_PORTB_BASE, GPIO_PIN_0 | GPIO_PIN_1);
    //! \return None.
    #ifdef USE_ULPI
    void
        GPIO_PIN_3);
    #endif
    // startup_ccs.c - Startup code for use with TI's Code Composer Studio.
    #include <stdint.h>
    #include "inc/hw_nvic.h"
    // Forward declaration of the default fault handlers.
    void ResetISR(void);
    static void NmiSR(void);
    static void FaultISR(void);
    static void IntDefaultHandler(void);
    // External declaration for the reset handler that is to be called when the
    // processor is started
    extern void _c_int00(void);
    // Linker variable that marks the top of the stack.
    extern uint32_t __STACK_TOP;
    // External declaration for the interrupt handler used by the application.
    extern void UARTIntHandler(void);
    // The vector table.  Note that the proper constructs must be placed on this to
    // ensure that it ends up at physical address 0x0000.0000 or at the start of
    // the program if located at a start address other than 0.
    #pragma DATA_SECTION(g_pfnVectors, ".intvecs")
    void (* const g_pfnVectors[])(void) =
        (void (*)(void))((uint32_t)&__STACK_TOP),
                                                // The initial stack pointer
        ResetISR,                               // The reset handler
        NmiSR,                                  // The NMI handler
        FaultISR,                               // The hard fault handler
        IntDefaultHandler,                      // The MPU fault handler
        IntDefaultHandler,                      // The bus fault handler
        IntDefaultHandler,                      // The usage fault handler
        0,                                      // Reserved
        0,                                      // Reserved
        0,                                      // Reserved
        0,                                      // Reserved
        IntDefaultHandler,                      // SVCall handler
        IntDefaultHandler,                      // Debug monitor handler
        0,                                      // Reserved
        IntDefaultHandler,                      // The PendSV handler
        IntDefaultHandler,                      // The SysTick handler
        IntDefaultHandler,                      // GPIO Port A
        IntDefaultHandler,                      // GPIO Port B
        IntDefaultHandler,                      // GPIO Port C
        IntDefaultHandler,                      // GPIO Port D
        IntDefaultHandler,                      // GPIO Port E
        IntDefaultHandler,                         // UART0 Rx and Tx
        IntDefaultHandler,                      // UART1 Rx and Tx
        IntDefaultHandler,                      // SSI0 Rx and Tx
        IntDefaultHandler,                      // I2C0 Master and Slave
        IntDefaultHandler,                      // PWM Fault
        IntDefaultHandler,                      // PWM Generator 0
        IntDefaultHandler,                      // PWM Generator 1
        IntDefaultHandler,                      // PWM Generator 2
        IntDefaultHandler,                      // Quadrature Encoder 0
        IntDefaultHandler,                      // ADC Sequence 0
        IntDefaultHandler,                      // ADC Sequence 1
        IntDefaultHandler,                      // ADC Sequence 2
        IntDefaultHandler,                      // ADC Sequence 3
        IntDefaultHandler,                      // Watchdog timer
        IntDefaultHandler,                      // Timer 0 subtimer A
        IntDefaultHandler,                      // Timer 0 subtimer B
        IntDefaultHandler,                      // Timer 1 subtimer A
        IntDefaultHandler,                      // Timer 1 subtimer B
        IntDefaultHandler,                      // Timer 2 subtimer A
        IntDefaultHandler,                      // Timer 2 subtimer B
        IntDefaultHandler,                      // Analog Comparator 0
        IntDefaultHandler,                      // Analog Comparator 1
        IntDefaultHandler,                      // Analog Comparator 2
        IntDefaultHandler,                      // System Control (PLL, OSC, BO)
        IntDefaultHandler,                      // FLASH Control
        IntDefaultHandler,                      // GPIO Port F
        IntDefaultHandler,                      // GPIO Port G
        IntDefaultHandler,                      // GPIO Port H
        IntDefaultHandler,                      // UART2 Rx and Tx
        IntDefaultHandler,                      // SSI1 Rx and Tx
        IntDefaultHandler,                      // Timer 3 subtimer A
        IntDefaultHandler,                      // Timer 3 subtimer B
        IntDefaultHandler,                      // I2C1 Master and Slave
        IntDefaultHandler,                      // CAN0
        IntDefaultHandler,                      // CAN1
        IntDefaultHandler,                      // Ethernet
        IntDefaultHandler,                      // Hibernate
        IntDefaultHandler,                      // USB0
        IntDefaultHandler,                      // PWM Generator 3
        IntDefaultHandler,                      // uDMA Software Transfer
        IntDefaultHandler,                      // uDMA Error
        IntDefaultHandler,                      // ADC1 Sequence 0
        IntDefaultHandler,                      // ADC1 Sequence 1
        IntDefaultHandler,                      // ADC1 Sequence 2
        IntDefaultHandler,                      // ADC1 Sequence 3
        IntDefaultHandler,                      // External Bus Interface 0
        IntDefaultHandler,                      // GPIO Port J
        IntDefaultHandler,                      // GPIO Port K
        IntDefaultHandler,                      // GPIO Port L
        IntDefaultHandler,                      // SSI2 Rx and Tx
        IntDefaultHandler,                      // SSI3 Rx and Tx
        IntDefaultHandler,                      // UART3 Rx and Tx
        IntDefaultHandler,                      // UART4 Rx and Tx
        UARTIntHandler,                      // UART5 Rx and Tx
        IntDefaultHandler,                      // UART6 Rx and Tx
        IntDefaultHandler,                      // UART7 Rx and Tx
        IntDefaultHandler,                      // I2C2 Master and Slave
        IntDefaultHandler,                      // I2C3 Master and Slave
        IntDefaultHandler,                      // Timer 4 subtimer A
        IntDefaultHandler,                      // Timer 4 subtimer B
        IntDefaultHandler,                      // Timer 5 subtimer A
        IntDefaultHandler,                      // Timer 5 subtimer B
        IntDefaultHandler,                      // FPU
        0,                                      // Reserved
        0,                                      // Reserved
        IntDefaultHandler,                      // I2C4 Master and Slave
        IntDefaultHandler,                      // I2C5 Master and Slave
        IntDefaultHandler,                      // GPIO Port M
        IntDefaultHandler,                      // GPIO Port N
        0,                                      // Reserved
        IntDefaultHandler,                      // Tamper
        IntDefaultHandler,                      // GPIO Port P (Summary or P0)
        IntDefaultHandler,                      // GPIO Port P1
        IntDefaultHandler,                      // GPIO Port P2
        IntDefaultHandler,                      // GPIO Port P3
        IntDefaultHandler,                      // GPIO Port P4
        IntDefaultHandler,                      // GPIO Port P5
        IntDefaultHandler,                      // GPIO Port P6
        IntDefaultHandler,                      // GPIO Port P7
        IntDefaultHandler,                      // GPIO Port Q (Summary or Q0)
        IntDefaultHandler,                      // GPIO Port Q1
        IntDefaultHandler,                      // GPIO Port Q2
        IntDefaultHandler,                      // GPIO Port Q3
        IntDefaultHandler,                      // GPIO Port Q4
        IntDefaultHandler,                      // GPIO Port Q5
        IntDefaultHandler,                      // GPIO Port Q6
        IntDefaultHandler,                      // GPIO Port Q7
        IntDefaultHandler,                      // GPIO Port R
        IntDefaultHandler,                      // GPIO Port S
        IntDefaultHandler,                      // SHA/MD5 0
        IntDefaultHandler,                      // AES 0
        IntDefaultHandler,                      // DES3DES 0
        IntDefaultHandler,                      // LCD Controller 0
        IntDefaultHandler,                      // Timer 6 subtimer A
        IntDefaultHandler,                      // Timer 6 subtimer B
        IntDefaultHandler,                      // Timer 7 subtimer A
        IntDefaultHandler,                      // Timer 7 subtimer B
        IntDefaultHandler,                      // I2C6 Master and Slave
        IntDefaultHandler,                      // I2C7 Master and Slave
        IntDefaultHandler,                      // HIM Scan Matrix Keyboard 0
        IntDefaultHandler,                      // One Wire 0
        IntDefaultHandler,                      // HIM PS/2 0
        IntDefaultHandler,                      // HIM LED Sequencer 0
        IntDefaultHandler,                      // HIM Consumer IR 0
        IntDefaultHandler,                      // I2C8 Master and Slave
        IntDefaultHandler,                      // I2C9 Master and Slave
        IntDefaultHandler                       // GPIO Port T
    // This is the code that gets called when the processor first starts execution
    // following a reset event.  Only the absolutely necessary set is performed,
    // after which the application supplied entry() routine is called.  Any fancy
    // actions (such as making decisions based on the reset cause register, and
    // resetting the bits in that register) are left solely in the hands of the
    // application.
    void
    ResetISR(void)
        // Jump to the CCS C initialization routine.  This will enable the
        // floating-point unit as well, so that does not need to be done here.
        __asm("    .global _c_int00\n"
              "    b.w     _c_int00");
    // This is the code that gets called when the processor receives a NMI.  This
    // simply enters an infinite loop, preserving the system state for examination
    // by a debugger.
    static void
    NmiSR(void)
        // Enter an infinite loop.
        while(1)
    // This is the code that gets called when the processor receives a fault
    // interrupt.  This simply enters an infinite loop, preserving the system state
    // for examination by a debugger.
    static void
    FaultISR(void)
        while(1)
    // This is the code that gets called when the processor receives an unexpected
    static void
        // Go into an infinite loop.
        while(1)
    您好 Kiran、
    是否有任何调试器错误指示? 比如在异常的存储器位置、点击 FaultISR 等。?
    您的优化设置是什么?
    您使用的是调试版本还是保护版本?
    如果您可以附加整个 CCS 项目、则不是文件、而是包含您的项目设置。 不确定这对您是否可行、了解是否由于可能包含的其他软件而不可行。
    Ralph Jacobi
    您好、Ralph、
    调试器未显示任何错误。
    我正在使用默认优化设置。
    我正在使用调试版本。
    我正在附加完整的项目 zip 文件。
    Kirane2e.ti.com/.../5810.uart_5F00_echo.zip
    您好 Kiran、
    这有点奇怪。 明天我必须再试一次、因为我现在只有一个方便使用 XDS200编程的电路板、但它对我来说运行正常。 我可以看到寄存器、我得到了正确的输出:
    Ralph Jacobi
    您好 Kiran、
    我不确定在我结束时会有什么建议。 使用 ICDI、我能够按预期调试您的项目、并确认了输出。 似乎一切都配置良好。
    我唯一需要更改的是默认库位置、因为我没有下载您的本地 TI REX、所以我将其指向 C 驱动器上的 TivaWare 2.2.0.295。
    Ralph Jacobi
