我现在在调试时进行了许多重新刷写、并且我经常遇到此问题-本节中的代码在引导时卡住:
/* Check if there were ESM group3 errors during power-up.
* These could occur during eFuse auto-load or during reads from flash OTP
* during power-up. Device operation is not reliable and not recommended
* in this case.
* An ESM group3 error only drives the nERROR pin low. An external circuit
* that monitors the nERROR pin must take the appropriate action to ensure that
* the system is placed in a safe state, as determined by the application.
if ((esmREG->SR1[2]) != 0U)
/* USER CODE BEGIN (24) */
/* USER CODE END */
/*SAFETYMCUSW 5 C MR:NA <APPROVED> "for(;;) can be removed by adding "# if 0" and "# endif" in the user codes above and below" */
/*SAFETYMCUSW 26 S MR:NA <APPROVED> "for(;;) can be removed by adding "# if 0" and "# endif" in the user codes above and below" */
/*SAFETYMCUSW 28 D MR:NA <APPROVED> "for(;;) can be removed by adding "# if 0" and "# endif" in the user codes above and below" */
for(;;)
}/* Wait */
/* USER CODE BEGIN (25) */
/* USER CODE END */
我认为没有实际的硬件错误,或者它不应该是.. 同时、我没有看到任何注释、即在调试时应禁用此测试。
有什么想法吗? 今天/现在我无法通过、可能需要对电路板进行下电上电、因为似乎没有大量的调试重启帮助。
