[参考译文] RTOS/TM4C1292NCPDT:Modbus 从站协议栈与 TI NDK 集成
Guru**** 2568585 points
https://e2e.ti.com/support/microcontrollers/arm-based-microcontrollers-group/arm-based-microcontrollers/f/arm-based-microcontrollers-forum/623941/rtos-tm4c1292ncpdt-modbus-slave-stack-integration-with-ti-ndk
器件型号:TM4C1292NCPDT
工具/软件:TI-RTOS
我 正在将 Modbus 从堆栈与 TI NDK 集成。 在 Linux 环境中配置目标层时、我们必须执行如下所示的代码才能初始化通道。
void * TMWDEFS_GLOBAL Liniotarg_initChannel (
 const void *pUserConfig,
 TMWTARG_CONFIG * pTmwConfig)
 LINIO_CONFIG * pIOConfig =(LINIO_CONFIG *) pUserConfig;
 LINIO_CHANNEL *pLinIoChannel;
 如果(!LinIoContext.bStarted)
#if LINIOTADG_SUPPING_TCP
   _LinuxSemCreate (&LinIoContext.tcpSemaphore);
   LinIoContext.pTcpChannels = TMWDEFS_NULL;
   LinIoContext.pTcpListeners = TMWDEFS_NULL;
   LinIoContext.bSocketThreadRunning = TMWDEFS_false;
   LinIoContext.bConnectThreadRunning = TMWDEFS_false;
   LinIoContext.socketThreadHandle = 0;
   LinIoContext.connectThreadHandle = 0;
#endif
#if LINIOTADG_SUPPING_232
   LinIoContext.pSerialChannels = TMWDEFS_NULL;
   _LinuxSemCreate(&LinIoContext.serialSemaphore);
#endif
   LinIoContext.bStarted = TMWDEFS_true;
 pLinIoChannel =(LINIO_CHANNEL *) malloc (sizeof (LINIO_CHANNEL));
 if (pLinIoChannel == NULL)
   返回 TMWDEFS_NULL;
 pLinIoChannel->type = pIOConfig->type;
 switch (pIOConfig->type)
 LINIO_TYPE_232案例:
   pLinIoChannel->pChannelInfo =(void *) lin232_initChannel (pIOConfig、pTmwConfig);
   中断;
#endif
 LINIO_TYPE_TCP 案例:
   pLinIoChannel->pChannelInfo =(void *) lintcp_initChannel (pIOConfig、pTmwConfig);
   中断;
#endif
 默认值:
   返回 TMWDEFS_NULL;
 return (pLinIoChannel);
/*函数:lintcp_initChannel */
void * TMWDEFS_GLOBAL LINtcp_initChannel (
 tcp_io_channel *pTcpChannel;
 pTcpChannel =(tcp_io_channel *) malloc (sizeof (tcp_io_channel));
 if (pTcpChannel =空)
   返回 TMWDEFS_NULL;
 memset (pTcpChannel、0、sizeof (tcp_io_channel));
 pTcpChannel->bChannelFree = TMWDEFS_false;
 pTcpChannel->dataSocket = invalid_socket;                                           //检查是否需要有效的套接字
 pTcpChannel->udpSocket = invalid_socket;
 pTcpChannel->ipPort = pIOConfig->lintcp.ipPort;
 pTcpChannel->mode = pIOConfig->lintcp.mode;
 // pTcpChannel->Role = pIOConfig->lintcp.role;
 strcpy (pTcpChannel->ipAddress、pIOConfig->lintcp.ipAddress);
 strcpy (pTcpChannel->chnlName、pIOConfig->linTCP.chnlName);
// pTcpChannel->validateUDPAddress = pIOConfig->lintcp.validateUDPAddress;
// pTcpChannel->validUDPAddress = 0;
 // strcpy (pTcpChannel->udpBroadcastAddress、pIOConfig->lintcp.udpBroadcastAddress);
// pTcpChannel->destUDPPort = pIOConfig->linTCP.destUDPPort;
// pTcpChannel->initUnsolUDPPort = pIOConfig->linTCP.initUnsolUDPPort;
// pTcpChannel->localUDPPort = pIOConfig->lintcp.localUDPPort;
 pTcpChannel->ipConnectTimeout = pIOConfig->lintcp.ipConnectTimeout;
 pTcpChannel->disconnectOnNewSyn = pIOConfig->lintcp.disconnectOnNewSyn;
// pTcpChannel->dualEndPointIpPort = pIOConfig->lintcp.dualEndPointIpPort;
 pTcpChannel->pChannelCallback = pTmwConfig->pChannelCallback;
 pTcpChannel->pChannelCallbackParam = pTmwConfig->pCallbackParam;
 pTcpChannel->pChannelReadyCallback = pTmwConfig->pChannelReadyCallback;
 pTcpChannel->pChannelReadyCbkParam = pTmwConfig->pChannelReadyCbkParam;
 tmw_TP_TakeSem (LinIoContext.tcpSemaphore);
 pTcpChannel->pNext = LinIoContext.pTcpChannels;
 LinIoContext.pTcpChannels = pTcpChannel;
 tmw_TP_ReleaseSem (LinIoContext.tcpSemaphore);
 返回 pTcpChannel;
我必须在 TI RTOS 环境中实现这一点。 请为我提供 相关指导。
    您好、Sandra、
    您可以参阅 TI-RTOS 中 TCP Echo 示例中的.cfg 文件、以了解如何配置 NDK 堆栈。 此外、有关更多详细信息、请参阅 NDK 的用户指南。
    Todd
    感谢你的答复。
