[参考译文] CCS/LM3S1968:Pleass 告诉我 DeepSleep 模式和唤醒方法
Guru**** 2616675 points
Other Parts Discussed in Thread: LM3S1968
https://e2e.ti.com/support/microcontrollers/arm-based-microcontrollers-group/arm-based-microcontrollers/f/arm-based-microcontrollers-forum/608957/ccs-lm3s1968-pleass-tell-me-about-deepsleep-mode-and-wake-up-method
器件型号:LM3S1968
工具/软件:Code Composer Studio
我使用了 LM3S1968 MCU。
但我有一些问题。 它在深度睡眠模式中唤醒。
我尝试了 GPIO 中断方法
下面我尝试了内容。
如果 GPIOA 有上升沿、则 CPU 被唤醒。 但不执行任何操作
我们的代码如下
//所有 GPIO 输入
 //HWREG (0x40004400)=0x00000000;   //A PDR
HWREG (0x40005400)= 0x00000000;   //B PDR
HWREG (0x40006400)= 0x00000000;   //C PDR
HWREG (0x40007400)= 0x00000000;   //D PDR
HWREG (0x40024400)= 0x00000000;   //E PDR
HWREG (0x40025400)= 0x00000000;   //F PDR
HWREG (0x40026400)= 0x00000000;   //G PDR
HWREG (0x40027400)= 0x00000000;   //H PDR
 //数字禁用
//HWREG (0x4000451C)= 0x00000000;   //A DS
HWREG (0x4000551C)= 0x00000000;   //B DS
HWREG (0x4000651C)= 0x00000000;   //C DS
HWREG (0x4000751C)= 0x00000000;   //D DS
HWREG (0x4002451C)= 0x00000000;   //E DS
HWREG (0x4002551C)= 0x00000000;   //F DS
HWREG (0x4002651C)= 0x00000000;   //G DS
HWREG (0x4002751C)= 0x00000000;   //H DS
 //交替放捆
//HWREG (0x40004420)= 0x00000000;   //A AFSEL
HWREG (0x40005420)= 0x00000000;   //B AFSEL
HWREG (0x40006420)= 0x00000000;   /C AFSEL
HWREG (0x40007420)= 0x00000000;   //D AFSEL
 HWREG (0x40024420)= 0x00000000;   //E AFSEL
HWREG (0x40025420)= 0x00000000;   //F AFSEL
HWREG (0x40026420)= 0x00000000;   //G AFSEL
 HWREG (0x40027420)= 0x00000000;   //H AFSEL
  //上拉禁用
//HWREG (0x40004510)=0x00000000;   //A PUR
HWREG (0x40005510)= 0x00000000;   //B PUR
HWREG (0x40006510)= 0x00000000;   //C PUR
HWREG (0x40007510)= 0x00000000;   //D PUR
HWREG (0x40024510)= 0x00000000;   //E PUR
HWREG (0x40025510)= 0x00000000;   //F PUR
HWREG (0x40026510)= 0x00000000;   //G PUR
HWREG (0x40027510)= 0x00000000;   //H PUR
 //下拉禁用
 //HWREG (0x40004514)=0x00000000;   //A PDR
HWREG (0x40005514)= 0x00000000;   //B PDR
HWREG (0x40006514)= 0x00000000;   //C PDR
HWREG (0x40007514)= 0x00000000;   //D PDR
HWREG (0x40024514)= 0x00000000;   //E PDR
HWREG (0x40025514)= 0x00000000;   //F PDR
HWREG (0x40026514)= 0x00000000;   //G PDR
HWREG (0x40027514)= 0x00000000;   //H PDR
SysCtlPeripheralEnable (SYSCTL_Periph_GPIOA);
SysCtlPeripheralDisable (SYSCTL_Periph_ADC);
SysCtlPeripheralDisable (SYSCTL_Periph_CAN0);
SysCtlPeripheralDisable (SYSCTL_Periph_CAN1);
SysCtlPeripheralDisable (SYSCTL_Periph_CAN2);
SysCtlPeripheralDisable (SYSCTL_Periph_COMP0);
SysCtlPeripheralDisable (SYSCTL_Periph_COMP1);
SysCtlPeripheralDisable (SYSCTL_Periph_Comp2);
SysCtlPeripheralDisable (SYSCTL_Periph_ETH);
SysCtlPeripheralDisable (SYSCTL_Periph_GPIOB);
SysCtlPeripheralDisable (SYSCTL_Periph_GPIOC);
SysCtlPeripheralDisable (SYSCTL_Periph_GPIOD);
SysCtlPeripheralDisable (SYSCTL_Periph_GPIOE);
SysCtlPeripheralDisable (SYSCTL_Periph_GPIOF);
SysCtlPeripheralDisable (SYSCTL_Periph_GPIOG);
SysCtlPeripheralDisable (SYSCTL_Periph_GPIOH);
 SysCtlPeripheralDisable (SYSCTL_Periph_HIBERNATE);
SysCtlPeripheralDisable (SYSCTL_Periph_I2C0);
SysCtlPeripheralDisable (SYSCTL_Periph_I2C1);
SysCtlPeripheralDisable (SYSCTL_Periph_PWM);
SysCtlPeripheralDisable (SYSCTL_Periph_QEI0);
SysCtlPeripheralDisable (SYSCTL_Periph_QEI1);
SysCtlPeripheralDisable (SYSCTL_Periph_SSI0);
SysCtlPeripheralDisable (SYSCTL_Periph_SSI1);
 SysCtlPeripheralDisable (SYSCTL_Periph_TIMER0);
SysCtlPeripheralDisable (SYSCTL_Periph_Timer1);
SysCtlPeripheralDisable (SYSCTL_Periph_TIMER2);
SysCtlPeripheralDisable (SYSCTL_Periph_TIMER3);
SysCtlPeripheralDisable (SYSCTL_Periph_UART0);
SysCtlPeripheralDisable (SYSCTL_Periph_UART1);
SysCtlPeripheralDisable (SYSCTL_Periph_UART2);
SysCtlPeripheralDisable (SYSCTL_Periph_WDOG);
SysCtlLDOSet (SYSCTL_LDO_2_45V);
SysCtlLDOSet (SYSCTL_LDO_2_40V);
SysCtlLDOSet (SYSCTL_LDO_2_35V);
SysCtlLDOSet (SYSCTL_LDO_2_30V);
SysCtlLDOSet (SYSCTL_LDO_2_25V);
SysCtlPeripheralDeepSlepEnable (SYSCTL_Periph_GPIOA);
SysCtlPeripheralDeepSlepDisable (SYSCTL_Periph_ADC);
SysCtlPeripheralDeepSlepDisable (SYSCTL_Periph_CAN0);
SysCtlPeripheralDeepSlepDisable (SYSCTL_Periph_CAN1);
SysCtlPeripheralDeepSlepDisable (SYSCTL_Periph_CAN2);
SysCtlPeripheralDeepSlepDisable (SYSCTL_Periph_COMP0);
SysCtlPeripheralDeepSlepDisable (SYSCTL_Periph_COMP1);
SysCtlPeripheralDeepSlepDisable (SYSCTL_Periph_Comp2);
SysCtlPeripheralDeepSlepDisable (SYSCTL_Periph_ETH);
SysCtlPeripheralDeepSlepDisable (SYSCTL_Periph_GPIOB);
SysCtlPeripheralDeepSlepDisable (SYSCTL_Periph_GPIOC);
SysCtlPeripheralDeepSlepDisable (SYSCTL_Periph_GPIOD);
SysCtlPeripheralDeepSlepDisable (SYSCTL_Periph_GPIOE);
SysCtlPeripheralDeepSlepDisable (SYSCTL_Periph_GPIOF);
SysCtlPeripheralDeepSlepDisable (SYSCTL_Periph_GPIOG);
SysCtlPeripheralDeepSlepDisable (SYSCTL_Periph_GPIOH);
SysCtlPeripheralDeepSlepDisable (SYSCTL_Periph_HIBERNATE);
SysCtlPeripheralDeepSlepDisable (SYSCTL_Periph_I2C0);
SysCtlPeripheralDeepSlepDisable (SYSCTL_Periph_I2C1);
SysCtlPeripheralDeepSlepDisable (SYSCTL_Periph_PWM);
SysCtlPeripheralDeepSlepDisable (SYSCTL_Periph_QEI0);
SysCtlPeripheralDeepSlepDisable (SYSCTL_Periph_QEI1);
SysCtlPeripheralDeepSlepDisable (SYSCTL_Periph_SSI0);
SysCtlPeripheralDeepSlepDisable (SYSCTL_Periph_SSI1);
SysCtlPeripheralDeepSlepDisable (SYSCTL_Periph_TIMER0);
SysCtlPeripheralDeepSlepDisable (SYSCTL_Periph_Timer1);
SysCtlPeripheralDeepSlepDisable (SYSCTL_Periph_TIMER2);
SysCtlPeripheralDeepSlepDisable (SYSCTL_Periph_TIMER3);
SysCtlPeripheralDeepSlepDisable (SYSCTL_Periph_UART0);
SysCtlPeripheralDeepSlepDisable (SYSCTL_Periph_UART1);
SysCtlPeripheralDeepSlepDisable (SYSCTL_Periph_UART2);
SysCtlPeripheralDeepSlepDisable (SYSCTL_Periph_WDOG);
 SysCtlPeripheralClockGating (真);
ulRCC = HWREG (0x400FE060);
ulRCC |= 0x00000002;
HWREG (0x400FE060)= ulRCC;
HWREG (0x400FE144)= 0x1F800030;          //DSLPCLKCFG
HWREG (0x400FE120)= 0x0;              //DCGC0
HWREG (0x400FE124)= 0x0;              //DCGC1
HWREG (0x400FE128)= 0x0;              //DCGC2
SysCtlDeepSleep ();           //强制 CTL 进入深度睡眠模式。
请告诉我在深度睡眠模式中的唤醒方法
此致。
