[参考译文] LAUNCHXL-CC2640R2:模拟 GPIO 作为数字输出崩溃
Guru**** 2553260 points
Other Parts Discussed in Thread: LAUNCHXL-CC2640R2
https://e2e.ti.com/support/wireless-connectivity/bluetooth-group/bluetooth/f/bluetooth-forum/1014957/launchxl-cc2640r2-analog-gpios-crash-as-digital-output
器件型号:LAUNCHXL-CC2640R2
Thread 中讨论的其他器件: SYSBIOS
我在这里有一个 LaunchXL-CC2640R2、我需要将其连接到未知的4路复用分段式显示屏。 为了测试我将一次控制一个段、以便我可以列出哪个段属于哪个背板和段驱动。 但是、配置输出引脚时遇到一些问题:
/*---PIN DEFINITIONS---*/
#define PIN_COM0 IOID_0
#define PIN_COM1 IOID_1
#define PIN_COM2 IOID_2
#define PIN_COM3 IOID_3
#define PIN_SEG0 IOID_4
#define PIN_SEG1 IOID_5
#define PIN_SEG2 IOID_6
#define PIN_SEG3 IOID_11
#define PIN_SEG4 IOID_12
#define PIN_SEG5 IOID_15
#define PIN_SEG6 IOID_18
#define PIN_SEG7 IOID_19
#define PIN_SEG8 IOID_20
#define PIN_SEG9 IOID_21
#define PIN_SEG10 IOID_22
#define PIN_SEG11 IOID_23
#define PIN_SEG12 IOID_24
#define PIN_SEG13 IOID_25
#define PIN_SEG14 IOID_26
#define PIN_SEG15 IOID_27
#define PIN_SEG16 IOID_28
#define PIN_SEG17 IOID_29
#define PIN_SEG18 IOID_30
#define PIN_SEG19 IOID_7
GPIO_setConfig(PIN_COM0, GPIO_CFG_OUT_STD | GPIO_CFG_OUT_LOW);
GPIO_setConfig(PIN_COM1, GPIO_CFG_OUT_STD | GPIO_CFG_OUT_LOW);
GPIO_setConfig(PIN_COM2, GPIO_CFG_OUT_STD | GPIO_CFG_OUT_LOW);
GPIO_setConfig(PIN_COM3, GPIO_CFG_OUT_STD | GPIO_CFG_OUT_LOW);
GPIO_setConfig(PIN_SEG0, GPIO_CFG_OUT_STD | GPIO_CFG_OUT_LOW);
GPIO_setConfig(PIN_SEG1, GPIO_CFG_OUT_STD | GPIO_CFG_OUT_LOW);
GPIO_setConfig(PIN_SEG2, GPIO_CFG_OUT_STD | GPIO_CFG_OUT_LOW);
GPIO_setConfig(PIN_SEG3, GPIO_CFG_OUT_STD | GPIO_CFG_OUT_LOW);
GPIO_setConfig(PIN_SEG4, GPIO_CFG_OUT_STD | GPIO_CFG_OUT_LOW);
GPIO_setConfig(PIN_SEG5, GPIO_CFG_OUT_STD | GPIO_CFG_OUT_LOW);
GPIO_setConfig(PIN_SEG6, GPIO_CFG_OUT_STD | GPIO_CFG_OUT_LOW);
GPIO_setConfig(PIN_SEG7, GPIO_CFG_OUT_STD | GPIO_CFG_OUT_LOW);
GPIO_setConfig(PIN_SEG8, GPIO_CFG_OUT_STD | GPIO_CFG_OUT_LOW);
GPIO_setConfig(PIN_SEG9, GPIO_CFG_OUT_STD | GPIO_CFG_OUT_LOW);
GPIO_setConfig(PIN_SEG10, GPIO_CFG_OUT_STD | GPIO_CFG_OUT_LOW);
GPIO_setConfig(PIN_SEG11, GPIO_CFG_OUT_STD | GPIO_CFG_OUT_LOW);
GPIO_setConfig(PIN_SEG12, GPIO_CFG_OUT_STD | GPIO_CFG_OUT_LOW);
GPIO_setConfig(PIN_SEG13, GPIO_CFG_OUT_STD | GPIO_CFG_OUT_LOW);
GPIO_setConfig(PIN_SEG14, GPIO_CFG_OUT_STD | GPIO_CFG_OUT_LOW);
GPIO_setConfig(PIN_SEG15, GPIO_CFG_OUT_STD | GPIO_CFG_OUT_LOW);
GPIO_setConfig(PIN_SEG16, GPIO_CFG_OUT_STD | GPIO_CFG_OUT_LOW);
GPIO_setConfig(PIN_SEG17, GPIO_CFG_OUT_STD | GPIO_CFG_OUT_LOW);
GPIO_setConfig(PIN_SEG18, GPIO_CFG_OUT_STD | GPIO_CFG_OUT_LOW);
GPIO_setConfig(PIN_SEG19, GPIO_CFG_OUT_STD | GPIO_CFG_OUT_LOW);
此代码运行正常且没有问题、注册到 BUTTON0 (IOID_13)和 BUTTON1 (IOID_14)引脚的中断运行良好。 以下代码也会运行、但仅在 PIN_SEG11被写入前运行:
GPIO_write(PIN_COM0, true);
GPIO_write(PIN_COM1, true);
GPIO_write(PIN_COM2, true);
GPIO_write(PIN_COM3, true);
GPIO_write(PIN_SEG0, true);
GPIO_write(PIN_SEG1, true);
GPIO_write(PIN_SEG2, true);
GPIO_write(PIN_SEG3, true);
GPIO_write(PIN_SEG4, true);
GPIO_write(PIN_SEG5, true);
GPIO_write(PIN_SEG6, true);
GPIO_write(PIN_SEG7, true);
GPIO_write(PIN_SEG8, true);
GPIO_write(PIN_SEG9, true);
GPIO_write(PIN_SEG10, true);    //still running
GPIO_write(PIN_SEG11, true);    //here lies my problem
GPIO_write(PIN_SEG12, true);
GPIO_write(PIN_SEG13, true);
GPIO_write(PIN_SEG14, true);
GPIO_write(PIN_SEG15, true);
GPIO_write(PIN_SEG16, true);
GPIO_write(PIN_SEG17, true);
GPIO_write(PIN_SEG18, true);
GPIO_write(PIN_SEG19, true);*/
之后、我的中断不再触发。 如您所见、当 PIN_SEG11也称为 IOID_23又称为 A0引脚被写入时、就会出现此问题。 但是、正如我在其他代码中看到的、可以将这些模拟引脚用作数字输出。 我是否必须删除某个位置的一些代码才能首先禁用模拟功能? 我的程序基于"empty_CC2640R2_LAUNCHXL_tirtos_ccs"示例。 在我的 empty.cfg-file 下启用 System_printf()输出:
utils.importFile("C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/ble5stack/common/cc26xx/kernel/cc2640/config/cc2640_r2_csdk.cfg");
* Extend the cc2640 configuration
var SysStd = xdc.useModule("xdc.runtime.SysStd");
var System = xdc.useModule("xdc.runtime.System");
System.SupportProxy = SysStd;
System.extendedFormats = '%$L%$S%$F%f';
/* ================ POSIX configuration ================ */
var Settings = xdc.useModule('ti.sysbios.posix.Settings');
if (Program.build.target.$name.match(/iar/)) {
    var MultithreadSupport = xdc.useModule('ti.sysbios.rts.iar.MultithreadSupport');
    MultithreadSupport.enableMultithreadSupport = false;
提前非常感谢您的帮助! (:
德国的最佳祝愿
Nico
    PS:在这里、我似乎也无法真正更改引脚状态。 例如、无论我写入"true"还是"false"、引脚4都始终保持高电平状态。  GPIO_init()在引脚配置之前调用,因此这不是问题。
    您好、Nico、
      CC2640R2_LAUNCHXL.h 中 CC2640R2_LAUNCHXL_GPIOName 的内容是什么?它是否与   CC2640R2_LAUNCHXL.c 中的 gpioPinConfigs 保持一致?  您还需要确保从 CC2640R2_LAUNCHXL_ADCBuf0ChannelName/CC2640R2_LAUNCHXL_ADCName & ADCBufCC26XX_adcChannelLut/adcCC26xxHWAttrs/ADC_CONFIG 中移除模拟引脚、以避免重叠。  您可以查看其他 E2E 主题以进一步了解 如何实施这些更改。
    Ryan
    您好、Ryan、
    非常感谢您的回答! 我的  CC2640R2_LAUNCHXL.c 如下所示:
     * Copyright (c) 2016-2019, Texas Instruments Incorporated
     * All rights reserved.
     * Redistribution and use in source and binary forms, with or without
     * modification, are permitted provided that the following conditions
     * are met:
     * *  Redistributions of source code must retain the above copyright
     *    notice, this list of conditions and the following disclaimer.
     * *  Redistributions in binary form must reproduce the above copyright
     *    notice, this list of conditions and the following disclaimer in the
     *    documentation and/or other materials provided with the distribution.
     * *  Neither the name of Texas Instruments Incorporated nor the names of
     *    its contributors may be used to endorse or promote products derived
     *    from this software without specific prior written permission.
     * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
     * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
     * THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
     * PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
     * CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
     * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
     * PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
     * OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
     * WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
     * OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
     * EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
     *  ====================== CC2640R2_LAUNCHXL.c ===================================
     *  This file is responsible for setting up the board specific items for the
     *  CC2640R2_LAUNCHXL board.
    #include <stdbool.h>
    #include <stddef.h>
    #include <stdint.h>
    #include <ti/devices/cc26x0r2/driverlib/ioc.h>
    #include <ti/devices/cc26x0r2/driverlib/udma.h>
    #include <ti/devices/cc26x0r2/inc/hw_ints.h>
    #include <ti/devices/cc26x0r2/inc/hw_memmap.h>
    #include "CC2640R2_LAUNCHXL.h"
     *  =============================== ADCBuf ===============================
    #include <ti/drivers/ADCBuf.h>
    #include <ti/drivers/adcbuf/ADCBufCC26XX.h>
    ADCBufCC26XX_Object adcBufCC26xxObjects[CC2640R2_LAUNCHXL_ADCBUFCOUNT];
     *  This table converts a virtual adc channel into a dio and internal analogue
     *  input signal. This table is necessary for the functioning of the adcBuf
     *  driver. Comment out unused entries to save flash. Dio and internal signal
     *  pairs are hardwired. Do not remap them in the table. You may reorder entire
     *  entries. The mapping of dio and internal signals is package dependent.
    const ADCBufCC26XX_AdcChannelLutEntry ADCBufCC26XX_adcChannelLut[CC2640R2_LAUNCHXL_ADCBUF0CHANNELCOUNT] = {
        /*{CC2640R2_LAUNCHXL_DIO23_ANALOG, ADC_COMPB_IN_AUXIO7},
        {CC2640R2_LAUNCHXL_DIO24_ANALOG, ADC_COMPB_IN_AUXIO6},
        {CC2640R2_LAUNCHXL_DIO25_ANALOG, ADC_COMPB_IN_AUXIO5},
        {CC2640R2_LAUNCHXL_DIO26_ANALOG, ADC_COMPB_IN_AUXIO4},
        {CC2640R2_LAUNCHXL_DIO27_ANALOG, ADC_COMPB_IN_AUXIO3},
        {CC2640R2_LAUNCHXL_DIO28_ANALOG, ADC_COMPB_IN_AUXIO2},
        {CC2640R2_LAUNCHXL_DIO29_ANALOG, ADC_COMPB_IN_AUXIO1},
        {CC2640R2_LAUNCHXL_DIO30_ANALOG, ADC_COMPB_IN_AUXIO0},*/
        {PIN_UNASSIGNED, ADC_COMPB_IN_VDDS},
        {PIN_UNASSIGNED, ADC_COMPB_IN_DCOUPL},
        {PIN_UNASSIGNED, ADC_COMPB_IN_VSS},
    const ADCBufCC26XX_HWAttrs adcBufCC26xxHWAttrs[CC2640R2_LAUNCHXL_ADCBUFCOUNT] = {
            .intPriority       = ~0,
            .swiPriority       = 0,
            .adcChannelLut     = ADCBufCC26XX_adcChannelLut,
    const ADCBuf_Config ADCBuf_config[CC2640R2_LAUNCHXL_ADCBUFCOUNT] = {
            &ADCBufCC26XX_fxnTable,
            &adcBufCC26xxObjects[CC2640R2_LAUNCHXL_ADCBUF0],
            &adcBufCC26xxHWAttrs[CC2640R2_LAUNCHXL_ADCBUF0]
    const uint_least8_t ADCBuf_count = CC2640R2_LAUNCHXL_ADCBUFCOUNT;
     *  =============================== ADC ===============================
    #include <ti/drivers/ADC.h>
    #include <ti/drivers/adc/ADCCC26XX.h>
    ADCCC26XX_Object adcCC26xxObjects[CC2640R2_LAUNCHXL_ADCCOUNT];
    const ADCCC26XX_HWAttrs adcCC26xxHWAttrs[CC2640R2_LAUNCHXL_ADCCOUNT] = {
            .adcDIO              = CC2640R2_LAUNCHXL_DIO23_ANALOG,
            .adcCompBInput       = ADC_COMPB_IN_AUXIO7,
            .refSource           = ADCCC26XX_FIXED_REFERENCE,
            .samplingDuration    = ADCCC26XX_SAMPLING_DURATION_2P7_US,
            .inputScalingEnabled = true,
            .triggerSource       = ADCCC26XX_TRIGGER_MANUAL,
            .returnAdjustedVal   = false
            .adcDIO              = CC2640R2_LAUNCHXL_DIO24_ANALOG,
            .adcCompBInput       = ADC_COMPB_IN_AUXIO6,
            .adcDIO              = CC2640R2_LAUNCHXL_DIO25_ANALOG,
            .adcCompBInput       = ADC_COMPB_IN_AUXIO5,
            .adcDIO              = CC2640R2_LAUNCHXL_DIO26_ANALOG,
            .adcCompBInput       = ADC_COMPB_IN_AUXIO4,
            .adcDIO              = CC2640R2_LAUNCHXL_DIO27_ANALOG,
            .adcCompBInput       = ADC_COMPB_IN_AUXIO3,
            .adcDIO              = CC2640R2_LAUNCHXL_DIO28_ANALOG,
            .adcCompBInput       = ADC_COMPB_IN_AUXIO2,
            .adcDIO              = CC2640R2_LAUNCHXL_DIO29_ANALOG,
            .adcCompBInput       = ADC_COMPB_IN_AUXIO1,
            .adcDIO              = CC2640R2_LAUNCHXL_DIO30_ANALOG,
            .adcCompBInput       = ADC_COMPB_IN_AUXIO0,
            .samplingDuration    = ADCCC26XX_SAMPLING_DURATION_10P9_MS,
            .adcDIO              = PIN_UNASSIGNED,
            .adcCompBInput       = ADC_COMPB_IN_DCOUPL,
            .adcCompBInput       = ADC_COMPB_IN_VSS,
            .adcCompBInput       = ADC_COMPB_IN_VDDS,
    const ADC_Config ADC_config[CC2640R2_LAUNCHXL_ADCCOUNT] = {
        /*{&ADCCC26XX_fxnTable, &adcCC26xxObjects[CC2640R2_LAUNCHXL_ADC0], &adcCC26xxHWAttrs[CC2640R2_LAUNCHXL_ADC0]},
        {&ADCCC26XX_fxnTable, &adcCC26xxObjects[CC2640R2_LAUNCHXL_ADC1], &adcCC26xxHWAttrs[CC2640R2_LAUNCHXL_ADC1]},
        {&ADCCC26XX_fxnTable, &adcCC26xxObjects[CC2640R2_LAUNCHXL_ADC2], &adcCC26xxHWAttrs[CC2640R2_LAUNCHXL_ADC2]},
        {&ADCCC26XX_fxnTable, &adcCC26xxObjects[CC2640R2_LAUNCHXL_ADC3], &adcCC26xxHWAttrs[CC2640R2_LAUNCHXL_ADC3]},
        {&ADCCC26XX_fxnTable, &adcCC26xxObjects[CC2640R2_LAUNCHXL_ADC4], &adcCC26xxHWAttrs[CC2640R2_LAUNCHXL_ADC4]},
        {&ADCCC26XX_fxnTable, &adcCC26xxObjects[CC2640R2_LAUNCHXL_ADC5], &adcCC26xxHWAttrs[CC2640R2_LAUNCHXL_ADC5]},
        {&ADCCC26XX_fxnTable, &adcCC26xxObjects[CC2640R2_LAUNCHXL_ADC6], &adcCC26xxHWAttrs[CC2640R2_LAUNCHXL_ADC6]},
        {&ADCCC26XX_fxnTable, &adcCC26xxObjects[CC2640R2_LAUNCHXL_ADC7], &adcCC26xxHWAttrs[CC2640R2_LAUNCHXL_ADC7]},*/
        {&ADCCC26XX_fxnTable, &adcCC26xxObjects[CC2640R2_LAUNCHXL_ADCDCOUPL], &adcCC26xxHWAttrs[CC2640R2_LAUNCHXL_ADCDCOUPL]},
        {&ADCCC26XX_fxnTable, &adcCC26xxObjects[CC2640R2_LAUNCHXL_ADCVSS], &adcCC26xxHWAttrs[CC2640R2_LAUNCHXL_ADCVSS]},
        {&ADCCC26XX_fxnTable, &adcCC26xxObjects[CC2640R2_LAUNCHXL_ADCVDDS], &adcCC26xxHWAttrs[CC2640R2_LAUNCHXL_ADCVDDS]},
    const uint_least8_t ADC_count = CC2640R2_LAUNCHXL_ADCCOUNT;
     *  =============================== Crypto ===============================
    #include <ti/drivers/crypto/CryptoCC26XX.h>
    CryptoCC26XX_Object cryptoCC26XXObjects[CC2640R2_LAUNCHXL_CRYPTOCOUNT];
    const CryptoCC26XX_HWAttrs cryptoCC26XXHWAttrs[CC2640R2_LAUNCHXL_CRYPTOCOUNT] = {
            .baseAddr       = CRYPTO_BASE,
            .powerMngrId    = PowerCC26XX_PERIPH_CRYPTO,
            .intNum         = INT_CRYPTO_RESULT_AVAIL_IRQ,
            .intPriority    = ~0,
    const CryptoCC26XX_Config CryptoCC26XX_config[CC2640R2_LAUNCHXL_CRYPTOCOUNT] = {
             .object  = &cryptoCC26XXObjects[CC2640R2_LAUNCHXL_CRYPTO0],
             .hwAttrs = &cryptoCC26XXHWAttrs[CC2640R2_LAUNCHXL_CRYPTO0]
     *  =============================== AESCCM ===============================
    #include <ti/drivers/AESCCM.h>
    #include <ti/drivers/aesccm/AESCCMCC26XX.h>
    AESCCMCC26XX_Object aesccmCC26XXObjects[CC2640R2_LAUNCHXL_AESCCMCOUNT];
    const AESCCMCC26XX_HWAttrs aesccmCC26XXHWAttrs[CC2640R2_LAUNCHXL_AESCCMCOUNT] = {
            .intPriority       = ~0,
    const AESCCM_Config AESCCM_config[CC2640R2_LAUNCHXL_AESCCMCOUNT] = {
             .object  = &aesccmCC26XXObjects[CC2640R2_LAUNCHXL_AESCCM0],
             .hwAttrs = &aesccmCC26XXHWAttrs[CC2640R2_LAUNCHXL_AESCCM0]
    const uint_least8_t AESCCM_count = CC2640R2_LAUNCHXL_AESCCMCOUNT;
     *  =============================== AESGCM ===============================
    #include <ti/drivers/AESGCM.h>
    #include <ti/drivers/aesgcm/AESGCMCC26XX.h>
    AESGCMCC26XX_Object aesgcmCC26XXObjects[CC2640R2_LAUNCHXL_AESGCMCOUNT];
    const AESGCMCC26XX_HWAttrs aesgcmCC26XXHWAttrs[CC2640R2_LAUNCHXL_AESGCMCOUNT] = {
            .intPriority       = ~0,
    const AESGCM_Config AESGCM_config[CC2640R2_LAUNCHXL_AESGCMCOUNT] = {
             .object  = &aesgcmCC26XXObjects[CC2640R2_LAUNCHXL_AESGCM0],
             .hwAttrs = &aesgcmCC26XXHWAttrs[CC2640R2_LAUNCHXL_AESGCM0]
    const uint_least8_t AESGCM_count = CC2640R2_LAUNCHXL_AESGCMCOUNT;
     *  =============================== AESCBC ===============================
    #include <ti/drivers/AESCBC.h>
    #include <ti/drivers/aescbc/AESCBCCC26XX.h>
    AESCBCCC26XX_Object aescbcCC26XXObjects[CC2640R2_LAUNCHXL_AESCBCCOUNT];
    const AESCBCCC26XX_HWAttrs aescbcCC26XXHWAttrs[CC2640R2_LAUNCHXL_AESCBCCOUNT] = {
            .intPriority       = ~0,
    const AESCBC_Config AESCBC_config[CC2640R2_LAUNCHXL_AESCBCCOUNT] = {
             .object  = &aescbcCC26XXObjects[CC2640R2_LAUNCHXL_AESCBC0],
             .hwAttrs = &aescbcCC26XXHWAttrs[CC2640R2_LAUNCHXL_AESCBC0]
    const uint_least8_t AESCBC_count = CC2640R2_LAUNCHXL_AESCBCCOUNT;
     *  =============================== AESCTR ===============================
    #include <ti/drivers/AESCTR.h>
    #include <ti/drivers/aesctr/AESCTRCC26XX.h>
    AESCTRCC26XX_Object aesctrCC26XXObjects[CC2640R2_LAUNCHXL_AESCTRCOUNT];
    const AESCTRCC26XX_HWAttrs aesctrCC26XXHWAttrs[CC2640R2_LAUNCHXL_AESCTRCOUNT] = {
            .intPriority       = ~0,
    const AESCTR_Config AESCTR_config[CC2640R2_LAUNCHXL_AESCTRCOUNT] = {
             .object  = &aesctrCC26XXObjects[CC2640R2_LAUNCHXL_AESCTR0],
             .hwAttrs = &aesctrCC26XXHWAttrs[CC2640R2_LAUNCHXL_AESCTR0]
    const uint_least8_t AESCTR_count = CC2640R2_LAUNCHXL_AESCTRCOUNT;
     *  =============================== AESECB ===============================
    #include <ti/drivers/AESECB.h>
    #include <ti/drivers/aesecb/AESECBCC26XX.h>
    AESECBCC26XX_Object aesecbCC26XXObjects[CC2640R2_LAUNCHXL_AESECBCOUNT];
    const AESECBCC26XX_HWAttrs aesecbCC26XXHWAttrs[CC2640R2_LAUNCHXL_AESECBCOUNT] = {
            .intPriority       = ~0,
    const AESECB_Config AESECB_config[CC2640R2_LAUNCHXL_AESECBCOUNT] = {
             .object  = &aesecbCC26XXObjects[CC2640R2_LAUNCHXL_AESECB0],
             .hwAttrs = &aesecbCC26XXHWAttrs[CC2640R2_LAUNCHXL_AESECB0]
    const uint_least8_t AESECB_count = CC2640R2_LAUNCHXL_AESECBCOUNT;
     *  =============================== AESCTRDRBG ===============================
    #include <ti/drivers/AESCTRDRBG.h>
    #include <ti/drivers/aesctrdrbg/AESCTRDRBGXX.h>
    AESCTRDRBGXX_Object aesctrdrbgXXObjects[CC2640R2_LAUNCHXL_AESCTRDRBGCOUNT];
    const AESCTRDRBGXX_HWAttrs aesctrdrbgXXHWAttrs[CC2640R2_LAUNCHXL_AESCTRDRBGCOUNT] = {
            .aesctrIndex       = CC2640R2_LAUNCHXL_AESCTR0,
    const AESCTRDRBG_Config AESCTRDRBG_config[CC2640R2_LAUNCHXL_AESCTRDRBGCOUNT] = {
             .object  = &aesctrdrbgXXObjects[CC2640R2_LAUNCHXL_AESCTRDRBG0],
             .hwAttrs = &aesctrdrbgXXHWAttrs[CC2640R2_LAUNCHXL_AESCTRDRBG0]
    const uint_least8_t AESCTRDRBG_count = CC2640R2_LAUNCHXL_AESCTRDRBGCOUNT;
     *  =============================== TRNG ===============================
    #include <ti/drivers/TRNG.h>
    #include <ti/drivers/trng/TRNGCC26XX.h>
    TRNGCC26XX_Object trngCC26XXObjects[CC2640R2_LAUNCHXL_TRNGCOUNT];
    const TRNGCC26XX_HWAttrs trngCC26X2HWAttrs[CC2640R2_LAUNCHXL_TRNGCOUNT] = {
            .intPriority       = ~0,
            .swiPriority       = 0,
            .samplesPerCycle   = 240000,
    const TRNG_Config TRNG_config[CC2640R2_LAUNCHXL_TRNGCOUNT] = {
             .object  = &trngCC26XXObjects[CC2640R2_LAUNCHXL_TRNG0],
             .hwAttrs = &trngCC26X2HWAttrs[CC2640R2_LAUNCHXL_TRNG0]
    const uint_least8_t TRNG_count = CC2640R2_LAUNCHXL_TRNGCOUNT;
     *  =============================== Display ===============================
    #include <ti/display/Display.h>
    #include <ti/display/DisplayUart.h>
    #include <ti/display/DisplaySharp.h>
    #ifndef BOARD_DISPLAY_UART_STRBUF_SIZE
    #define BOARD_DISPLAY_UART_STRBUF_SIZE    128
    #endif
    /* This value can be changed to 96 for use with the 430BOOST-SHARP96 BoosterPack. */
    #define BOARD_DISPLAY_SHARP_SIZE    128
    DisplayUart_Object     displayUartObject;
    DisplaySharp_Object    displaySharpObject;
    static char uartStringBuf[BOARD_DISPLAY_UART_STRBUF_SIZE];
    static uint_least8_t sharpDisplayBuf[BOARD_DISPLAY_SHARP_SIZE * BOARD_DISPLAY_SHARP_SIZE / 8];
    const DisplayUart_HWAttrs displayUartHWAttrs = {
        .uartIdx      = CC2640R2_LAUNCHXL_UART0,
        .baudRate     = 115200,
        .mutexTimeout = (unsigned int)(-1),
        .strBuf       = uartStringBuf,
        .strBufLen    = BOARD_DISPLAY_UART_STRBUF_SIZE,
    const DisplaySharp_HWAttrsV1 displaySharpHWattrs = {
        .spiIndex    = CC2640R2_LAUNCHXL_SPI0,
        .csPin       = CC2640R2_LAUNCHXL_GPIO_LCD_CS,
        .powerPin    = CC2640R2_LAUNCHXL_GPIO_LCD_POWER,
        .enablePin   = CC2640R2_LAUNCHXL_GPIO_LCD_ENABLE,
        .pixelWidth  = BOARD_DISPLAY_SHARP_SIZE,
        .pixelHeight = BOARD_DISPLAY_SHARP_SIZE,
        .displayBuf  = sharpDisplayBuf,
    #ifndef BOARD_DISPLAY_USE_UART
    #define BOARD_DISPLAY_USE_UART 1
    #endif
    #ifndef BOARD_DISPLAY_USE_UART_ANSI
    #define BOARD_DISPLAY_USE_UART_ANSI 0
    #endif
    #ifndef BOARD_DISPLAY_USE_LCD
    #define BOARD_DISPLAY_USE_LCD 0
    #endif
     * This #if/#else is needed to workaround a problem with the
     * IAR compiler. The IAR compiler doesn't like the empty array
     * initialization. (IAR Error[Pe1345])
    #if (BOARD_DISPLAY_USE_UART || BOARD_DISPLAY_USE_LCD)
    const Display_Config Display_config[] = {
    #if (BOARD_DISPLAY_USE_UART)
    #  if (BOARD_DISPLAY_USE_UART_ANSI)
            .fxnTablePtr = &DisplayUartAnsi_fxnTable,
    #  else /* Default to minimal UART with no cursor placement */
            .fxnTablePtr = &DisplayUartMin_fxnTable,
    #  endif
            .object      = &displayUartObject,
            .hwAttrs     = &displayUartHWAttrs,
    #endif
    #if (BOARD_DISPLAY_USE_LCD)
            .fxnTablePtr = &DisplaySharp_fxnTable,
            .object      = &displaySharpObject,
            .hwAttrs     = &displaySharpHWattrs
    #endif
    const uint_least8_t Display_count = sizeof(Display_config) / sizeof(Display_Config);
    #else
    const Display_Config *Display_config = NULL;
    const uint_least8_t Display_count = 0;
    #endif /* (BOARD_DISPLAY_USE_UART || BOARD_DISPLAY_USE_LCD) */
     *  =============================== GPIO ===============================
    #include <ti/drivers/GPIO.h>
    #include <ti/drivers/gpio/GPIOCC26XX.h>
     * Array of Pin configurations
     * NOTE: The order of the pin configurations must coincide with what was
     *       defined in CC2640R2_LAUNCHXL.h
     * NOTE: Pins not used for interrupts should be placed at the end of the
     *       array. Callback entries can be omitted from callbacks array to
     *       reduce memory usage.
    GPIO_PinConfig gpioPinConfigs[] = {
        /* Input pins */
        GPIOCC26XX_DIO_13 | GPIO_DO_NOT_CONFIG,  /* Button 0 */
        GPIOCC26XX_DIO_14 | GPIO_DO_NOT_CONFIG,  /* Button 1 */
        GPIOCC26XX_DIO_15 | GPIO_DO_NOT_CONFIG,  /* CC2640R2_LAUNCHXL_SPI_MASTER_READY */
        GPIOCC26XX_DIO_21 | GPIO_DO_NOT_CONFIG,  /* CC2640R2_LAUNCHXL_SPI_SLAVE_READY */
        /* Output pins */
        GPIOCC26XX_DIO_07 | GPIO_DO_NOT_CONFIG,  /* Green LED */
        GPIOCC26XX_DIO_06 | GPIO_DO_NOT_CONFIG,  /* Red LED */
        GPIOCC26XX_DIO_30 | GPIO_DO_NOT_CONFIG,  /* TMP116_EN */
        /* SPI Flash CSN */
        GPIOCC26XX_DIO_20 | GPIO_DO_NOT_CONFIG,
        /* SD CS */
        /* Sharp Display - GPIO configurations will be done in the Display files */
        GPIOCC26XX_DIO_24 | GPIO_DO_NOT_CONFIG, /* SPI chip select */
        GPIOCC26XX_DIO_22 | GPIO_DO_NOT_CONFIG, /* LCD power control */
        GPIOCC26XX_DIO_23 | GPIO_DO_NOT_CONFIG, /*LCD enable */
     * Array of callback function pointers
     *       defined in CC2640R2_LAUNCH.h
     * NOTE: Pins not used for interrupts can be omitted from callbacks array to
     *       reduce memory usage (if placed at end of gpioPinConfigs array).
    GPIO_CallbackFxn gpioCallbackFunctions[] = {
        NULL,  /* Button 0 */
        NULL,  /* Button 1 */
        NULL,  /* CC2640R2_LAUNCHXL_SPI_MASTER_READY */
        NULL,  /* CC2640R2_LAUNCHXL_SPI_SLAVE_READY */
    const GPIOCC26XX_Config GPIOCC26XX_config = {
        .pinConfigs         = (GPIO_PinConfig *)gpioPinConfigs,
        .callbacks          = (GPIO_CallbackFxn *)gpioCallbackFunctions,
        .numberOfPinConfigs = CC2640R2_LAUNCHXL_GPIOCOUNT,
        .numberOfCallbacks  = sizeof(gpioCallbackFunctions)/sizeof(GPIO_CallbackFxn),
        .intPriority        = (~0)
     *  =============================== GPTimer ===============================
     *  Remove unused entries to reduce flash usage both in Board.c and Board.h
    #include <ti/drivers/timer/GPTimerCC26XX.h>
    GPTimerCC26XX_Object gptimerCC26XXObjects[CC2640R2_LAUNCHXL_GPTIMERCOUNT];
    const GPTimerCC26XX_HWAttrs gptimerCC26xxHWAttrs[CC2640R2_LAUNCHXL_GPTIMERPARTSCOUNT] = {
        { .baseAddr = GPT0_BASE, .intNum = INT_GPT0A, .intPriority = (~0), .powerMngrId = PowerCC26XX_PERIPH_GPT0, .pinMux = GPT_PIN_0A, },
        { .baseAddr = GPT0_BASE, .intNum = INT_GPT0B, .intPriority = (~0), .powerMngrId = PowerCC26XX_PERIPH_GPT0, .pinMux = GPT_PIN_0B, },
        { .baseAddr = GPT1_BASE, .intNum = INT_GPT1A, .intPriority = (~0), .powerMngrId = PowerCC26XX_PERIPH_GPT1, .pinMux = GPT_PIN_1A, },
        { .baseAddr = GPT1_BASE, .intNum = INT_GPT1B, .intPriority = (~0), .powerMngrId = PowerCC26XX_PERIPH_GPT1, .pinMux = GPT_PIN_1B, },
        { .baseAddr = GPT2_BASE, .intNum = INT_GPT2A, .intPriority = (~0), .powerMngrId = PowerCC26XX_PERIPH_GPT2, .pinMux = GPT_PIN_2A, },
        { .baseAddr = GPT2_BASE, .intNum = INT_GPT2B, .intPriority = (~0), .powerMngrId = PowerCC26XX_PERIPH_GPT2, .pinMux = GPT_PIN_2B, },
        { .baseAddr = GPT3_BASE, .intNum = INT_GPT3A, .intPriority = (~0), .powerMngrId = PowerCC26XX_PERIPH_GPT3, .pinMux = GPT_PIN_3A, },
        { .baseAddr = GPT3_BASE, .intNum = INT_GPT3B, .intPriority = (~0), .powerMngrId = PowerCC26XX_PERIPH_GPT3, .pinMux = GPT_PIN_3B, },
    const GPTimerCC26XX_Config GPTimerCC26XX_config[CC2640R2_LAUNCHXL_GPTIMERPARTSCOUNT] = {
        { &gptimerCC26XXObjects[CC2640R2_LAUNCHXL_GPTIMER0], &gptimerCC26xxHWAttrs[CC2640R2_LAUNCHXL_GPTIMER0A], GPT_A },
        { &gptimerCC26XXObjects[CC2640R2_LAUNCHXL_GPTIMER0], &gptimerCC26xxHWAttrs[CC2640R2_LAUNCHXL_GPTIMER0B], GPT_B },
        { &gptimerCC26XXObjects[CC2640R2_LAUNCHXL_GPTIMER1], &gptimerCC26xxHWAttrs[CC2640R2_LAUNCHXL_GPTIMER1A], GPT_A },
        { &gptimerCC26XXObjects[CC2640R2_LAUNCHXL_GPTIMER1], &gptimerCC26xxHWAttrs[CC2640R2_LAUNCHXL_GPTIMER1B], GPT_B },
        { &gptimerCC26XXObjects[CC2640R2_LAUNCHXL_GPTIMER2], &gptimerCC26xxHWAttrs[CC2640R2_LAUNCHXL_GPTIMER2A], GPT_A },
        { &gptimerCC26XXObjects[CC2640R2_LAUNCHXL_GPTIMER2], &gptimerCC26xxHWAttrs[CC2640R2_LAUNCHXL_GPTIMER2B], GPT_B },
        { &gptimerCC26XXObjects[CC2640R2_LAUNCHXL_GPTIMER3], &gptimerCC26xxHWAttrs[CC2640R2_LAUNCHXL_GPTIMER3A], GPT_A },
        { &gptimerCC26XXObjects[CC2640R2_LAUNCHXL_GPTIMER3], &gptimerCC26xxHWAttrs[CC2640R2_LAUNCHXL_GPTIMER3B], GPT_B },
     *  =============================== I2C ===============================
    #include <ti/drivers/I2C.h>
    #include <ti/drivers/i2c/I2CCC26XX.h>
    I2CCC26XX_Object i2cCC26xxObjects[CC2640R2_LAUNCHXL_I2CCOUNT];
    const I2CCC26XX_HWAttrsV1 i2cCC26xxHWAttrs[CC2640R2_LAUNCHXL_I2CCOUNT] = {
            .baseAddr    = I2C0_BASE,
            .powerMngrId = PowerCC26XX_PERIPH_I2C0,
            .intNum      = INT_I2C_IRQ,
            .intPriority = ~0,
            .swiPriority = 0,
            .sdaPin      = CC2640R2_LAUNCHXL_I2C0_SDA0,
            .sclPin      = CC2640R2_LAUNCHXL_I2C0_SCL0,
    const I2C_Config I2C_config[CC2640R2_LAUNCHXL_I2CCOUNT] = {
            .fxnTablePtr = &I2CCC26XX_fxnTable,
            .object      = &i2cCC26xxObjects[CC2640R2_LAUNCHXL_I2C0],
            .hwAttrs     = &i2cCC26xxHWAttrs[CC2640R2_LAUNCHXL_I2C0]
    const uint_least8_t I2C_count = CC2640R2_LAUNCHXL_I2CCOUNT;
     *  =============================== I2S ===============================
    #include <ti/drivers/I2S.h>
    #include <ti/drivers/i2s/I2SCC26XX.h>
    I2SCC26XX_Object i2sCC26XXObjects[CC2640R2_LAUNCHXL_I2SCOUNT];
    const I2SCC26XX_HWAttrs i2sCC26XXHWAttrs[CC2640R2_LAUNCHXL_I2SCOUNT] = {
            .pinSD1      =  CC2640R2_LAUNCHXL_I2S_ADI,
            .pinSD0      =  CC2640R2_LAUNCHXL_I2S_ADO,
            .pinSCK      =  CC2640R2_LAUNCHXL_I2S_BCLK,
            .pinMCLK     =  CC2640R2_LAUNCHXL_I2S_MCLK,
            .pinWS       =  CC2640R2_LAUNCHXL_I2S_WCLK,
            .intPriority = ~0,
    const I2S_Config I2S_config[CC2640R2_LAUNCHXL_I2SCOUNT] = {
            .object      = &i2sCC26XXObjects[CC2640R2_LAUNCHXL_I2S0],
            .hwAttrs     = &i2sCC26XXHWAttrs[CC2640R2_LAUNCHXL_I2S0]
    const uint_least8_t I2S_count = CC2640R2_LAUNCHXL_I2SCOUNT;
     *  =============================== NVS ===============================
    #include <ti/drivers/NVS.h>
    #include <ti/drivers/nvs/NVSSPI25X.h>
    #include <ti/drivers/nvs/NVSCC26XX.h>
    #define NVS_REGIONS_BASE 0x1A000
    #define SECTORSIZE       0x1000
    #define REGIONSIZE       (SECTORSIZE * 4)
    #ifndef Board_EXCLUDE_NVS_INTERNAL_FLASH
     * Reserve flash sectors for NVS driver use by placing an uninitialized byte
     * array at the desired flash address.
    #if defined(__TI_COMPILER_VERSION__)
     * Place uninitialized array at NVS_REGIONS_BASE
    #pragma LOCATION(flashBuf, NVS_REGIONS_BASE);
    #pragma NOINIT(flashBuf);
    static char flashBuf[REGIONSIZE];
    #elif defined(__IAR_SYSTEMS_ICC__)
    static __no_init char flashBuf[REGIONSIZE] @ NVS_REGIONS_BASE;
    #elif defined(__GNUC__)
     * Place the flash buffers in the .nvs section created in the gcc linker file.
     * The .nvs section enforces alignment on a sector boundary but may
     * be placed anywhere in flash memory.  If desired the .nvs section can be set
     * to a fixed address by changing the following in the gcc linker file:
     * .nvs (FIXED_FLASH_ADDR) (NOLOAD) : AT (FIXED_FLASH_ADDR) {
     *      *(.nvs)
     * } > REGION_TEXT
    __attribute__ ((section (".nvs")))
    #endif
    /* Allocate objects for NVS Internal Regions */
    NVSCC26XX_Object nvsCC26xxObjects[1];
    /* Hardware attributes for NVS Internal Regions */
    const NVSCC26XX_HWAttrs nvsCC26xxHWAttrs[1] = {
            .regionBase = (void *)flashBuf,
            .regionSize = REGIONSIZE,
    #endif /* Board_EXCLUDE_NVS_INTERNAL_FLASH */
    #ifndef Board_EXCLUDE_NVS_EXTERNAL_FLASH
    #define SPISECTORSIZE    0x1000
    #define SPIREGIONSIZE    (SPISECTORSIZE * 32)
    #define VERIFYBUFSIZE    64
    static uint8_t verifyBuf[VERIFYBUFSIZE];
    /* Allocate objects for NVS External Regions */
    NVSSPI25X_Object nvsSPI25XObjects[1];
    /* Hardware attributes for NVS External Regions */
    const NVSSPI25X_HWAttrs nvsSPI25XHWAttrs[1] = {
            .regionBaseOffset = 0,
            .regionSize = SPIREGIONSIZE,
            .sectorSize = SPISECTORSIZE,
            .verifyBuf = verifyBuf,
            .verifyBufSize = VERIFYBUFSIZE,
            .spiHandle = NULL,
            .spiIndex = 0,
            .spiBitRate = 4000000,
            .spiCsnGpioIndex = CC2640R2_LAUNCHXL_GPIO_SPI_FLASH_CS,
            .statusPollDelayUs = 100,
    #endif /* Board_EXCLUDE_NVS_EXTERNAL_FLASH */
    /* NVS Region index 0 and 1 refer to NVS and NVS SPI respectively */
    const NVS_Config NVS_config[CC2640R2_LAUNCHXL_NVSCOUNT] = {
            .fxnTablePtr = &NVSCC26XX_fxnTable,
            .object = &nvsCC26xxObjects[0],
            .hwAttrs = &nvsCC26xxHWAttrs[0],
    #endif
            .fxnTablePtr = &NVSSPI25X_fxnTable,
            .object = &nvsSPI25XObjects[0],
            .hwAttrs = &nvsSPI25XHWAttrs[0],
    #endif
    const uint_least8_t NVS_count = CC2640R2_LAUNCHXL_NVSCOUNT;
     *  =============================== PIN ===============================
    #include <ti/drivers/PIN.h>
    #include <ti/drivers/pin/PINCC26XX.h>
    const PIN_Config BoardGpioInitTable[] = {
        CC2640R2_LAUNCHXL_PIN_RLED | PIN_GPIO_OUTPUT_EN | PIN_GPIO_LOW | PIN_PUSHPULL | PIN_DRVSTR_MAX,       /* LED initially off */
        CC2640R2_LAUNCHXL_PIN_GLED | PIN_GPIO_OUTPUT_EN | PIN_GPIO_LOW | PIN_PUSHPULL | PIN_DRVSTR_MAX,       /* LED initially off */
        CC2640R2_LAUNCHXL_PIN_BTN1 | PIN_INPUT_EN | PIN_PULLUP | PIN_IRQ_BOTHEDGES | PIN_HYSTERESIS,          /* Button is active low */
        CC2640R2_LAUNCHXL_PIN_BTN2 | PIN_INPUT_EN | PIN_PULLUP | PIN_IRQ_BOTHEDGES | PIN_HYSTERESIS,          /* Button is active low */
        CC2640R2_LAUNCHXL_SPI_FLASH_CS | PIN_GPIO_OUTPUT_EN | PIN_GPIO_HIGH | PIN_PUSHPULL | PIN_DRVSTR_MIN,  /* External flash chip select */
        CC2640R2_LAUNCHXL_UART_RX | PIN_INPUT_EN | PIN_PULLDOWN,                                              /* UART RX via debugger back channel */
        CC2640R2_LAUNCHXL_UART_TX | PIN_GPIO_OUTPUT_EN | PIN_GPIO_LOW | PIN_PUSHPULL,                         /* UART TX via debugger back channel */
        CC2640R2_LAUNCHXL_SPI0_MOSI | PIN_INPUT_EN | PIN_PULLDOWN,                                            /* SPI master out - slave in */
        CC2640R2_LAUNCHXL_SPI0_MISO | PIN_INPUT_EN | PIN_PULLDOWN,                                            /* SPI master in - slave out */
        CC2640R2_LAUNCHXL_SPI0_CLK | PIN_INPUT_EN | PIN_PULLDOWN,                                             /* SPI clock */
        PIN_TERMINATE
    const PINCC26XX_HWAttrs PINCC26XX_hwAttrs = {
        .intPriority = ~0,
        .swiPriority = 0
     *  =============================== Power ===============================
    #include <ti/drivers/Power.h>
    #include <ti/drivers/power/PowerCC26XX.h>
    const PowerCC26XX_Config PowerCC26XX_config = {
        .policyInitFxn      = NULL,
        .policyFxn          = &PowerCC26XX_standbyPolicy,
        .calibrateFxn       = &PowerCC26XX_calibrate,
        .enablePolicy       = true,
        .calibrateRCOSC_LF  = true,
        .calibrateRCOSC_HF  = true,
     *  =============================== PWM ===============================
    #include <ti/drivers/PWM.h>
    #include <ti/drivers/pwm/PWMTimerCC26XX.h>
    PWMTimerCC26XX_Object pwmtimerCC26xxObjects[CC2640R2_LAUNCHXL_PWMCOUNT];
    const PWMTimerCC26XX_HwAttrs pwmtimerCC26xxHWAttrs[CC2640R2_LAUNCHXL_PWMCOUNT] = {
        { .pwmPin = CC2640R2_LAUNCHXL_PWMPIN0, .gpTimerUnit = CC2640R2_LAUNCHXL_GPTIMER0A },
        { .pwmPin = CC2640R2_LAUNCHXL_PWMPIN1, .gpTimerUnit = CC2640R2_LAUNCHXL_GPTIMER0B },
        { .pwmPin = CC2640R2_LAUNCHXL_PWMPIN2, .gpTimerUnit = CC2640R2_LAUNCHXL_GPTIMER1A },
        { .pwmPin = CC2640R2_LAUNCHXL_PWMPIN3, .gpTimerUnit = CC2640R2_LAUNCHXL_GPTIMER1B },
        { .pwmPin = CC2640R2_LAUNCHXL_PWMPIN4, .gpTimerUnit = CC2640R2_LAUNCHXL_GPTIMER2A },
        { .pwmPin = CC2640R2_LAUNCHXL_PWMPIN5, .gpTimerUnit = CC2640R2_LAUNCHXL_GPTIMER2B },
        { .pwmPin = CC2640R2_LAUNCHXL_PWMPIN6, .gpTimerUnit = CC2640R2_LAUNCHXL_GPTIMER3A },
        { .pwmPin = CC2640R2_LAUNCHXL_PWMPIN7, .gpTimerUnit = CC2640R2_LAUNCHXL_GPTIMER3B },
    const PWM_Config PWM_config[CC2640R2_LAUNCHXL_PWMCOUNT] = {
        { &PWMTimerCC26XX_fxnTable, &pwmtimerCC26xxObjects[CC2640R2_LAUNCHXL_PWM0], &pwmtimerCC26xxHWAttrs[CC2640R2_LAUNCHXL_PWM0] },
        { &PWMTimerCC26XX_fxnTable, &pwmtimerCC26xxObjects[CC2640R2_LAUNCHXL_PWM1], &pwmtimerCC26xxHWAttrs[CC2640R2_LAUNCHXL_PWM1] },
        { &PWMTimerCC26XX_fxnTable, &pwmtimerCC26xxObjects[CC2640R2_LAUNCHXL_PWM2], &pwmtimerCC26xxHWAttrs[CC2640R2_LAUNCHXL_PWM2] },
        { &PWMTimerCC26XX_fxnTable, &pwmtimerCC26xxObjects[CC2640R2_LAUNCHXL_PWM3], &pwmtimerCC26xxHWAttrs[CC2640R2_LAUNCHXL_PWM3] },
        { &PWMTimerCC26XX_fxnTable, &pwmtimerCC26xxObjects[CC2640R2_LAUNCHXL_PWM4], &pwmtimerCC26xxHWAttrs[CC2640R2_LAUNCHXL_PWM4] },
        { &PWMTimerCC26XX_fxnTable, &pwmtimerCC26xxObjects[CC2640R2_LAUNCHXL_PWM5], &pwmtimerCC26xxHWAttrs[CC2640R2_LAUNCHXL_PWM5] },
        { &PWMTimerCC26XX_fxnTable, &pwmtimerCC26xxObjects[CC2640R2_LAUNCHXL_PWM6], &pwmtimerCC26xxHWAttrs[CC2640R2_LAUNCHXL_PWM6] },
        { &PWMTimerCC26XX_fxnTable, &pwmtimerCC26xxObjects[CC2640R2_LAUNCHXL_PWM7], &pwmtimerCC26xxHWAttrs[CC2640R2_LAUNCHXL_PWM7] },
    const uint_least8_t PWM_count = CC2640R2_LAUNCHXL_PWMCOUNT;
     *  =============================== RF Driver ===============================
    #include <ti/drivers/rf/RF.h>
    const RFCC26XX_HWAttrsV2 RFCC26XX_hwAttrs = {
        .hwiPriority        = ~0,       /* Lowest HWI priority */
        .swiPriority        = 0,        /* Lowest SWI priority */
        .xoscHfAlwaysNeeded = true,     /* Keep XOSC dependency while in standby */
        .globalCallback     = NULL,     /* No board specific callback */
        .globalEventMask    = 0         /* No events subscribed to */
     *  =============================== SD ===============================
    #include <ti/drivers/SD.h>
    #include <ti/drivers/sd/SDSPI.h>
    SDSPI_Object sdspiObjects[CC2640R2_LAUNCHXL_SDCOUNT];
    const SDSPI_HWAttrs sdspiHWAttrs[CC2640R2_LAUNCHXL_SDCOUNT] = {
            .spiCsGpioIndex = CC2640R2_LAUNCHXL_SDSPI_CS
    const SD_Config SD_config[CC2640R2_LAUNCHXL_SDCOUNT] = {
            .fxnTablePtr = &SDSPI_fxnTable,
            .object = &sdspiObjects[CC2640R2_LAUNCHXL_SDSPI0],
            .hwAttrs = &sdspiHWAttrs[CC2640R2_LAUNCHXL_SDSPI0]
    const uint_least8_t SD_count = CC2640R2_LAUNCHXL_SDCOUNT;
     *  =============================== SPI DMA ===============================
    #include <ti/drivers/SPI.h>
    #include <ti/drivers/spi/SPICC26XXDMA.h>
    SPICC26XXDMA_Object spiCC26XXDMAObjects[CC2640R2_LAUNCHXL_SPICOUNT];
     * NOTE: The SPI instances below can be used by the SD driver to communicate
     * with a SD card via SPI.  The 'defaultTxBufValue' fields below are set to 0xFF
     * to satisfy the SDSPI driver requirement.
    const SPICC26XXDMA_HWAttrsV1 spiCC26XXDMAHWAttrs[CC2640R2_LAUNCHXL_SPICOUNT] = {
            .baseAddr           = SSI0_BASE,
            .intNum             = INT_SSI0_COMB,
            .intPriority        = ~0,
            .swiPriority        = 0,
            .powerMngrId        = PowerCC26XX_PERIPH_SSI0,
            .defaultTxBufValue  = 0xFF,
            .rxChannelBitMask   = 1<<UDMA_CHAN_SSI0_RX,
            .txChannelBitMask   = 1<<UDMA_CHAN_SSI0_TX,
            .mosiPin            = CC2640R2_LAUNCHXL_SPI0_MOSI,
            .misoPin            = CC2640R2_LAUNCHXL_SPI0_MISO,
            .clkPin             = CC2640R2_LAUNCHXL_SPI0_CLK,
            .csnPin             = CC2640R2_LAUNCHXL_SPI0_CSN,
            .minDmaTransferSize = 10
            .baseAddr           = SSI1_BASE,
            .intNum             = INT_SSI1_COMB,
            .intPriority        = ~0,
            .swiPriority        = 0,
            .powerMngrId        = PowerCC26XX_PERIPH_SSI1,
            .rxChannelBitMask   = 1<<UDMA_CHAN_SSI1_RX,
            .txChannelBitMask   = 1<<UDMA_CHAN_SSI1_TX,
            .mosiPin            = CC2640R2_LAUNCHXL_SPI1_MOSI,
            .misoPin            = CC2640R2_LAUNCHXL_SPI1_MISO,
            .clkPin             = CC2640R2_LAUNCHXL_SPI1_CLK,
            .csnPin             = CC2640R2_LAUNCHXL_SPI1_CSN,
    const SPI_Config SPI_config[CC2640R2_LAUNCHXL_SPICOUNT] = {
             .fxnTablePtr = &SPICC26XXDMA_fxnTable,
             .object      = &spiCC26XXDMAObjects[CC2640R2_LAUNCHXL_SPI0],
             .hwAttrs     = &spiCC26XXDMAHWAttrs[CC2640R2_LAUNCHXL_SPI0]
             .object      = &spiCC26XXDMAObjects[CC2640R2_LAUNCHXL_SPI1],
             .hwAttrs     = &spiCC26XXDMAHWAttrs[CC2640R2_LAUNCHXL_SPI1]
    const uint_least8_t SPI_count = CC2640R2_LAUNCHXL_SPICOUNT;
     *  =============================== UART ===============================
    #include <ti/drivers/UART.h>
    #include <ti/drivers/uart/UARTCC26XX.h>
    UARTCC26XX_Object uartCC26XXObjects[CC2640R2_LAUNCHXL_UARTCOUNT];
    uint8_t uartCC26XXRingBuffer[CC2640R2_LAUNCHXL_UARTCOUNT][32];
    const UARTCC26XX_HWAttrsV2 uartCC26XXHWAttrs[CC2640R2_LAUNCHXL_UARTCOUNT] = {
            .baseAddr       = UART0_BASE,
            .powerMngrId    = PowerCC26XX_PERIPH_UART0,
            .intNum         = INT_UART0_COMB,
            .intPriority    = ~0,
            .swiPriority    = 0,
            .txPin          = CC2640R2_LAUNCHXL_UART_TX,
            .rxPin          = CC2640R2_LAUNCHXL_UART_RX,
            .ctsPin         = PIN_UNASSIGNED,
            .rtsPin         = PIN_UNASSIGNED,
            .ringBufPtr     = uartCC26XXRingBuffer[CC2640R2_LAUNCHXL_UART0],
            .ringBufSize    = sizeof(uartCC26XXRingBuffer[CC2640R2_LAUNCHXL_UART0]),
            .txIntFifoThr   = UARTCC26XX_FIFO_THRESHOLD_1_8,
            .rxIntFifoThr   = UARTCC26XX_FIFO_THRESHOLD_4_8,
            .errorFxn       = NULL
    const UART_Config UART_config[CC2640R2_LAUNCHXL_UARTCOUNT] = {
            .fxnTablePtr = &UARTCC26XX_fxnTable,
            .object      = &uartCC26XXObjects[CC2640R2_LAUNCHXL_UART0],
            .hwAttrs     = &uartCC26XXHWAttrs[CC2640R2_LAUNCHXL_UART0]
    const uint_least8_t UART_count = CC2640R2_LAUNCHXL_UARTCOUNT;
     *  =============================== UDMA ===============================
    #include <ti/drivers/dma/UDMACC26XX.h>
    UDMACC26XX_Object udmaObjects[CC2640R2_LAUNCHXL_UDMACOUNT];
    const UDMACC26XX_HWAttrs udmaHWAttrs[CC2640R2_LAUNCHXL_UDMACOUNT] = {
            .baseAddr    = UDMA0_BASE,
            .powerMngrId = PowerCC26XX_PERIPH_UDMA,
            .intNum      = INT_DMA_ERR,
            .intPriority = ~0
    const UDMACC26XX_Config UDMACC26XX_config[CC2640R2_LAUNCHXL_UDMACOUNT] = {
             .object  = &udmaObjects[CC2640R2_LAUNCHXL_UDMA0],
             .hwAttrs = &udmaHWAttrs[CC2640R2_LAUNCHXL_UDMA0]
     *  =============================== Watchdog ===============================
    #include <ti/drivers/Watchdog.h>
    #include <ti/drivers/watchdog/WatchdogCC26XX.h>
    WatchdogCC26XX_Object watchdogCC26XXObjects[CC2640R2_LAUNCHXL_WATCHDOGCOUNT];
    const WatchdogCC26XX_HWAttrs watchdogCC26XXHWAttrs[CC2640R2_LAUNCHXL_WATCHDOGCOUNT] = {
            .baseAddr    = WDT_BASE,
            .reloadValue = 1000 /* Reload value in milliseconds */
    const Watchdog_Config Watchdog_config[CC2640R2_LAUNCHXL_WATCHDOGCOUNT] = {
            .fxnTablePtr = &WatchdogCC26XX_fxnTable,
            .object      = &watchdogCC26XXObjects[CC2640R2_LAUNCHXL_WATCHDOG0],
            .hwAttrs     = &watchdogCC26XXHWAttrs[CC2640R2_LAUNCHXL_WATCHDOG0]
    const uint_least8_t Watchdog_count = CC2640R2_LAUNCHXL_WATCHDOGCOUNT;
     *  Board-specific initialization function to disable external flash.
     *  This function is defined in the file CC2640R2_LAUNCHXL_fxns.c
    extern void Board_initHook(void);
     *  ======== CC2640R2_LAUNCHXL_initGeneral ========
    void CC2640R2_LAUNCHXL_initGeneral(void)
        Power_init();
        if (PIN_init(BoardGpioInitTable) != PIN_SUCCESS) {
            /* Error with PIN_init */
            while (1);
        /* Perform board-specific initialization */
        Board_initHook();
     *  ======== Board_init ========
    void Board_init(void)
        CC2640R2_LAUNCHXL_initGeneral();
    CC2640R2_LAUNCHXL.h:
     * are met:
     *  @file       CC2640R2_LAUNCHXL.h
     *  @brief      CC2640R2 LaunchPad Board Specific header file.
     *  This board file is made for the 7x7 mm QFN package, to convert this board
     *  file to use for other smaller device packages(5x5 mm and 4x4 mm QFN), the
     *  board will need to be modified since all the IO pins are not available for
     *  smaller packages. Note that the 2.7 x 2.7 mm WCSP package should use a
     *  separate board file also included within the SDK.
     *  Refer to the datasheet for all the package options and IO descriptions:
     *  www.ti.com/.../cc2640r2f.pdf
     *  For example, to change to the 4x4 package, remove all defines for all IOs
     *  not available (IOID_10 and higher) since the 4x4 package
     *  has only 10 DIO pins as listed in the datasheet. Remove the modules/pins
     *  not used including ADC, Display, SPI1, LED, and PIN due to limited pins.
    #ifndef __CC2640R2_LAUNCHXL_BOARD_H__
    #define __CC2640R2_LAUNCHXL_BOARD_H__
    #ifdef __cplusplus
    extern "C" {
    #endif
    /* Includes */
    /* Externs */
    extern const PIN_Config BoardGpioInitTable[];
    /* Defines */
    #define CC2640R2_LAUNCHXL
    /* Mapping of pins to board signals using general board aliases
     *      <board signal alias>                  <pin mapping>
    /* Analog Capable DIOs */
    #define CC2640R2_LAUNCHXL_DIO23_ANALOG          IOID_23
    #define CC2640R2_LAUNCHXL_DIO24_ANALOG          IOID_24
    #define CC2640R2_LAUNCHXL_DIO25_ANALOG          IOID_25
    #define CC2640R2_LAUNCHXL_DIO26_ANALOG          IOID_26
    #define CC2640R2_LAUNCHXL_DIO27_ANALOG          IOID_27
    #define CC2640R2_LAUNCHXL_DIO28_ANALOG          IOID_28
    #define CC2640R2_LAUNCHXL_DIO29_ANALOG          IOID_29
    #define CC2640R2_LAUNCHXL_DIO30_ANALOG          IOID_30
    /* Digital IOs */
    #define CC2640R2_LAUNCHXL_DIO0                  IOID_0
    #define CC2640R2_LAUNCHXL_DIO1_RFSW             IOID_1
    #define CC2640R2_LAUNCHXL_DIO12                 IOID_12
    #define CC2640R2_LAUNCHXL_DIO15                 IOID_15
    #define CC2640R2_LAUNCHXL_DIO16_TDO             IOID_16
    #define CC2640R2_LAUNCHXL_DIO17_TDI             IOID_17
    #define CC2640R2_LAUNCHXL_DIO21                 IOID_21
    #define CC2640R2_LAUNCHXL_DIO22                 IOID_22
    /* Discrete Inputs */
    #define CC2640R2_LAUNCHXL_PIN_BTN1              IOID_13
    #define CC2640R2_LAUNCHXL_PIN_BTN2              IOID_14
    /* GPIO */
    #define CC2640R2_LAUNCHXL_GPIO_LED_ON           1
    #define CC2640R2_LAUNCHXL_GPIO_LED_OFF          0
    /* I2C */
    #define CC2640R2_LAUNCHXL_I2C0_SCL0             IOID_4
    #define CC2640R2_LAUNCHXL_I2C0_SDA0             IOID_5
    /* I2S */
    #define CC2640R2_LAUNCHXL_I2S_ADO               IOID_0
    #define CC2640R2_LAUNCHXL_I2S_ADI               IOID_1
    #define CC2640R2_LAUNCHXL_I2S_BCLK              IOID_30
    #define CC2640R2_LAUNCHXL_I2S_MCLK              PIN_UNASSIGNED
    #define CC2640R2_LAUNCHXL_I2S_WCLK              IOID_29
    /* LEDs */
    #define CC2640R2_LAUNCHXL_PIN_LED_ON            1
    #define CC2640R2_LAUNCHXL_PIN_LED_OFF           0
    #define CC2640R2_LAUNCHXL_PIN_RLED              IOID_6
    #define CC2640R2_LAUNCHXL_PIN_GLED              IOID_7
    /* PWM Outputs */
    #define CC2640R2_LAUNCHXL_PWMPIN0               CC2640R2_LAUNCHXL_PIN_RLED
    #define CC2640R2_LAUNCHXL_PWMPIN1               CC2640R2_LAUNCHXL_PIN_GLED
    #define CC2640R2_LAUNCHXL_PWMPIN2               PIN_UNASSIGNED
    #define CC2640R2_LAUNCHXL_PWMPIN3               PIN_UNASSIGNED
    #define CC2640R2_LAUNCHXL_PWMPIN4               PIN_UNASSIGNED
    #define CC2640R2_LAUNCHXL_PWMPIN5               PIN_UNASSIGNED
    #define CC2640R2_LAUNCHXL_PWMPIN6               PIN_UNASSIGNED
    #define CC2640R2_LAUNCHXL_PWMPIN7               PIN_UNASSIGNED
    /* SPI */
    #define CC2640R2_LAUNCHXL_SPI_FLASH_CS          IOID_20
    #define CC2640R2_LAUNCHXL_FLASH_CS_ON           0
    #define CC2640R2_LAUNCHXL_FLASH_CS_OFF          1
    /* SPI Board */
    #define CC2640R2_LAUNCHXL_SPI0_MISO             IOID_8          /* RF1.20 */
    #define CC2640R2_LAUNCHXL_SPI0_MOSI             IOID_9          /* RF1.18 */
    #define CC2640R2_LAUNCHXL_SPI0_CLK              IOID_10         /* RF1.16 */
    #define CC2640R2_LAUNCHXL_SPI0_CSN              IOID_11
    #define CC2640R2_LAUNCHXL_SPI1_MISO             PIN_UNASSIGNED
    #define CC2640R2_LAUNCHXL_SPI1_MOSI             PIN_UNASSIGNED
    #define CC2640R2_LAUNCHXL_SPI1_CLK              PIN_UNASSIGNED
    #define CC2640R2_LAUNCHXL_SPI1_CSN              PIN_UNASSIGNED
    /* UART Board */
    #define CC2640R2_LAUNCHXL_UART_RX               IOID_2          /* RXD */
    #define CC2640R2_LAUNCHXL_UART_TX               IOID_3          /* TXD */
    #define CC2640R2_LAUNCHXL_UART_CTS              IOID_19         /* CTS */
    #define CC2640R2_LAUNCHXL_UART_RTS              IOID_18         /* RTS */
     *  @brief  Initialize the general board specific settings
     *  This function initializes the general board specific settings.
    void CC2640R2_LAUNCHXL_initGeneral(void);
     *  @brief  Turn off the external flash on LaunchPads
    void CC2640R2_LAUNCHXL_shutDownExtFlash(void);
     *  @brief  Wake up the external flash present on the board files
     *  This function toggles the chip select for the amount of time needed
     *  to wake the chip up.
    void CC2640R2_LAUNCHXL_wakeUpExtFlash(void);
     *  @def    CC2640R2_LAUNCHXL_ADCBufName
     *  @brief  Enum of ADCs
    typedef enum CC2640R2_LAUNCHXL_ADCBufName {
        CC2640R2_LAUNCHXL_ADCBUF0 = 0,
    } CC2640R2_LAUNCHXL_ADCBufName;
     *  @def    CC2640R2_LAUNCHXL_ADCBuf0SourceName
     *  @brief  Enum of ADCBuf channels
    typedef enum CC2640R2_LAUNCHXL_ADCBuf0ChannelName {
        /*CC2640R2_LAUNCHXL_ADCBUF0CHANNEL0 = 0,
        CC2640R2_LAUNCHXL_ADCBUF0CHANNEL1,
        CC2640R2_LAUNCHXL_ADCBUF0CHANNEL2,
        CC2640R2_LAUNCHXL_ADCBUF0CHANNEL3,
        CC2640R2_LAUNCHXL_ADCBUF0CHANNEL4,
        CC2640R2_LAUNCHXL_ADCBUF0CHANNEL5,
        CC2640R2_LAUNCHXL_ADCBUF0CHANNEL6,
        CC2640R2_LAUNCHXL_ADCBUF0CHANNEL7,*/
        CC2640R2_LAUNCHXL_ADCBUF0CHANNELVDDS=0,
        CC2640R2_LAUNCHXL_ADCBUF0CHANNELDCOUPL,
        CC2640R2_LAUNCHXL_ADCBUF0CHANNELVSS,
    } CC2640R2_LAUNCHXL_ADCBuf0ChannelName;
     *  @def    CC2640R2_LAUNCHXL_ADCName
    typedef enum CC2640R2_LAUNCHXL_ADCName {
        /*CC2640R2_LAUNCHXL_ADC0 = 0,
        CC2640R2_LAUNCHXL_ADC1,
        CC2640R2_LAUNCHXL_ADC2,
        CC2640R2_LAUNCHXL_ADC3,
        CC2640R2_LAUNCHXL_ADC4,
        CC2640R2_LAUNCHXL_ADC5,
        CC2640R2_LAUNCHXL_ADC6,
        CC2640R2_LAUNCHXL_ADC7,*/
        CC2640R2_LAUNCHXL_ADCDCOUPL=0,
        CC2640R2_LAUNCHXL_ADCVSS,
        CC2640R2_LAUNCHXL_ADCVDDS,
    } CC2640R2_LAUNCHXL_ADCName;
     *  @def    CC2640R2_LAUNCHXL_CryptoName
     *  @brief  Enum of Crypto names
    typedef enum CC2640R2_LAUNCHXL_CryptoName {
        CC2640R2_LAUNCHXL_CRYPTO0 = 0,
    } CC2640R2_LAUNCHXL_CryptoName;
     *  @def    CC2640R2_LAUNCHXL_AESCCMName
     *  @brief  Enum of AESCCM names
    typedef enum CC2640R2_LAUNCHXL_AESCCMName {
        CC2640R2_LAUNCHXL_AESCCM0 = 0,
    } CC2640R2_LAUNCHXL_AESCCMName;
     *  @def    CC2640R2_LAUNCHXL_AESGCMName
     *  @brief  Enum of AESGCM names
    typedef enum CC2640R2_LAUNCHXL_AESGCMName {
        CC2640R2_LAUNCHXL_AESGCM0 = 0,
    } CC2640R2_LAUNCHXL_AESGCMName;
     *  @def    CC2640R2_LAUNCHXL_AESCBCName
     *  @brief  Enum of AESCBC names
    typedef enum CC2640R2_LAUNCHXL_AESCBCName {
        CC2640R2_LAUNCHXL_AESCBC0 = 0,
    } CC2640R2_LAUNCHXL_AESCBCName;
     *  @def    CC2640R2_LAUNCHXL_AESCTRName
     *  @brief  Enum of AESCTR names
    typedef enum CC2640R2_LAUNCHXL_AESCTRName {
        CC2640R2_LAUNCHXL_AESCTR0 = 0,
    } CC2640R2_LAUNCHXL_AESCTRName;
     *  @def    CC2640R2_LAUNCHXL_AESECBName
     *  @brief  Enum of AESECB names
    typedef enum CC2640R2_LAUNCHXL_AESECBName {
        CC2640R2_LAUNCHXL_AESECB0 = 0,
    } CC2640R2_LAUNCHXL_AESECBName;
     *  @def    CC2640R2_LAUNCHXL_AESCTRDRBGName
     *  @brief  Enum of AESCTRDRBG names
    typedef enum CC2640R2_LAUNCHXL_AESCTRDRBGName {
        CC2640R2_LAUNCHXL_AESCTRDRBG0 = 0,
    } CC2640R2_LAUNCHXL_AESCTRDRBGName;
     *  @def    CC2640R2_LAUNCHXL_TRNGName
     *  @brief  Enum of TRNG names
    typedef enum CC2640R2_LAUNCHXL_TRNGName {
        CC2640R2_LAUNCHXL_TRNG0 = 0,
    } CC2640R2_LAUNCHXL_TRNGName;
     *  @def    CC2640R2_LAUNCHXL_GPIOName
     *  @brief  Enum of GPIO names
    typedef enum CC2640R2_LAUNCHXL_GPIOName {
        CC2640R2_LAUNCHXL_GPIO_S1 = 0,
        CC2640R2_LAUNCHXL_GPIO_S2,
        CC2640R2_LAUNCHXL_SPI_MASTER_READY,
        CC2640R2_LAUNCHXL_SPI_SLAVE_READY,
        CC2640R2_LAUNCHXL_GPIO_LED_GREEN,
        CC2640R2_LAUNCHXL_GPIO_LED_RED,
        CC2640R2_LAUNCHXL_GPIO_TMP116_EN,
        CC2640R2_LAUNCHXL_SDSPI_CS,
    } CC2640R2_LAUNCHXL_GPIOName;
     *  @def    CC2640R2_LAUNCHXL_GPTimerName
     *  @brief  Enum of GPTimer parts
    typedef enum CC2640R2_LAUNCHXL_GPTimerName {
        CC2640R2_LAUNCHXL_GPTIMER0A = 0,
        CC2640R2_LAUNCHXL_GPTIMER0B,
        CC2640R2_LAUNCHXL_GPTIMER1A,
        CC2640R2_LAUNCHXL_GPTIMER1B,
        CC2640R2_LAUNCHXL_GPTIMER2A,
        CC2640R2_LAUNCHXL_GPTIMER2B,
        CC2640R2_LAUNCHXL_GPTIMER3A,
        CC2640R2_LAUNCHXL_GPTIMER3B,
    } CC2640R2_LAUNCHXL_GPTimerName;
     *  @def    CC2640R2_LAUNCHXL_GPTimers
     *  @brief  Enum of GPTimers
    typedef enum CC2640R2_LAUNCHXL_GPTimers {
        CC2640R2_LAUNCHXL_GPTIMER0 = 0,
        CC2640R2_LAUNCHXL_GPTIMER1,
        CC2640R2_LAUNCHXL_GPTIMER2,
        CC2640R2_LAUNCHXL_GPTIMER3,
    } CC2640R2_LAUNCHXL_GPTimers;
     *  @def    CC2640R2_LAUNCHXL_I2CName
     *  @brief  Enum of I2C names
    typedef enum CC2640R2_LAUNCHXL_I2CName {
        CC2640R2_LAUNCHXL_I2C0 = 0,
    } CC2640R2_LAUNCHXL_I2CName;
     *  @def    CC2640R2_LAUNCHXL_I2SName
     *  @brief  Enum of I2S names
    typedef enum CC2640R2_LAUNCHXL_I2SName {
        CC2640R2_LAUNCHXL_I2S0 = 0,
    } CC2640R2_LAUNCHXL_I2SName;
     *  @def    CC2640R2_LAUNCHXL_NVSName
     *  @brief  Enum of NVS names
    typedef enum CC2640R2_LAUNCHXL_NVSName {
        CC2640R2_LAUNCHXL_NVSCC26XX0 = 0,
    #endif
        CC2640R2_LAUNCHXL_NVSSPI25X0,
    #endif
    } CC2640R2_LAUNCHXL_NVSName;
     *  @def    CC2640R2_LAUNCHXL_PWM
     *  @brief  Enum of PWM outputs
    typedef enum CC2640R2_LAUNCHXL_PWMName {
        CC2640R2_LAUNCHXL_PWM0 = 0,
        CC2640R2_LAUNCHXL_PWM1,
        CC2640R2_LAUNCHXL_PWM2,
        CC2640R2_LAUNCHXL_PWM3,
        CC2640R2_LAUNCHXL_PWM4,
        CC2640R2_LAUNCHXL_PWM5,
        CC2640R2_LAUNCHXL_PWM6,
        CC2640R2_LAUNCHXL_PWM7,
    } CC2640R2_LAUNCHXL_PWMName;
     *  @def    CC2640R2_LAUNCHXL_SDName
     *  @brief  Enum of SD names
    typedef enum CC2640R2_LAUNCHXL_SDName {
        CC2640R2_LAUNCHXL_SDSPI0 = 0,
    } CC2640R2_LAUNCHXL_SDName;
     *  @def    CC2640R2_LAUNCHXL_SPIName
     *  @brief  Enum of SPI names
    typedef enum CC2640R2_LAUNCHXL_SPIName {
        CC2640R2_LAUNCHXL_SPI0 = 0,
        CC2640R2_LAUNCHXL_SPI1,
    } CC2640R2_LAUNCHXL_SPIName;
     *  @def    CC2640R2_LAUNCHXL_UARTName
     *  @brief  Enum of UARTs
    typedef enum CC2640R2_LAUNCHXL_UARTName {
        CC2640R2_LAUNCHXL_UART0 = 0,
    } CC2640R2_LAUNCHXL_UARTName;
     *  @def    CC2640R2_LAUNCHXL_UDMAName
     *  @brief  Enum of DMA buffers
    typedef enum CC2640R2_LAUNCHXL_UDMAName {
        CC2640R2_LAUNCHXL_UDMA0 = 0,
    } CC2640R2_LAUNCHXL_UDMAName;
     *  @def    CC2640R2_LAUNCHXL_WatchdogName
     *  @brief  Enum of Watchdogs
    typedef enum CC2640R2_LAUNCHXL_WatchdogName {
        CC2640R2_LAUNCHXL_WATCHDOG0 = 0,
    } CC2640R2_LAUNCHXL_WatchdogName;
    #ifdef __cplusplus
    #endif
    #endif /* __CC2640R2_LAUNCHXL_BOARD_H__ */
    我未对通用 ADC 引脚进行注释。 当我输入"GPIO_WRITE (PIN_SEG11、TRUE);"行时、所有内容仍然崩溃-当我将"true"替换为"false"时、所有内容都可以正常工作。 您能否为我推荐一篇有关引脚定义的文章? 这方面仍有一些问题、因为我以前的体验仅限于 Arduino。
    此外、是否有方法可以获取有关此处发生的错误的更多信息?
    祝你一切顺利、
    Nico
    我仍然建议将这些数字引脚添加到 GPIO 表中。  也许您可以从更少的引脚或默认示例开始、并尝试使其在此处工作以减少依赖项的数量、或者在 器件故障期间使用调试器进一步确定寄存器状态并调用栈。
    Ryan
    好的、谢谢! 我稍后将在 此处阅读这篇文章:http://software-dl.ti.com/lprf/simplelink_cc2640r2_sdk/1.00.00.22/exports/docs/tidrivers/doxygen/html/_g_p_i_o_8h.html
    希望它能给我一些见解。 非常感谢您的帮助! 我将在发生任何事情时立即更新此位置(:
    祝你一切顺利、
    Nico
    您好、Ryan! 非常感谢您的提示、这是非常好的帮助! 在我还从控制外部闪存、I2S、ADC 和其他外围设备的配置文件中删除了一些位后、我几乎能够使所有引脚正常工作。 现在我唯一缺少的是 IOID_1 (别名 RFSW? 这是什么意思?)、6、19、20、22和23。 引脚1上有一个信号、而其他引脚保持高电平或低电平。
    下面是我的一些(配置)文件...
    主文件引脚初始化:
    #define PIN_PWM IOID_9
    #define PIN_PWM_N IOID_10
    //main Thread
    GPIO_init();
        GPIO_setConfig(PIN_PWM, GPIO_CFG_OUT_STD | GPIO_CFG_OUT_LOW);
        GPIO_setConfig(PIN_PWM_N, GPIO_CFG_OUT_STD | GPIO_CFG_OUT_LOW);
        GPIO_write(PIN_PWM, true);
        GPIO_write(PIN_PWM_N, true);
    //some other stuff afterwards, like initializing interrupts on 2 other pins not used in the above list
    while (1) {
            //sleep(time);
            //GPIO_toggle(Board_GPIO_LED0);
            //PWM_setDuty(pwm1, duty);
            //PWM_setDuty(pwm2, duty);
            GPIO_toggle(PIN_PWM);
            GPIO_toggle(PIN_PWM_N);
            GPIO_toggle(PIN_COM0);
            GPIO_toggle(PIN_COM1);
            GPIO_toggle(PIN_COM2);
            GPIO_toggle(PIN_COM3);
            GPIO_toggle(PIN_SEG0);
            GPIO_toggle(PIN_SEG1);
            GPIO_toggle(PIN_SEG2);
            GPIO_toggle(PIN_SEG3);
            GPIO_toggle(PIN_SEG4);
            GPIO_toggle(PIN_SEG5);
            GPIO_toggle(PIN_SEG6);
            GPIO_toggle(PIN_SEG7);
            GPIO_toggle(PIN_SEG8);
            GPIO_toggle(PIN_SEG9);
            GPIO_toggle(PIN_SEG10);
            GPIO_toggle(PIN_SEG11);
            GPIO_toggle(PIN_SEG12);
            GPIO_toggle(PIN_SEG13);
            GPIO_toggle(PIN_SEG14);
            GPIO_toggle(PIN_SEG15);
            GPIO_toggle(PIN_SEG16);
            GPIO_toggle(PIN_SEG17);
            GPIO_toggle(PIN_SEG18);
            GPIO_toggle(PIN_SEG19);
            usleep(300);
    CC2640R2_LAUNCHXL.c
     * are met:
    #include <stddef.h>
    #include <stdint.h>
    /*const CryptoCC26XX_HWAttrs cryptoCC26XXHWAttrs[CC2640R2_LAUNCHXL_CRYPTOCOUNT] = {
            .intPriority    = ~0,
            .intPriority       = ~0,
            .intPriority       = ~0,
            .intPriority       = ~0,
            .intPriority       = ~0,
            .intPriority       = ~0,
            .intPriority       = ~0,
            .swiPriority       = 0,
        /* Input pins */
                                       PIN_PWM | PIN_GPIO_OUTPUT_DIS | PIN_INPUT_DIS | PIN_PUSHPULL,
                                       PIN_PWM_N | PIN_GPIO_OUTPUT_DIS | PIN_INPUT_DIS | PIN_PUSHPULL,
                                       PIN_COM0 | PIN_GPIO_OUTPUT_DIS | PIN_INPUT_DIS | PIN_PUSHPULL,
                                       PIN_COM1 | PIN_GPIO_OUTPUT_DIS | PIN_INPUT_DIS | PIN_PUSHPULL,
                                       PIN_COM2 | PIN_GPIO_OUTPUT_DIS | PIN_INPUT_DIS | PIN_PUSHPULL,
                                       PIN_COM3 | PIN_GPIO_OUTPUT_DIS | PIN_INPUT_DIS | PIN_PUSHPULL,
                                       PIN_SEG0 | PIN_GPIO_OUTPUT_DIS | PIN_INPUT_DIS | PIN_PUSHPULL,
                                       PIN_SEG1 | PIN_GPIO_OUTPUT_DIS | PIN_INPUT_DIS | PIN_PUSHPULL,
                                       PIN_SEG2 | PIN_GPIO_OUTPUT_DIS | PIN_INPUT_DIS | PIN_PUSHPULL,
                                       PIN_SEG3 | PIN_GPIO_OUTPUT_DIS | PIN_INPUT_DIS | PIN_PUSHPULL,
                                       PIN_SEG4 | PIN_GPIO_OUTPUT_DIS | PIN_INPUT_DIS | PIN_PUSHPULL,
                                       PIN_SEG5 | PIN_GPIO_OUTPUT_DIS | PIN_INPUT_DIS | PIN_PUSHPULL,
                                       PIN_SEG6 | PIN_GPIO_OUTPUT_DIS | PIN_INPUT_DIS | PIN_PUSHPULL,
                                       PIN_SEG7 | PIN_GPIO_OUTPUT_DIS | PIN_INPUT_DIS | PIN_PUSHPULL,
                                       PIN_SEG8 | PIN_GPIO_OUTPUT_DIS | PIN_INPUT_DIS | PIN_PUSHPULL,
                                       PIN_SEG9 | PIN_GPIO_OUTPUT_DIS | PIN_INPUT_DIS | PIN_PUSHPULL,
                                       PIN_SEG10 | PIN_GPIO_OUTPUT_DIS | PIN_INPUT_DIS | PIN_PUSHPULL,
                                       PIN_SEG11 | PIN_GPIO_OUTPUT_DIS | PIN_INPUT_DIS | PIN_PUSHPULL,
                                       PIN_SEG12 | PIN_GPIO_OUTPUT_DIS | PIN_INPUT_DIS | PIN_PUSHPULL,
                                       PIN_SEG13 | PIN_GPIO_OUTPUT_DIS | PIN_INPUT_DIS | PIN_PUSHPULL,
                                       PIN_SEG14 | PIN_GPIO_OUTPUT_DIS | PIN_INPUT_DIS | PIN_PUSHPULL,
                                       PIN_SEG15 | PIN_GPIO_OUTPUT_DIS | PIN_INPUT_DIS | PIN_PUSHPULL,
                                       PIN_SEG16 | PIN_GPIO_OUTPUT_DIS | PIN_INPUT_DIS | PIN_PUSHPULL,
                                       PIN_SEG17 | PIN_GPIO_OUTPUT_DIS | PIN_INPUT_DIS | PIN_PUSHPULL,
                                       PIN_SEG18 | PIN_GPIO_OUTPUT_DIS | PIN_INPUT_DIS | PIN_PUSHPULL,
                                       PIN_SEG19 | PIN_GPIO_OUTPUT_DIS | PIN_INPUT_DIS | PIN_PUSHPULL,
                                       PIN_TERMINATE
        .intPriority        = (~0)
        PIN_TERMINATE
        .intPriority = ~0,
        .swiPriority = 0
        Power_init();
            while (1);
        Board_initHook();
    CC2640R2_LAUNCHXL.c
     * are met:
    #ifdef __cplusplus
    extern "C" {
    #endif
    /* Includes */
    /* Externs */
    /* Defines */
    /* Digital IOs */
    /* GPIO */
    /* I2C */
    /* I2S */
    /* LEDs */
    /* PWM Outputs */
    #endif
    #endif
    /*typedef enum CC2640R2_LAUNCHXL_PWMName {
    } CC2640R2_LAUNCHXL_PWMName;*/
    #ifdef __cplusplus
    #endif
    我也删除了.h 中不需要的一些内容、但它似乎主要是引脚名称的定义。
    也许最好将所有 GPIO 配置从  GPIO_PinConfig gpioPinConfigs[]移动到 PIN_Config BoardGpioInitTable[]?
    BoardGpioInitTable 可能不如将  gpioPinConfigs 映射到 CC2640R2_LAUNCHXL_GPIOName 那么重要、 有关更多详细信息、请参阅此 E2E 主题。  E2E 搜索相关主题: https://e2e.ti.com/search?q=CC2640R2_LAUNCHXL_GPIOName&category=forum
    Ryan
    Ryan、您好、这正是问题的关键、非常感谢! 我想我可以随时使用相应的 IOID_x 句柄来寻址任何引脚。 但实际上、如果我正确理解它、它似乎就是这样工作的:
    1) 您创建了 CC2640R2_LAUNCHXL_GPIOName 列表
    2) 按照相同的顺序、插入相应的 IOID_x (或 GPIOCC26XX_DIO_x)-这将配置引脚、并从  0开始获取对应于 CC2640R2_LAUNCHXL_GPIOName 枚举的内部 ID。
    3) 您现在可以使用此 ID 控制引脚。
    因此、我将第一行中的#defines 更改为 GPIOName 枚举中的相应 ID、并将 gpioPinConfigs[]中的 PIN_SEGy 值替换为仅 IOID_x 引脚编号。 现在它可以工作、我可以控制我需要的每个 GPIO 引脚。
    祝您度过美好的一天、再次感谢您的帮助! (:
    祝你一切顺利、
    Nico
