[参考译文] CC2652R:如何触发 UART 读回?
Guru**** 2927270 points
https://e2e.ti.com/support/wireless-connectivity/bluetooth-group/bluetooth/f/bluetooth-forum/1378087/cc2652r-how-do-i-trigger-a-uart-readcallback
器件型号:CC2652R
主题中讨论的其他器件:SysConfig
我 根据  最新的 SDK 7_41_00_17添加了 UART 驱动程序。  我曾提到 uart2callback 例程、但我想通过中断接收数据、而不是在 while 函数中轮询 UART2_read。  因此、我更改了例程、如下所示:
 * Copyright (c) 2020, Texas Instruments Incorporated
 * All rights reserved.
 * Redistribution and use in source and binary forms, with or without
 * modification, are permitted provided that the following conditions
 * are met:
 * *  Redistributions of source code must retain the above copyright
 *    notice, this list of conditions and the following disclaimer.
 * *  Redistributions in binary form must reproduce the above copyright
 *    notice, this list of conditions and the following disclaimer in the
 *    documentation and/or other materials provided with the distribution.
 * *  Neither the name of Texas Instruments Incorporated nor the names of
 *    its contributors may be used to endorse or promote products derived
 *    from this software without specific prior written permission.
 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
 * THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
 * PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
 * CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
 * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
 * PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
 * OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
 * WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
 * OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
 * EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
 *  ======== uart2callback.c ========
#include <stdint.h>
#include <stddef.h>
/* POSIX Header files */
#include <semaphore.h>
/* Driver Header files */
#include <ti/drivers/GPIO.h>
#include <ti/drivers/UART2.h>
/* Driver configuration */
#include "ti_drivers_config.h"
static sem_t sem;
static volatile size_t numBytesRead;
char input;
UART2_Handle uart;
 *  ======== callbackFxn ========
void callbackFxn(UART2_Handle handle, void *buffer, size_t count, void *userArg, int_fast16_t status)
    GPIO_toggle(CONFIG_GPIO_LED_0);
    if (status != UART2_STATUS_SUCCESS)
        /* RX error occured in UART2_read() */
        while (1) {}
    status = UART2_read(uart, &input, 1, NULL);
                /* UART2_read() failed */
                while (1) {}
    numBytesRead = count;
    sem_post(&sem);
 *  ======== mainThread ========
void *mainThread(void *arg0)
    const char echoPrompt[] = "Echoing characters:\r\n";
    UART2_Params uartParams;
    int32_t semStatus;
    uint32_t status = UART2_STATUS_SUCCESS;
    /* Call driver init functions */
    GPIO_init();
    /* Configure the LED pin */
    GPIO_setConfig(CONFIG_GPIO_LED_0, GPIO_CFG_OUT_STD | GPIO_CFG_OUT_LOW);
    /* Create semaphore */
    semStatus = sem_init(&sem, 0, 0);
    if (semStatus != 0)
        /* Error creating semaphore */
        while (1) {}
    /* Create a UART in CALLBACK read mode */
    UART2_Params_init(&uartParams);
    uartParams.readMode     = UART2_Mode_CALLBACK;
    uartParams.readCallback = callbackFxn;
    uartParams.baudRate     = 115200;
    uartParams.readReturnMode = UART2_ReadReturnMode_PARTIAL;
    uart = UART2_open(CONFIG_UART2_0, &uartParams);
    if (uart == NULL)
        /* UART2_open() failed */
        while (1) {}
    /* Turn on user LED to indicate successful initialization */
    GPIO_write(CONFIG_GPIO_LED_0, CONFIG_GPIO_LED_ON);
    /* Pass NULL for bytesWritten since it's not used in this example */
    UART2_write(uart, echoPrompt, sizeof(echoPrompt), NULL);
    /* Loop forever echoing */
    while (1)
        numBytesRead = 0;
//        /* Pass NULL for bytesRead since it's not used in this example */
//        status = UART2_read(uart, &input, 1, NULL);
//        if (status != UART2_STATUS_SUCCESS)
//            /* UART2_read() failed */
//            while (1) {}
        /* Do not write until read callback executes */
        sem_wait(&sem);
        if (numBytesRead > 0)
            status = UART2_write(uart, &input, 1, NULL);
                /* UART2_write() failed */
                while (1) {}
不幸的是、我没有进入 callbackFxn 函数、我想知道如何触发 readCallback、或者我的配置有什么问题。
    我是偶然解决的。
    修改了以下内容:
     * are met:
    #include <stdint.h>
    #include <stddef.h>
    static sem_t sem;
    uint8_t input[100] = {0};
    UART2_Handle uart;
            while (1) {}
        status = UART2_read(uart, input, sizeof(input), NULL);
                    while (1) {}
        sem_post(&sem);
        int32_t semStatus;
        GPIO_init();
        if (semStatus != 0)
            while (1) {}
        if (uart == NULL)
            while (1) {}
                    while (1) {}
        while (1)
            numBytesRead = 0;
    //            while (1) {}
            sem_wait(&sem);
                status = UART2_write(uart, input, numBytesRead, NULL);
                    while (1) {}
    您似乎必须首先调用 UART2_Read 才能进入 readCallback、这与 Nordic 的第一次回调和读取稍有不同。
    尊敬的 Ethan:
    感谢您分享您的解决方案!
    尊敬的 Cl é ment:
    顺便说一下、 最新的 SDK 删除了 UART 驱动程序、只保留了 UART2、如何同时使用两个 UART?
    您可以使用 SysConfig 定义两个 UART2实例。 两个 UART2实例都应使用 UART2驱动程序。
    我希望这将有所帮助、
    感谢您的回答
