[参考译文] INSTASPINFOCMOTORWAREGUI:缩放单个反馈传感器 instaspin
Guru**** 2589275 points
https://e2e.ti.com/support/microcontrollers/c2000-microcontrollers-group/c2000/f/c2000-microcontrollers-forum/1502640/instaspinfocmotorwaregui-scaling-individual-feedback-sensors-instaspin
部件号:INSTASPINFOCMOTORWAREGUI
您好、
我们将 instaspin FOC 用于中等功率逆变器。 在评估过程中、我们注意到电流反馈传感器中存在线性误差。 它们存在因传感器而稍有不同的传感器缩放误差。 当电机运行时、这在电机的相位中显示为相电流失衡约为13%。 如何针对代码中的各个感测调节误差进行调整? 我是否会在以下代码中添加乘法常量?
//! \brief      Reads the ADC data
//! \details    Reads in the ADC result registers, adjusts for offsets, and
//!             scales the values according to the settings in user.h.  The
//!             structure gAdcData holds three phase voltages, three line
//!             currents, and one DC bus voltage.
//! \param[in]  handle    The hardware abstraction layer (HAL) handle
//! \param[in]  pAdcData  A pointer to the ADC data buffer
static inline void HAL_readAdcData(HAL_Handle handle,HAL_AdcData_t *pAdcData)
  HAL_Obj *obj = (HAL_Obj *)handle;
  _iq value;
  _iq current_sf = HAL_getCurrentScaleFactor(handle);
  _iq voltage_sf = HAL_getVoltageScaleFactor(handle);
  // convert current A
  // sample the first sample twice due to errata sprz342f, ignore the first sample
  value = (_iq)ADC_readResult(obj->adcHandle,ADC_ResultNumber_1);
  value = _IQ12mpy(value,current_sf) - obj->adcBias.I.value[0];      // divide by 2^numAdcBits = 2^12
  pAdcData->I.value[0] = value;
  // convert current B
  value = (_iq)ADC_readResult(obj->adcHandle,ADC_ResultNumber_2);
  value = _IQ12mpy(value,current_sf) - obj->adcBias.I.value[1];      // divide by 2^numAdcBits = 2^12
  pAdcData->I.value[1] = value;
  // convert current C
  value = (_iq)ADC_readResult(obj->adcHandle,ADC_ResultNumber_3);
  value = _IQ12mpy(value,current_sf) - obj->adcBias.I.value[2];      // divide by 2^numAdcBits = 2^12
  pAdcData->I.value[2] = value;
  // convert voltage A
  value = (_iq)ADC_readResult(obj->adcHandle,ADC_ResultNumber_4);
  value = _IQ12mpy(value,voltage_sf) - obj->adcBias.V.value[0];      // divide by 2^numAdcBits = 2^12
  pAdcData->V.value[0] = value;
  // convert voltage B
  value = (_iq)ADC_readResult(obj->adcHandle,ADC_ResultNumber_5);
  value = _IQ12mpy(value,voltage_sf) - obj->adcBias.V.value[1];      // divide by 2^numAdcBits = 2^12
  pAdcData->V.value[1] = value;
  // convert voltage C
  value = (_iq)ADC_readResult(obj->adcHandle,ADC_ResultNumber_6);
  value = _IQ12mpy(value,voltage_sf) - obj->adcBias.V.value[2];      // divide by 2^numAdcBits = 2^12
  pAdcData->V.value[2] = value;
  // read the dcBus voltage value
  value = (_iq)ADC_readResult(obj->adcHandle,ADC_ResultNumber_7);     // divide by 2^numAdcBits = 2^12
  value = _IQ12mpy(value,voltage_sf);
  pAdcData->dcBus = value;
  // read the dc total current
  return;
} // end of HAL_readAdcData() function
//! \details    Reads in the ADC result registers, and
static inline void HAL_readAdcDataWithOffsets(HAL_Handle handle,HAL_AdcData_t *pAdcData)
  _iq value;
  value = _IQ12mpy(value,current_sf);
  return;
} // end of HAL_readAdcDataWithOffsets() function
请注意、这不是初始校准时的偏移、而是缩放误差。 我需要分别调整传感器。 有没有好的方法来实现这一点?
/Mikael
    如何针对代码中的各个感应缩放误差进行调整? 我是否在以下代码中添加乘法常量?
    通常、假设电流传感器没有线性误差或误差非常小。 如果没有、则必须更改电流传感器或添加附加功能才能进行校准。
    遗憾的是、没有用于线性误差校准的示例代码、您必须自行设计此代码、而不是像您上面提到的那样仅仅添加一个常数。
    如果结果值开始与测量的实际电流相对应、为什么我不能在上面的代码中添加常量?
    增益误差应该是乘法系数、而不是失调电压误差的常量。 您可以在一些工程网站上找到有关如何校准传感器失调电压和增益误差的相关文章、并参考本文以添加校准功能。
