[参考译文] TMS320F2800137:f280013x_dcan_flash-kernel
Guru**** 2943350 points
https://e2e.ti.com/support/microcontrollers/c2000-microcontrollers-group/c2000/f/c2000-microcontrollers-forum/1523744/tms320f2800137-f280013x_dcan_flash-kernel
器件型号:TMS320F2800137
您好、您是否有 f2800137的 CAN 或 dcan 引导烧录程序? 例如 f280013x_dcan_flash-kernel.txt
要么是 f280013x_flash 内核工程?
