[参考译文] TMS320F280049:时钟和 PLL 功能障碍导致 DSP 功能故障发生器
Guru**** 2933120 points
https://e2e.ti.com/support/microcontrollers/c2000-microcontrollers-group/c2000/f/c2000-microcontrollers-forum/1527463/tms320f280049-clock-and-pll-dysfunction-leading-to-dsp-functional-failer
器件型号:TMS320F280049
您好、Stevan
由于我仍然无法通过在主页上搜索找到此帖子、我创建了一个指向此帖子的新链接。
https://e2e.ti.com/support/microcontrollers/c2000-microcontrollers-group/c2000/f/c2000-microcontrollers-forum/1523902/tms320f280049-clock-and-pll-dysfunction-leading-to-dsp-functional-failer/5872624#5872624
