[参考译文] TMS320F28377S:CCS 20 和 gitIgnore
Guru**** 3020190 points
https://e2e.ti.com/support/microcontrollers/c2000-microcontrollers-group/c2000/f/c2000-microcontrollers-forum/1605161/tms320f28377s-ccs-20-and-gitignore
器件型号: TMS320F28377S
CCS 20 向.gitignore 文件添加了可修改的条目。
CCS 20.4.0.13__1.10.0
下面是从我的.gitignore 复制的
/Debug/
/释放/
/debug_INT_RAM/
/debug_flash/
/debug_EXT_RAM_LP/
/DEBUG_EXT_RAM/
/debug_flash/
/debug_flash/
/debug_flash/
/debug_flash/
/debug_flash/
/debug_flash/
/debug_flash/
/debug_flash/
/debug_flash/
/debug_flash/
/debug_flash/
/debug_flash/
/debug_flash/
/debug_flash/
/debug_flash/
/debug_flash/
/debug_flash/
/debug_flash/
/debug_flash/
/debug_flash/
/debug_flash/
/debug_flash/
/debug_flash/
/debug_flash/
/DEBUG_EXT_RAM/
/DEBUG_EXT_RAM/
/DEBUG_EXT_RAM/
/DEBUG_EXT_RAM/
/DEBUG_EXT_RAM/
/DEBUG_EXT_RAM/
/DEBUG_EXT_RAM/
/DEBUG_EXT_RAM/
/DEBUG_EXT_RAM/
/DEBUG_EXT_RAM/
/DEBUG_EXT_RAM/
/DEBUG_EXT_RAM/
/DEBUG_EXT_RAM/
/DEBUG_EXT_RAM/
/DEBUG_EXT_RAM/
/DEBUG_EXT_RAM/
/DEBUG_EXT_RAM/
/DEBUG_EXT_RAM/
/DEBUG_EXT_RAM/
/DEBUG_EXT_RAM/
/DEBUG_EXT_RAM/
/DEBUG_EXT_RAM/
/DEBUG_EXT_RAM/
/DEBUG_EXT_RAM/
/DEBUG_EXT_RAM/
/DEBUG_EXT_RAM/
/DEBUG_EXT_RAM/
/DEBUG_EXT_RAM/
/DEBUG_EXT_RAM/
/DEBUG_EXT_RAM/
/DEBUG_EXT_RAM/
/DEBUG_EXT_RAM/
/DEBUG_EXT_RAM/
/DEBUG_EXT_RAM/
/DEBUG_EXT_RAM/
/DEBUG_EXT_RAM/
/DEBUG_EXT_RAM/
/DEBUG_EXT_RAM/
/DEBUG_EXT_RAM/
/DEBUG_EXT_RAM/
/DEBUG_EXT_RAM/
/DEBUG_EXT_RAM/
/DEBUG_EXT_RAM/
/DEBUG_EXT_RAM/
/DEBUG_EXT_RAM/
/DEBUG_EXT_RAM/
/DEBUG_EXT_RAM/
/DEBUG_EXT_RAM/
/DEBUG_EXT_RAM/
/DEBUG_EXT_RAM/
/DEBUG_EXT_RAM/
/DEBUG_EXT_RAM/
/DEBUG_EXT_RAM/
/DEBUG_EXT_RAM/
/DEBUG_EXT_RAM/
/DEBUG_EXT_RAM/
/DEBUG_EXT_RAM/
/DEBUG_EXT_RAM/
/DEBUG_EXT_RAM/
/DEBUG_EXT_RAM/
/DEBUG_EXT_RAM/
/DEBUG_EXT_RAM/
/DEBUG_EXT_RAM/
/DEBUG_EXT_RAM/
/DEBUG_EXT_RAM/
/DEBUG_EXT_RAM/
/debug_flash/
/debug_flash/
/debug_flash/
/debug_flash/
/debug_flash/
/debug_flash/
/debug_flash/
/debug_flash/
/debug_flash/
/debug_flash/
/debug_flash/
/debug_flash/
/debug_flash/
/debug_flash/
/debug_flash/
/debug_flash/
/debug_flash/
/debug_flash/
/debug_flash/
/debug_flash/
/debug_flash/
/debug_flash/
/debug_flash/
/debug_flash/
/debug_flash/
/debug_flash/
/DEBUG_EXT_RAM/
/debug_golden/
/debug_golden/
/debug_golden/
/debug_golden/
/debug_golden/
/debug_golden/
/debug_golden/
/debug_golden/
/debug_golden/
/debug_golden/
/debug_golden/
/debug_golden/
/debug_golden/
/debug_golden/
/debug_golden/
/debug_golden/
/debug_golden/
/debug_update/
/debug_update/
/debug_update/
/debug_update/
/debug_update/
/debug_update/
/debug_update/
/debug_update/
/debug_update/
/debug_update/
/debug_update/
/debug_update/
/debug_update/
/debug_update/
/debug_flash/
/debug_flash/
/debug_flash/
/debug_flash/
/debug_flash/
/debug_flash/
/debug_flash/
/debug_flash/
/debug_flash/
/debug_flash/
/debug_flash/
/debug_flash/
/debug_flash/
/DEBUG_EXT_RAM/
/debug_golden/
/debug_update/
/debug_update/
/debug_update/
/debug_update/
/debug_update/
    您好、Paul:
    感谢您的提问。 您能否共享在 CCS 添加这些冗余文件夹之前创建的.gitignore 文件?
    IRA
    您好、Ira、
    在 CCS 添加 redundent 文件夹之前忽略 Gitignore:
    /Debug/
    /释放/
    /debug_INT_RAM/
    /debug_flash/
    /debug_EXT_RAM_LP/
    /DEBUG_EXT_RAM/
    您好、Paul:
    您的存储库中是否有多个 CCS 工程? 有时这会导致 CCS 修改.gitignore 文件。
    此外、存储库根目录(在其中创建.gitgnore 文件)与 CCS 工作区是否相同?
    另外、确保没有通过 CCS 设置配置要忽略的任何文件。 将此文件与.gitignore 文件一起使用也可能会导致此错误。
    即、确保以下字段留空。
    或者、在创建并提交新的.gitignore 文件后、您可以运行以下命令以确保 CCS 不会修改.gitgnore 文件
    git commit -m “clean new .gitignore file added“
    Git update-index --assume-vango .gitignore
    这将指示 Git 忽略 CCS 未来的更改
    谢谢。此致、
    IRA
