[参考译文] TMDSCNCD280039C:MCU TMS320F280039C 上的 AES ECB 模式加密
Guru**** 2989960 points
Other Parts Discussed in Thread: TMS320F280039C
https://e2e.ti.com/support/microcontrollers/c2000-microcontrollers-group/c2000/f/c2000-microcontrollers-forum/1085499/tmdscncd280039c-aes-ecb-mode-encryption-on-mcu-tms320f280039c
部件号:TMDSCNCD280039C
“线程”中讨论的其它部件:TMS320F280039C
尊敬的专家:
我使用相同的设置条件来验证网络工具和 MCU 加密的输出是否相同。
模式设置:AES 128位加密用于 ECB 模式。
Web 工具 URL:aes.online-domain-tools.com
MCU:TMS320F280039C 和 TI 示例代码(AES_ex1_ECB)
为什么微控制器 AES 模块的加密与在线工具的输出不同?
网络加密工具的加密输出如下:
输入数据:{0x00112233,0x44556677,0x8899aabb,0xccddeeff}
密钥 :{0x00010203,0x04050607,0x08090a0b,0x0c0d0e0f}
CYPHER:{0x69c4e0d8,0x6a7b0430,0xd8cdb780,0x70b4c55a}
MCU TMS320F280039C 输出加密的结果如下:
密钥:{0x00010203,0x04050607,0x08090a0b,0x0c0d0e0f}
CYPHER:{0xEEDB5AAD,0x8361C787,0x703A4E60,0x8BB9165B}
感谢你的帮助。
    Web 工具 URL: http://aes.online-domain-tools.com/ 或 http://testprotect.com/appendix/AEScalc
    这两个 URL 的验证如下
     MCU 的验证如下
    // FILE:   aes_ex1_ecb_encrypt.c
    // TITLE:  AES ECB Encryption
    //! \addtogroup driver_example_cm_list
    //! <h1>AES ECB Encryption Example (CM)</h1>
    //! This example encrypts block cipher-text using AES128 in ECB mode. It does
    //! the encryption first without uDMA and then with uDMA. The results are
    //! checked after each operation.
    //! \b External \b Connections \n
    //!  - None
    //! \b Watch \b Variables \n
    //! - \b errCountGlobal - Error Counter. It should be zero.
    //! - \b testStatusGlobal - Test status. It should be equal to PASS.
    // $Copyright:
    // Copyright (C) 2022 Texas Instruments Incorporated - http://www.ti.com/
    // Redistribution and use in source and binary forms, with or without
    // modification, are permitted provided that the following conditions
    // are met:
    //   Redistributions of source code must retain the above copyright
    //   notice, this list of conditions and the following disclaimer.
    //   Redistributions in binary form must reproduce the above copyright
    //   notice, this list of conditions and the following disclaimer in the
    //   documentation and/or other materials provided with the
    //   distribution.
    //   Neither the name of Texas Instruments Incorporated nor the names of
    //   its contributors may be used to endorse or promote products derived
    //   from this software without specific prior written permission.
    // THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
    // "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
    // LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
    // A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
    // OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
    // SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
    // LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
    // DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
    // THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
    // (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
    // OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
    // Included Files
    #include <string.h>
    #include "driverlib.h"
    #include "device.h"
    // Defines
    #define TEST_PASS 0xABCDABCD
    #define TEST_FAIL 0xDEADDEAD
    #define BURST_SIZE         0x8
    #define BURST_SRCSTEP      0x2
    #define BURST_DESTSTEP     0x2
    #define TRANSFER_SIZE      0x4
    #define TRANSFER_SRCSTEP   0x2
    #define TRANSFER_DESTSTEP  0x2
    #define SRCWRAPSIZE        0x100
    #define WRAP_SRCSTEP       0x10
    #define DESTWRAPSIZE       0x100
    #define WRAP_DESTSTEP      0x10
    // Global Variables
    // Global error counter & status
    uint16_t errCountGlobal = 0;
    uint32_t testStatusGlobal;
    // Output cipher-text array
    #pragma DATA_SECTION(cipherTextArray,"ramgs0");
    uint32_t cipherTextArray[16];
    // Global interrupt status
    static volatile uint32_t intStatus = 0;
    // The AES interrupt handler and interrupt flags.
    static volatile bool contextInIntFlag;
    static volatile bool dataInIntFlag;
    static volatile bool contextOutIntFlag;
    static volatile bool dataOutIntFlag;
    static volatile bool contextInDMADoneIntFlag;
    static volatile bool dataInDMADoneIntFlag;
    static volatile bool contextOutDMADoneIntFlag;
    static volatile bool dataOutDMADoneIntFlag;
    // Structure for NIST AES ECB tests
    typedef struct
        AES_KeySize keySize;
        uint32_t keyArray[8];
        uint32_t dataLength;
        uint32_t plainTextArray[16];
    } testVectorECB;
    // Test Cases from NIST ECB Revised Spec.
    #pragma DATA_SECTION(testVectorECBArray,"ramgs0");
    testVectorECB testVectorECBArray[] =
     // Test Case #1 with 128 bit key
      .keySize = AES_KEY_SIZE_128BIT,
      .keyArray = { 0x00010203, 0x04050607,0x08090a0b, 0x0c0d0e0f },
      .dataLength = 16U,
      .plainTextArray  = { 0x00112233, 0x44556677, 0x8899aabb, 0xccddeeff,
                           0x578a2dae, 0x9cac031e, 0xac6fb79e, 0x518eaf45,
                           0x461cc830, 0x11e45ca3, 0x19c1fbe5, 0xef520a1a,
                           0x45249ff6, 0x179b4fdf, 0x7b412bad, 0x10376ce6 },
      .cipherTextArray = { 0xb47bd73a, 0x60367a0d, 0xf3ca9ea8, 0x97ef6624,
                           0x85d5d3f5, 0x9d69b903, 0x5a8985e7, 0xafbafd96,
                           0x7fcdb143, 0x23ce8e59, 0xe3001b88, 0x880603ed,
                           0x5e780c7b, 0x3fade827, 0x71202382, 0xd45d7204 }
     // Test Case #2 with 256 bit key
      .keySize  = AES_KEY_SIZE_256BIT,
      .keyArray = { 0x10eb3d60, 0xbe71ca15, 0xf0ae732b, 0x81777d85,
                    0x072c351f, 0xd708613b, 0xa310982d, 0xf4df1409 },
      .dataLength = 64U,
      .plainTextArray  = { 0xe2bec16b, 0x969f402e, 0x117e3de9, 0x2a179373,
      .cipherTextArray = { 0xbdd1eef3, 0x3ca0d2b5, 0x7e5a4b06, 0xf881b13d,
                           0x10cb1c59, 0x26ed10d4, 0x4aa75bdc, 0x70283631,
                           0xb921edb6, 0xf9f4a69c, 0xb1e753f1, 0x1dedafbe,
                           0x7a4b3023, 0xfff3f939, 0x8f8d7d06, 0xc7ec249e }
    // Function Prototypes
    void performECBEncryption(AES_KeySize keySize, uint32_t *srcArray,
                         uint32_t *dstArray,   uint32_t *keyArray,
                         uint32_t dataLength, bool useDMA);
    uint32_t roundUpDataLength(uint32_t dataLength);
    void initializeDMACH1(void);
    void initializeDMACH2(void);
    void configureDMACH1(const void *src, const void *dst, uint32_t transferSize);
    void configureDMACH2(const void *src, const void *dst, uint32_t transferSize);
    void configurreDMAInterruptCH1(void);
    void configureDMAInteruptCH2(void);
    void initilizeAES(void);
    void startAES(void);
    interrupt void AESDMADataInISR(void)
        AES_disableDMARequest(AESA_BASE, AES_DMA_EN_DATA_IN);
        dataInDMADoneIntFlag = true;
        Interrupt_clearACKGroup(INTERRUPT_ACK_GROUP7);
    interrupt void AESDMADataOutISR(void)
        AES_disableDMARequest(AESA_BASE, AES_DMA_EN_DATA_OUT);
        dataOutDMADoneIntFlag = true;
        DMA_disableTrigger(DMA_CH1_BASE);
        DMA_clearTriggerFlag(DMA_CH1_BASE);
        DMA_clearErrorFlag(DMA_CH1_BASE);
        DMA_disableTrigger(DMA_CH2_BASE);
        DMA_clearTriggerFlag(DMA_CH2_BASE);
        DMA_clearErrorFlag(DMA_CH2_BASE);
        //Configure DMA Channel 1 as needed
        DMA_configAddresses(DMA_CH1_BASE,dst,src);
        // Burst configuration with 4 32 bit words/burst. Destination is not moving.
        DMA_configBurst(DMA_CH1_BASE,BURST_SIZE,BURST_SRCSTEP,0);
        // Transfer configuration with 4 bursts/transfer. Destination is not moving.
        DMA_configTransfer(DMA_CH1_BASE,transferSize,TRANSFER_SRCSTEP,0);
        // Wrap condition enabled if more than 256 bursts/transfer
        DMA_configWrap(DMA_CH1_BASE,SRCWRAPSIZE,WRAP_SRCSTEP,DESTWRAPSIZE,WRAP_DESTSTEP);
        DMA_configMode(DMA_CH1_BASE,DMA_TRIGGER_AESA_DATAIN,DMA_CFG_ONESHOT_DISABLE |
                       DMA_CFG_CONTINUOUS_DISABLE | DMA_CFG_SIZE_32BIT);
        DMA_enableTrigger(DMA_CH1_BASE);
        //Configure DMA Channel 2 as needed
        DMA_configAddresses(DMA_CH2_BASE,dst,src);
        // Burst configuration with 4 32 words/burst. Source is not moving.
        DMA_configBurst(DMA_CH2_BASE,BURST_SIZE,0,BURST_DESTSTEP);
        // Transfer configuration with 4 bursts/transfer. Source is not moving.
        DMA_configTransfer(DMA_CH2_BASE,transferSize,0,TRANSFER_DESTSTEP);
        DMA_configWrap(DMA_CH2_BASE,SRCWRAPSIZE,WRAP_SRCSTEP,DESTWRAPSIZE,WRAP_DESTSTEP);
        DMA_configMode(DMA_CH2_BASE,DMA_TRIGGER_AESA_DATAOUT,DMA_CFG_ONESHOT_DISABLE |
        DMA_enableTrigger(DMA_CH2_BASE);
    void configureDMAInterruptCH1(void)
        // Register the interrupt handler.
        Interrupt_register(INT_DMA_CH1, AESDMADataInISR);
        // Enable the DMA interrupt.
        Interrupt_enable(INT_DMA_CH1);
        Interrupt_enableMaster();
        DMA_enableInterrupt(DMA_CH1_BASE);
        // generate the interrupt at the end of the transfer.
        DMA_setInterruptMode(DMA_CH1_BASE,DMA_INT_AT_END);
    void configureDMAInterruptCH2(void)
        Interrupt_register(INT_DMA_CH2, AESDMADataOutISR);
        Interrupt_enable(INT_DMA_CH2);
        DMA_enableInterrupt(DMA_CH2_BASE);
        DMA_setInterruptMode(DMA_CH2_BASE,DMA_INT_AT_END);
        Interrupt_disableMaster();
        AES_disableGlobalInterrupt(AESA_SS_BASE);
        AES_performSoftReset(AESA_BASE);
    void startAES(void)
        //start the DMA Channel and wait for the trigger event.
        DMA_startChannel(DMA_CH1_BASE);
        DMA_startChannel(DMA_CH2_BASE);
        AES_enableDMARequest(AESA_BASE, AES_DMA_EN_DATA_IN | AES_DMA_EN_DATA_OUT);
    // Main
    void main(void)
        uint32_t errCountLocal, cnt;
        uint32_t *keyArray, dataLength;
        uint32_t *expCipherTextArray, *plainTextArray;
        uint32_t vectorCnt;
        // Initialize device clock and peripherals
        Device_init();
        // Initialize GPIO and configure the GPIO pin as a push-pull output
        Device_initGPIO();
        // Disable global interrupts.
        DINT;
        // Initialize PIE and clear PIE registers. Disables CPU interrupts.
        Interrupt_initModule();
        // Initialize the PIE vector table with pointers to the shell Interrupt
        // Service Routines (ISR).
        Interrupt_initVectorTable();
        // Initialize local variables.
        errCountLocal = 0;
        // Enable Global Interrupt (INTM) and realtime interrupt (DBGM)
        EINT;
        ERTM;
        vectorCnt = 0;
        // Loop through all the given vectors.
        //for(vectorCnt = 0;
        //    (vectorCnt < (sizeof(testVectorECBArray) /
        //     sizeof(testVectorECBArray[0]))); vectorCnt++)
            // Get the current vector's data members.
            keySize  = testVectorECBArray[vectorCnt].keySize;
            keyArray = testVectorECBArray[vectorCnt].keyArray;
            dataLength         = testVectorECBArray[vectorCnt].dataLength;
            plainTextArray     = testVectorECBArray[vectorCnt].plainTextArray;
            expCipherTextArray = testVectorECBArray[vectorCnt].cipherTextArray;
            // Clear the array containing the cipher text.
            for(cnt = 0; cnt < 16; cnt++)
                cipherTextArray[cnt] = 0;
            // Perform Encryption without DMA.
            performECBEncryption(keySize, plainTextArray, cipherTextArray, keyArray,
                                 dataLength, false);
            // Check the results
            for(cnt = 0; cnt < 16U; cnt++)
                if(cipherTextArray[cnt] != expCipherTextArray[cnt])
                    errCountLocal++;
            // Update the global error counter.
            if(errCountLocal > 0)
                errCountGlobal++;
            // Clear the local error counter.
            errCountLocal = 0;
            // Perform Encryption with DMA.
            performECBEncryption(keySize, plainTextArray,cipherTextArray, keyArray,
                                 dataLength, true);
                    errCountLocal++;
                errCountGlobal++;
            errCountLocal = 0;
        // Clean up AES Data registers
        // Update test status variable
        if(errCountGlobal == 0)
            testStatusGlobal = TEST_PASS;
        else
            testStatusGlobal = TEST_FAIL;
        // Infinite Loop to keep the core running
        while(1)
    // Perform an AES-ECB encryption operation.
        // Clear the interrupt flags.
        contextInIntFlag = false;
        dataInIntFlag = false;
        contextOutIntFlag = false;
        dataOutIntFlag = false;
        contextInDMADoneIntFlag = false;
        dataInDMADoneIntFlag = false;
        contextOutDMADoneIntFlag = false;
        dataOutDMADoneIntFlag = false;
        // Perform a soft reset.
        initilizeAES();
        // Configure the AES module.
        AES_ConfigParams aesConfig;
        memset(&aesConfig, 0, sizeof(AES_ConfigParams));
        aesConfig.direction = AES_DIRECTION_ENCRYPT;
        aesConfig.keySize = keySize;
        aesConfig.opMode = AES_OPMODE_ECB;
        aesConfig.ctrWidth = AES_CTR_WIDTH_32BIT;
        aesConfig.ccmLenWidth = AES_CCM_L_1;
        aesConfig.ccmAuthLenWidth = AES_CCM_M_0;
        AES_configureModule(AESA_BASE, &aesConfig);
        // Write the key.
        AES_setKey1(AESA_BASE, keyArray, keySize);
        // Depending on the argument, perform the decryption
        // with or without uDMA.
        if(useDMA)
            DMA_initController();
            initializeDMACH1();
            configureDMACH1((const void*)srcArray,
                            (const void*)(AESA_BASE + AES_O_DATA_IN_OUT_0),
                            (roundUpDataLength(dataLength) / 16U));
            configureDMAInterruptCH1();
            initializeDMACH2();
            configureDMACH2((const void*)(AESA_BASE + AES_O_DATA_IN_OUT_0),
                            (const void*)dstArray,
            configureDMAInterruptCH2();
            /*trigger dma*/
            startAES();
            // Wait for the data in DMA done interrupt.
            while(!dataInDMADoneIntFlag)
            // Wait for the data out DMA done interrupt.
            while(!dataOutDMADoneIntFlag)
        else
            // Enable all interrupts.
            AES_enableInterrupt(AESA_BASE, (AES_INT_CONTEXT_IN |
                                AES_INT_CONTEXT_OUT | AES_INT_DATA_IN    |
                                AES_INT_DATA_OUT));
            // Perform the encryption.
            AES_processData(AESA_BASE, srcArray, dstArray, dataLength);
    // roundUpDataLength - Round up length to nearest 16 byte boundary.  This is
    // needed because all four data registers must be written at once.  This is
    // handled in the AES driver, but if using uDMA, the length must rounded up.
        uint32_t remainder;
        remainder = dataLength % 16U;
        if(remainder == 0U)
            return(dataLength);
        else
            return(dataLength + (16U - remainder));
    // End of File
    感谢您的提问! 我在提供的代码中注意到两件事:
    1.尽管其余数据保持不变,但.dataLength 参数已更改为16U (而不是默认64U)。 本质上,请将.dataLength 增加到64U,或将数组更改为更短。
    左=原始示例,右=从原始帖子编辑的代码
    2.已完全绕过执行实际代码的循环。 这将只执行一次操作,因为括号中的代码通过删除 for 循环介绍性信息基本上已从代码中“删除”。 请在开头恢复循环“for”代码。
    请告诉我这些解决方案是否能解决问题。
    此致,
    文斯
    你好,Vince
    感谢你的回复。 我重新下载了 TI 示例代码,但没有更改代码。
    由于样本代码的最后一个循环对普通数据(64字节)执行 AES-256(密钥) ECB 模式,因此我直接比较了 MCU 的 AES-256 ECB 模式和网络工具的加密结果。
    以下 ECB 加密结果的比较不同。
    环境条件设置:ECB 加密模式,Key256位, 数据(64字节)
    纯数据= e2bec16b969f402e117e3de92a179373
              578a2dae9cac031eac6fb79e518eafe45.
              461cc83011e45ca319c1fbe5ef520a1a
              45249ff6179b4fdf7b412bad10376ce6.
    键= 10eb3d60be71ca15f0ae732b81777d85072c351fd708613ba310982df4df1409
    左=运行 TI 示例代码结果,右= Web 工具结果(aes.online-domain-tools.com)
    //!  - None
    // $Copyright:
    // are met:
    //   distribution.
    // Included Files
    #include <string.h>
    #include "device.h"
    // Defines
    // Global Variables
    typedef struct
    } testVectorECB;
      .keyArray = { 0x16157e2b, 0xa6d2ae28, 0x8815f7ab, 0x3c4fcf09 },
      .dataLength = 64U,
      .dataLength = 64U,
    void startAES(void)
    // Main
    void main(void)
        uint32_t vectorCnt;
        Device_init();
        Device_initGPIO();
        DINT;
        errCountLocal = 0;
        EINT;
        ERTM;
        for(vectorCnt = 0;
                                 dataLength, false);
                    errCountLocal++;
                errCountGlobal++;
            errCountLocal = 0;
                                 dataLength, true);
                    errCountLocal++;
                errCountGlobal++;
            errCountLocal = 0;
        else
        while(1)
        initilizeAES();
        // Write the key.
        if(useDMA)
            initializeDMACH1();
            initializeDMACH2();
            /*trigger dma*/
            startAES();
        else
                                AES_INT_DATA_OUT));
        uint32_t remainder;
        if(remainder == 0U)
            return(dataLength);
        else
    // End of File
    我的设置是否有问题?
    感谢你的帮助。
    我将数据输入了您所提及的在线工具中。 在将数据传送到在线工具时需要注意的一个变化是在传送到引擎之前交换数据的必要条件。 设计中的 AES 引擎希望数据采用与在线工具所期望的不同的小端格式。
    一旦数据被转换并传送到在线工具,密码文本就会开始与示例中提供的内容匹配。 (请注意,密码文本输出在解释时也需要进行无提示更改)。 我已将 数据 的快照放在下面,以供您参考。
    希望这能有所帮助。 请告诉我此回复是否可以解决您的问题。
    谢谢和问候
    普拉莫德
    你好,Vince
    感谢你的帮助。 按照您所说的解决方法调整字节数。
    非常感谢。
