[参考译文] TMS320F280021:具有 Code Composer Studio 的 C2000编译器
Guru**** 2913410 points
Other Parts Discussed in Thread: C2000WARE, TMS320F280021
https://e2e.ti.com/support/microcontrollers/c2000-microcontrollers-group/c2000/f/c2000-microcontrollers-forum/1123847/tms320f280021-c2000-compiler-with-code-composer-studio
器件型号:TMS320F280021
主题中讨论的其他器件:C2000WARE
请参阅 TI 存储器寄存器的存储器位置。
