[参考译文] tms320f28379d 中存在内存分配问题
Guru**** 2609955 points
Other Parts Discussed in Thread: TMS320F28379D
https://e2e.ti.com/support/microcontrollers/c2000-microcontrollers-group/c2000/f/c2000-microcontrollers-forum/1011914/memory-allocation-problem-in-tms320f28379d
主题中讨论的其他器件:TMS320F28379D
tms320f28379d 中的内存分配问题
您能不能建议 我在下面的内存分配页面中进行哪些更改
存储器
第0页:/* 程序内存*/
         /*内存(RAM/FLASH)块可移动到 Page1进行数据分配*/
         /* begin 用于"引导至闪存"引导加载程序模式  */
  开始             :origin = 0x080000,length = 0x000002
  RAMM0             :origin = 0x000122、length = 0x0002DE
  RAMD0             :origin = 0x00B000、length = 0x000800
  RAMLS0            :origin = 0x008000、length = 0x000800
  RAMLS1            :origin = 0x008800,length = 0x000800
  RAMLS2           :origin = 0x009000,length = 0x000800
  RAMLS3           :origin = 0x009800,length = 0x000800
  RAMGS14         :origin = 0x01A000,length = 0x001000
  RAMGS15         :origin = 0x01B000,length = 0x001000
  复位             :origin = 0x3FFFC0,length = 0x000002
  /*闪存扇区*/
  FLASHA          :origin = 0x080002,length = 0x001FFE   /*片上闪存*/
  FLASHB          :origin = 0x082000、length = 0x002000   //片上闪存*
  FLASHC          :origin = 0x084000,length = 0x002000   //片上闪存*/
  FLASHD          :origin = 0x086000、length = 0x002000   //片上闪存*/
  FLASHE          :origin = 0x088000、length = 0x008000   //片上闪存*/
  FLASHF          :origin = 0x090000,length = 0x008000   //片上闪存*
  FLASHG          :origin = 0x098000、length = 0x008000   //片上闪存*/
  FLASHH          :origin = 0x0A0000,length = 0x008000   //片上闪存*/
  FLASHI          :origin = 0x0A8000、length = 0x008000   //片上闪存*/
  FLASHJ          :origin = 0x0B0000,length = 0x008000   //片上闪存*/
  FLASHK          :origin = 0x0B8000、length = 0x002000   //片上闪存*/
  FLASHL          :origin = 0x0BA000、length = 0x002000   //片上闪存*/
  FLASHM          :origin = 0x0BC000、length = 0x002000   //片上闪存*/
  FLASHN          :origin = 0x0BE000、length = 0x002000   //片上闪存*/
第1页:/*数据存储器*/
        /*内存(RAM/FLASH)块可移动到 PAGE0进行程序分配*/
  BOOT_RSVD      :origin = 0x000002,length = 0x000120    // M0的一部分,引导 ROM 将此用于栈*/
  RAMM1          :origin = 0x000400、length = 0x000400    //片上 RAM 块 M1 *
  RAMD1          :origin = 0x00B800,length = 0x000800
  RAMLS4     :origin = 0x00A000,length = 0x000800
  RAMLS5     :origin = 0x00A800,length = 0x000800
  RAMGS0     :origin = 0x00C000、length = 0x001000
  RAMGS1     :origin = 0x00D000、length = 0x001000
  RAMGS2     :origin = 0x00E000、length = 0x001000
  RAMGS3     :origin = 0x00F000、length = 0x001000
  RAMGS4     :origin = 0x010000,length = 0x001000
  RAMGS5     :origin = 0x011000,length = 0x001000
  RAMGS6     :origin = 0x012000,length = 0x001000
  RAMGS7     :origin = 0x013000,length = 0x001000
  RAMGS8     :origin = 0x014000,length = 0x001000
  RAMGS9     :origin = 0x015000,length = 0x001000
  RAMGS10    :origin = 0x016000,length = 0x001000
  RAMGS11    :origin = 0x017000,length = 0x001000
  RAMGS12    :origin = 0x018000,length = 0x001000
  RAMGS13    :origin = 0x019000,length = 0x001000
  CPU2TOCPU1RAM  :origin = 0x03F800,length = 0x000400
  CPU1TOCPU2RAM  :origin = 0x03FC00,length = 0x000400
部分
  /*分配计划领域:*/
  .cinit             :> FLASHB     PAGE = 0,ALIGN (4)
  .pinit             :> FLASHB,    PAGE = 0,ALIGN (4)
  .text              :>> FLASHB | FLASHC | FLASHD | FLASHE     PAGE = 0,ALIG(4)
  codestart          :> begin      page = 0,align (4)
#ifdef __TI_Compiler_version__
  #if __TI_Compiler_version__>=15009000
   .TI.ramfunc:{}负载= FLASHD,
                        RUN = RAMLS0 | RAMLS1 | RAMLS2 | RAMLS3、
                        load_start (_RamfuncsLoadStart)、
                        load_size (_RamfuncsLoadSize)、
                        load_end (_RamfuncsLoadEnd)、
                        run_start (_RamfuncsRunStart)、
                        run_size (_RamfuncsRunSize)、
                        run_end (_RamfuncsRunEnd)、
                        PAGE = 0、ALIGN (4)
  其他
  ramfuncs           :load = FLASHD,
                        PAGE = 0、ALIGN (4)
  #endif
#endif
  /*分配未初始化的数据段:*/
  .stack             :>RAMM1       page = 1.
  .ebss              :>> RAMLS4 | RAMLS5 | RAMGS0 | RAMGS1      PAGE = 1.
  .esysmem           :> RAMLS5      PAGE = 1.
  /*初始化段进入闪存*/
  econst            :>> FLASHF | FLASHG | FLASHH     PAGE = 0,ALIGN (4)
  .switch            :> FLASHB     PAGE = 0,ALIGN (4)
  .reset             :> reset,    page = 0,type = DSECT //未使用,*/
  filter_RegsFile    :> RAMGS0,     PAGE = 1
/*  SHARERAMGS0      :>RAMGS0,      PAGE = 1
  SHARERAMGS1      :>RAMGS1,      PAGE = 1.
  SHARERAMGS2      :>RAMGS2,      PAGE = 1.
  SHARERAMGS3      :>RAMGS3,      PAGE = 1*/
  SHARERAMGS5      :> RAMGS5,      PAGE = 1
  SHARERAMGS6      :> RAMGS6,      PAGE = 1
  /*使用 IPC API 驱动程序时需要以下部分定义*/
   组:> CPU1TOCPU2RAM,PAGE = 1
       PUTBUFFER
       PUTWRITEIDX
       GETREADIDX
   组:> CPU2TOCPU1RAM,PAGE = 1
       GETBUFFER:   TYPE = DSECT
       GETWRITEIDX: TYPE = DSECT
       PUTREADIDX:  TYPE = DSECT
//文件结束。
我尝试创建 大小超过1024的数组、然后它显示说明#10099-D 程序将不适合   2837x_flash_lnk_cpu1.cmd   /EV_BMS_CPU1   行100   C/C++问题
我的数组是
UNION smuData{
   unsigned long ulData[600];
   unsigned int uiData[1200];
   union cmuData cmuData[15];
extern union smuData   smuData[4];
和工作代码阵列
UNION smuData{
   unsigned long ulData[480];
   unsigned int uiData[960];
   union cmuData cmuData[12];
    Baskar、
    尝试增大 ebss 或 esysmem 的大小(无论它是在抱怨什么-也许是 ebss)-请检查第100行。
    您可以为该段使用多个 RAM 块、如您引用的链接器中所示。
    示例:    .ebss         :>> RAMLS4 | RAMLS5 | RAMGS0 | RAMGS1    PAGE = 1.
    谢谢、此致、
    Vamsi
