[参考译文] CCS:重负载启动时的电机抖动(几乎关闭至旋转堵塞)
Guru**** 2894990 points
https://e2e.ti.com/support/microcontrollers/c2000-microcontrollers-group/c2000/f/c2000-microcontrollers-forum/790457/ccs-motor-jitter-at-start-up-instant-with-heavy-load-nearly-closed-to-rotation-blockage
工具/软件:Code Composer Studio
#define USER_ZEROSPEEDLIMIT (0.5/USER_IQ_FULL_SCALE_FREQ_Hz)
实际测试发现: USER_ZEROSPEEDLIMIT 值太大(大于2.0)更可能发生抖动、太小(小于0.5)、电机启动弱、瞬时过流、例程默认值0.5、尚未找到合适的值、该参数的哪个值更适合从负载开始?
