[参考译文] TMS320F280021-Q1:EPWM 输出未像预期的那样清晰 LEAD LLC 电路 H 桥 MOS 短路
Guru**** 2535530 points
https://e2e.ti.com/support/microcontrollers/c2000-microcontrollers-group/c2000/f/c2000-microcontrollers-forum/1296573/tms320f280021-q1-epwm-output-not-clear-as-expect-lead-llc-circuit-h-bridge-mos-short
器件型号:TMS320F280021-Q1
•背景
处理期间的输出功率;EPWM 3 4 驱动 LLC H 桥; PWM 频率 80k~150k (由软件设置); 谐振工作频率 90 kHz
波形由监控器捕获 C2000器件的 EPWM 输出引脚、在 MOS 驱动器和 C2000之间添加了隔离:
(红色箭头指向的左侧引脚连接到 C2000)
MOS 驱动器:
ePWM 配置代码:
void UserSetEPWM()
    EALLOW;
    CpuSysRegs.PCLKCR0.bit.TBCLKSYNC = 0;
    EDIS;
    EALLOW;
    GpioCtrlRegs.GPHAMSEL.bit.GPIO242 = 0;
    GpioCtrlRegs.GPHQSEL2.bit.GPIO242 = 3;
    InputXbarRegs.INPUT1SELECT = 242;
    GpioCtrlRegs.GPHLOCK.bit.GPIO242 = 1;
    GpioCtrlRegs.GPHCR.bit.GPIO242 = 1;
    InputXbarRegs.INPUTSELECTLOCK.bit.INPUT1SELECT = 1;
    EPwm1Regs.TZSEL.bit.OSHT1 = TZ_ENABLE;
    EPwm2Regs.TZSEL.bit.OSHT1 = TZ_ENABLE;
    EPwm3Regs.TZSEL.bit.OSHT1 = TZ_ENABLE;
    EPwm4Regs.TZSEL.bit.OSHT1 = TZ_ENABLE;
    EPwm1Regs.TZSEL.bit.OSHT5 = TZ_ENABLE;
    EPwm2Regs.TZSEL.bit.OSHT5 = TZ_ENABLE;
    EPwm3Regs.TZSEL.bit.OSHT5 = TZ_ENABLE;
    EPwm4Regs.TZSEL.bit.OSHT5 = TZ_ENABLE;
    EPwm1Regs.TZSEL.bit.OSHT6 = TZ_ENABLE;
    EPwm2Regs.TZSEL.bit.OSHT6 = TZ_ENABLE;
    EPwm3Regs.TZSEL.bit.OSHT6 = TZ_ENABLE;
    EPwm4Regs.TZSEL.bit.OSHT6 = TZ_ENABLE;
    EPwm1Regs.TZCTL.bit.TZA = TZ_FORCE_LO;
    EPwm1Regs.TZCTL.bit.TZB = TZ_FORCE_LO;
    EPwm2Regs.TZCTL.bit.TZA = TZ_FORCE_LO;
    EPwm2Regs.TZCTL.bit.TZB = TZ_FORCE_LO;
    EPwm3Regs.TZCTL.bit.TZA = TZ_FORCE_LO;
    EPwm3Regs.TZCTL.bit.TZB = TZ_FORCE_LO;
    EPwm4Regs.TZCTL.bit.TZA = TZ_FORCE_LO;
    EPwm4Regs.TZCTL.bit.TZB = TZ_FORCE_LO;
    EPwm1Regs.TZFRC.bit.OST = 1;
    EPwm2Regs.TZFRC.bit.OST = 1;
    EPwm3Regs.TZFRC.bit.OST = 1;
    EPwm4Regs.TZFRC.bit.OST = 1;
    EPwm1Regs.GLDCFG.all = 0x07FF;
    EPwm1Regs.GLDCTL.bit.GLDMODE = 6;
    EPwm1Regs.GLDCTL.bit.OSHTMODE = 1;
    EPwm1Regs.GLDCTL.bit.GLD = 1;
    EPwm1Regs.EPWMXLINK.bit.GLDCTL2LINK = 0;
    EPwm2Regs.GLDCFG.all = 0x07FF;
    EPwm2Regs.GLDCTL.bit.GLDMODE = 6;
    EPwm2Regs.GLDCTL.bit.OSHTMODE = 1;
    EPwm2Regs.GLDCTL.bit.GLD = 1;
    EPwm2Regs.EPWMXLINK.bit.GLDCTL2LINK = 0;
    EPwm3Regs.GLDCFG.all = 0x07FF;
    EPwm3Regs.GLDCTL.bit.GLDMODE = 6;
    EPwm3Regs.GLDCTL.bit.OSHTMODE = 1;
    EPwm3Regs.GLDCTL.bit.GLD = 1;
    EPwm3Regs.EPWMXLINK.bit.GLDCTL2LINK = 0;
    EPwm4Regs.GLDCFG.all = 0x07FF;
    EPwm4Regs.GLDCTL.bit.GLDMODE = 6;
    EPwm4Regs.GLDCTL.bit.OSHTMODE = 1;
    EPwm4Regs.GLDCTL.bit.GLD = 1;
    EPwm4Regs.EPWMXLINK.bit.GLDCTL2LINK = 0;
    EDIS;
    EPwm1Regs.TBPRD = EPWMPeriod;
    EPwm1Regs.TBCTL.bit.CLKDIV = TB_DIV1;             // TBCLK = SYSCLKOUT /(HSPCLKDIV ×CLKDIV)
    EPwm1Regs.TBCTL.bit.HSPCLKDIV = TB_DIV1;
    EPwm1Regs.TBCTL.bit.PHSDIR = TB_UP;
    EPwm1Regs.TBCTL.bit.PRDLD = TB_SHADOW;
    EPwm1Regs.TBCTL.bit.PHSEN = TB_ENABLE;            //使能同步
    EPwm1Regs.TBPHS.bit.TBPHS = 0;
    EPwm1Regs.TBCTL.bit.CTRMODE = TB_COUNT_UPDOWN;    // Count updown
    EPwm1Regs.EPWMSYNCINSEL.bit.SEL = SYNC_IN_SRC_DISABLE_ALL;
    EPwm1Regs.EPWMSYNCOUTEN.bit.ZEROEN = SYNC_OUT_SRC_ENABLE;
    EPwm2Regs.TBPRD = EPWMPeriod;
    EPwm2Regs.TBCTL.bit.CLKDIV = TB_DIV1;             // TBCLK = SYSCLKOUT /(HSPCLKDIV ×CLKDIV)
    EPwm2Regs.TBCTL.bit.HSPCLKDIV = TB_DIV1;
    EPwm2Regs.TBCTL.bit.PHSDIR = TB_UP;
    EPwm2Regs.TBCTL.bit.PRDLD = TB_SHADOW;
    EPwm2Regs.TBCTL.bit.PHSEN = TB_ENABLE;
    EPwm2Regs.TBPHS.bit.TBPHS = 2;
    EPwm2Regs.TBCTL.bit.CTRMODE = TB_COUNT_UPDOWN;    // Count updown
    EPwm2Regs.EPWMSYNCINSEL.bit.SEL = SYNC_IN_SRC_SYNCOUT_EPWM1;
    EPwm3Regs.TBPRD = EPWMPeriod;
    EPwm3Regs.TBCTL.bit.CLKDIV = TB_DIV1;             // TBCLK = SYSCLKOUT /(HSPCLKDIV ×CLKDIV)
    EPwm3Regs.TBCTL.bit.HSPCLKDIV = TB_DIV1;
    EPwm3Regs.TBCTL.bit.PHSDIR = TB_UP;
    EPwm3Regs.TBCTL.bit.PRDLD = TB_SHADOW;
    EPwm3Regs.TBCTL.bit.PHSEN = TB_ENABLE;
    EPwm3Regs.TBPHS.bit.TBPHS = 3;                      //补偿10ns数字隔离器延迟
    EPwm3Regs.TBCTL.bit.CTRMODE = TB_COUNT_UPDOWN;    // Count updown
    EPwm3Regs.EPWMSYNCINSEL.bit.SEL = SYNC_IN_SRC_SYNCOUT_EPWM1;
    EPwm4Regs.TBPRD = EPWMPeriod;
    EPwm4Regs.TBCTL.bit.CLKDIV = TB_DIV1;             // TBCLK = SYSCLKOUT /(HSPCLKDIV ×CLKDIV)
    EPwm4Regs.TBCTL.bit.HSPCLKDIV = TB_DIV1;
    EPwm4Regs.TBCTL.bit.PHSDIR = TB_UP;
    EPwm4Regs.TBCTL.bit.PRDLD = TB_SHADOW;
    EPwm4Regs.TBCTL.bit.PHSEN = TB_ENABLE;
    EPwm4Regs.TBPHS.bit.TBPHS = 3;                      //补偿10ns数字隔离器延迟
    EPwm4Regs.TBCTL.bit.CTRMODE = TB_COUNT_UPDOWN;    // Count updown
    EPwm4Regs.EPWMSYNCINSEL.bit.SEL = SYNC_IN_SRC_SYNCOUT_EPWM1;
    EPwm5Regs.TBPRD = 1000;
    EPwm5Regs.TBCTL.bit.CLKDIV = TB_DIV1;             // TBCLK = SYSCLKOUT /(HSPCLKDIV ×CLKDIV)
    EPwm5Regs.TBCTL.bit.HSPCLKDIV = TB_DIV1;
    EPwm5Regs.TBCTL.bit.PHSDIR = TB_UP;
    EPwm5Regs.TBCTL.bit.PRDLD = TB_SHADOW;
    EPwm5Regs.TBCTL.bit.PHSEN = TB_DISABLE;
//    EPwm5Regs.TBPHS.bit.TBPHS = 2;                      //补偿10ns数字隔离器延迟
    EPwm5Regs.TBCTL.bit.CTRMODE = TB_COUNT_UPDOWN;    // Count updown
    EPwm5Regs.EPWMSYNCINSEL.bit.SEL = SYNC_IN_SRC_DISABLE_ALL;
    //计数比较模块设定
    EPwm1Regs.TBCTR = 0;  //计数初值为0
    EPwm1Regs.CMPA.bit.CMPA = EPWMPeriod_DIV2 - LeastTime_LLC;
    EPwm1Regs.CMPB.bit.CMPB = EPWMPeriod_DIV2 + LeastTime_LLC;
    EPwm1Regs.CMPCTL.bit.LOADAMODE = CC_CTR_ZERO;
    EPwm1Regs.CMPCTL.bit.LOADBMODE = CC_CTR_ZERO;
    EPwm1Regs.CMPCTL.bit.SHDWAMODE = CC_SHADOW;
    EPwm1Regs.CMPCTL.bit.SHDWBMODE = CC_SHADOW;
    EPwm2Regs.TBCTR = 0;  //计数初值为0
    EPwm2Regs.CMPA.bit.CMPA = EPWMPeriod_DIV2 - LeastTime_LLC;
    EPwm2Regs.CMPB.bit.CMPB = EPWMPeriod_DIV2 + LeastTime_LLC;
    EPwm2Regs.CMPCTL.bit.LOADAMODE = CC_CTR_ZERO;
    EPwm2Regs.CMPCTL.bit.LOADBMODE = CC_CTR_ZERO;
    EPwm2Regs.CMPCTL.bit.SHDWAMODE = CC_SHADOW;
    EPwm2Regs.CMPCTL.bit.SHDWBMODE = CC_SHADOW;
    EPwm3Regs.TBCTR = 0;  //计数初值为0
    EPwm3Regs.CMPA.bit.CMPA = EPWMPeriod_DIV2 - LeastTime_LLC;
    EPwm3Regs.CMPB.bit.CMPB = EPWMPeriod_DIV2 + LeastTime_LLC;
    EPwm3Regs.CMPCTL.bit.LOADAMODE = CC_CTR_ZERO;
    EPwm3Regs.CMPCTL.bit.LOADBMODE = CC_CTR_ZERO;
    EPwm3Regs.CMPCTL.bit.SHDWAMODE = CC_SHADOW;
    EPwm3Regs.CMPCTL.bit.SHDWBMODE = CC_SHADOW;
    EPwm4Regs.TBCTR = 0;  //计数初值为0
    EPwm4Regs.CMPA.bit.CMPA = EPWMPeriod_DIV2 - LeastTime_LLC;
    EPwm4Regs.CMPB.bit.CMPB = EPWMPeriod_DIV2 + LeastTime_LLC;
    EPwm4Regs.CMPCTL.bit.LOADAMODE = CC_CTR_ZERO;
    EPwm4Regs.CMPCTL.bit.LOADBMODE = CC_CTR_ZERO;
    EPwm4Regs.CMPCTL.bit.SHDWAMODE = CC_SHADOW;
    EPwm4Regs.CMPCTL.bit.SHDWBMODE = CC_SHADOW;
    EPwm5Regs.TBCTR = 0;  //计数初值为0
//    EPwm5Regs.CMPA.bit.CMPA = 0;
//    EPwm5Regs.CMPCTL.bit.LOADAMODE = CC_CTR_ZERO;
//    EPwm5Regs.CMPCTL.bit.SHDWAMODE = CC_SHADOW;
    // AQ模块设定
    EPwm1Regs.AQCTLA.bit.CAU = AQ_SET;
    EPwm1Regs.AQCTLA.bit.CBU = AQ_CLEAR;
    EPwm1Regs.AQCTLB.bit.CBD = AQ_SET;
    EPwm1Regs.AQCTLB.bit.CAD = AQ_CLEAR;
    EPwm1Regs.AQCTLA.bit.ZRO = AQ_CLEAR;
    EPwm1Regs.AQCTLB.bit.ZRO = AQ_CLEAR;
    EPwm2Regs.AQCTLB.bit.CAU = AQ_SET;
    EPwm2Regs.AQCTLB.bit.CBU = AQ_CLEAR;
    EPwm2Regs.AQCTLA.bit.CBD = AQ_SET;
    EPwm2Regs.AQCTLA.bit.CAD = AQ_CLEAR;
    EPwm2Regs.AQCTLA.bit.ZRO = AQ_CLEAR;
    EPwm2Regs.AQCTLB.bit.ZRO = AQ_CLEAR;
    EPwm3Regs.AQCTLA.bit.CAU = AQ_SET;
    EPwm3Regs.AQCTLA.bit.CBU = AQ_CLEAR;
    EPwm3Regs.AQCTLB.bit.CBD = AQ_SET;
    EPwm3Regs.AQCTLB.bit.CAD = AQ_CLEAR;
    EPwm3Regs.AQCTLA.bit.ZRO = AQ_CLEAR;
    EPwm3Regs.AQCTLB.bit.ZRO = AQ_CLEAR;
    EPwm4Regs.AQCTLB.bit.CAU = AQ_SET;
    EPwm4Regs.AQCTLB.bit.CBU = AQ_CLEAR;
    EPwm4Regs.AQCTLA.bit.CBD = AQ_SET;
    EPwm4Regs.AQCTLA.bit.CAD = AQ_CLEAR;
    EPwm4Regs.AQCTLA.bit.ZRO = AQ_CLEAR;
    EPwm4Regs.AQCTLB.bit.ZRO = AQ_CLEAR;
    //DB死区模块设定
    EPwm1Regs.DBCTL.bit.OUT_MODE = DB_DISABLE;
    EPwm2Regs.DBCTL.bit.OUT_MODE = DB_DISABLE;
    EPwm3Regs.DBCTL.bit.OUT_MODE = DB_DISABLE;
    EPwm4Regs.DBCTL.bit.OUT_MODE = DB_DISABLE;
    EPwm1Regs.GLDCTL2.bit.GFRCLD = 1;
    EPwm5Regs.ETSEL.bit.SOCAEN = 1;                // 1 Enable the ADC Start of Conversion B (EPWMxSOCB) Pulse, Enable EPWMxSOCB pulse.
    EPwm5Regs.ETSEL.bit.SOCASEL = ET_CTR_ZERO;     //PRD 触发ADC_B
    EPwm5Regs.ETPS.bit.SOCAPRD = ET_1ST;
//    EPwm1Regs.ETSEL.bit.INTEN = 1;                // 1 Enable the ADC Start of Conversion B (EPWMxSOCB) Pulse, Enable EPWMxSOCB pulse.
//    EPwm1Regs.ETSEL.bit.INTSEL = ET_CTR_ZERO;     //PRD 触发ADC_B
//    EPwm1Regs.ETPS.bit.INTPRD = ET_1ST;
    EALLOW;
    CpuSysRegs.PCLKCR0.bit.TBCLKSYNC = 1;
    EDIS;
更新 ePWM 参数代码:
void loadpwm()
    F_SW = CC_PID.PIDU;         //PI计算值
    F_SW = __fmin(150,F_SW);
    F_SW = __fmax(80,F_SW);
    EPWMPeriod = 50000 / F_SW;
    EPWMPeriod_DIV2 = EPWMPeriod / 2;
    LLC_Hduty_EPWM = LLC_duty * EPWMPeriod_DIV2;
    if( LLC_Hduty_EPWM > EPWMPeriod_DIV2 - 25 )
        LLC_Hduty_EPWM = EPWMPeriod_DIV2 - 25;
    EPWMPeriod = EPWM_Cal_SW / F_SW;
    EPWMPeriod = EPWMPeriod_DIV2 * 2;
    F_Int = 50;
    T_Ctrl = 0.001f/F_Int;
    EPwm3Regs.TBPRD = EPWMPeriod;                           //Period of TB = 10kHz
    EPwm4Regs.TBPRD = EPWMPeriod;                           //Period of TB = 10kHz
    EPwm3Regs.CMPA.bit.CMPA = EPWMPeriod_DIV2 - LLC_Hduty_EPWM;
    EPwm3Regs.CMPB.bit.CMPB = EPWMPeriod_DIV2 + LLC_Hduty_EPWM;
    EPwm4Regs.CMPA.bit.CMPA = EPWMPeriod_DIV2 - LLC_Hduty_EPWM;
    EPwm4Regs.CMPB.bit.CMPB = EPWMPeriod_DIV2 + LLC_Hduty_EPWM;
    EPwm1Regs.GLDCTL2.bit.OSHTLD = 1;
• 期号
当 LLC 将频率从85K 向下调整到接近80K 时、上下半桥 MOS 管的驱动信号有可能会偶尔同时处于高电平。
MOS 管短路、管烧坏。
短路前的波形和频率:
下图显示了发生短路时的波形(PI 参数调整不当)、输出振荡发生:蓝色为 LLC 输入电压、黄色为 LLC 谐振电感器电流、绿色为 LLC 输出电流。
每个 C2000器件上 偶尔都会出现此问题。  出现的条件是、在充电和启动过程中、LLC 输出被加载几秒钟、LLC 输入电压下降、然后 LLC 执行频率调制。 该频率接近约80K 的下限频率、可能会发生直通短路。
客户通过使用具有不同操作的不同比较值来生成死区时间。 DB 模块被旁路。
ePWM 输出引脚上的干扰让我感到困惑:
谢谢、此致
