[参考译文] TMS320F28386D:IEC60703安全库
Guru**** 2872500 points
https://e2e.ti.com/support/microcontrollers/c2000-microcontrollers-group/c2000/f/c2000-microcontrollers-forum/1365647/tms320f28386d-iec60703-safety-library
器件型号:TMS320F28386D
Thread 中讨论的其他器件:C2000WARE
您好、C2000 Champ!
我 在 C2000-IEC60730-SW-PACKAGE 页面中查看可用性。 我在列表中找不到 TMS320F28386x 器件。
您能否说明一下、TMS320F28386x 是否可从 TI C2000 IEC60703封装版本的 IEC 60703安全库支持列表中获得?
Supported products & hardware
C2000 REAL-TIME MICROCONTROLLERS
TMS320C28341 — C2000Tm 32-bit MCU with 200 MIPS, FPU, 196 KB RAM, EMIF
TMS320C28342 — C2000Tm 32-bit MCU with 300 MIPS, FPU, 196 KB RAM, EMIF
TMS320C28343 — C2000Tm 32-bit MCU with 200 MIPS, FPU, 260 KB RAM, EMIF
TMS320C28343-Q1 — Automotive C2000Tm 32-bit MCU with 200 MIPS, FPU, 260 KB RAM, EMIF
TMS320C28344 — C2000Tm 32-bit MCU with 300 MIPS, FPU, 260 KB RAM, EMIF
TMS320C28345 — C2000Tm 32-bit MCU with 200 MIPS, FPU, 516 KB RAM, EMIF
TMS320C28346 — C2000Tm 32-bit MCU with 300 MIPS, FPU, 516 KB RAM, EMIF
TMS320C28346-Q1 — Automotive C2000Tm 32-bit MCU with 300 MIPS, FPU, 516 KB RAM, EMIF
TMS320F28020 — C2000Tm 32-bit MCU with 40 MHz, 32 KB flash, 8 PWM
TMS320F28021 — C2000Tm 32-bit MCU with 40 MHz, 64 KB flash
TMS320F28022 — C2000Tm 32-bit MCU with 50 MHz, 32 KB flash, 8 PWM
TMS320F28022-Q1 — Automotive C2000Tm 32-bit MCU with 50 MHz, 32 KB flash, 8 PWM
TMS320F28023 — C2000Tm 32-bit MCU with 50 MHz, 64 KB flash
TMS320F28023-Q1 — Automotive C2000Tm 32-bit MCU with 50 MHz, 64 KB flash
TMS320F28026 — C2000Tm 32-bit MCU with 60-MHz, 32-kb flash
TMS320F28026-Q1 — Automotive C2000Tm 32-bit MCU with 60 MHz, 32 KB flash
TMS320F28026F — C2000Tm 32-bit MCU with 60 MHz, 32 KB flash, InstaSPIN-FOC
TMS320F28027 — C2000Tm 32-bit MCU with 60 MHz, 64 KB flash
TMS320F28027-Q1 — Automotive C2000Tm 32-bit MCU with 60 MHz, 64 KB flash
TMS320F28027F — C2000Tm 32-bit MCU with 60 MHz, 64 KB flash, InstaSPIN-FOC
TMS320F28027F-Q1 — Automotive C2000Tm 32-bit MCU with 60 MHz, 64 KB flash, InstaSPIN-FOC
TMS320F28030 — C2000Tm 32-bit MCU with 60-MHz, 32-kb flash, 2 MSPS ADC
TMS320F28030-Q1 — Automotive C2000Tm 32-bit MCU with 60 MHz, 32 KB flash
TMS320F28031 — C2000Tm 32-bit MCU with 60 MHz, 64 KB flash, 2 MSPS ADC
TMS320F28031-Q1 — Automotive C2000Tm 32-bit MCU with 60 MHz, 64 KB flash, 2 MSPS ADC
TMS320F28032 — C2000Tm 32-bit MCU with 60 MHz, 64 KB flash, 4.6 MSPS ADC
TMS320F28032-Q1 — Automotive C2000Tm 32-bit MCU with 60 MHz, 64 KB flash, 4.6 MSPS ADC
TMS320F28033 — C2000Tm 32-bit MCU with 60 MHz, 64 KB flash, 4.6 MSPS ADC, CLA
TMS320F28033-Q1 — Automotive C2000Tm 32-bit MCU with 60 MHz, 64 KB flash, 4.6 MSPS ADC, CLA
TMS320F28034 — C2000Tm 32-bit MCU with 60 MHz, 128 KB flash
TMS320F28034-Q1 — Automotive C2000Tm 32-bit MCU with 60 MHz, 128 KB flash
TMS320F28035 — C2000Tm 32-bit MCU with 60 MHz, 128 KB flash, CLA
TMS320F28035-Q1 — Automotive C2000Tm 32-bit MCU with 60 MHz, 128 KB flash, CLA
TMS320F28050 — C2000Tm 32-bit MCU with 60-MHz, 32-kb flash, PGAs, 2 MSPS ADC
TMS320F28051 — C2000Tm 32-bit MCU with 60 MHz, 64 KB flash, PGAs, 2 MSPS ADC
TMS320F28052 — C2000Tm 32-bit MCU with 60 MHz, 64 KB flash, PGAs, 3.75 MSPS ADC
TMS320F28052-Q1 — Automotive C2000Tm 32-bit MCU with 60 MHz, 64 KB flash, PGAs, 3.75 MSPS ADC
TMS320F28052F — C2000Tm 32-bit MCU with 60 MHz, 64 KB flash, InstaSPIN-FOC, PGAs
TMS320F28052F-Q1 — Automotive C2000Tm 32-bit MCU with 60 MHz, 64 KB flash, InstaSPIN-FOC, PGAs
TMS320F28052M — C2000Tm 32-bit MCU with 60 MHz, 64 KB flash, InstaSPIN-MOTION, PGAs
TMS320F28052M-Q1 — Automotive C2000Tm 32-bit MCU with 60 MHz, 64 KB flash, InstaSPIN-MOTION, PGAs
TMS320F28053 — C2000Tm 32-bit MCU with 60 MHz, 64 KB flash, CLA, PGAs, 3.75 MSPS ADC
TMS320F28054 — C2000Tm 32-bit MCU with 60 MHz, 128 KB flash, PGAs
TMS320F28054-Q1 — Automotive C2000Tm 32-bit MCU with 60 MHz, 128 KB flash, PGAs
TMS320F28054F — C2000Tm 32-bit MCU with 60 MHz, 128 KB flash, InstaSPIN-FOC, PGAs
TMS320F28054F-Q1 — Automotive C2000Tm 32-bit MCU with 60 MHz, 128 KB flash, InstaSPIN-FOC, PGAs
TMS320F28054M — C2000Tm 32-bit MCU with 60 MHz, 128 KB flash, InstaSPIN-MOTION, PGAs
TMS320F28054M-Q1 — Automotive C2000Tm 32-bit MCU with 60 MHz, 128 KB flash, InstaSPIN-MOTION, PGAs
TMS320F28055 — C2000Tm 32-bit MCU with 60 MHz, 128 KB flash, CLA, PGAs
TMS320F28062 — C2000Tm 32-bit MCU with 90 MHz, FPU, 128 KB flash, 52 KB RAM
TMS320F28062-Q1 — Automotive C2000Tm 32-bit MCU with 90 MHz, FPU, 128 KB flash, 52 KB RAM
TMS320F28062F — C2000Tm 32-bit MCU with 90 MHz, FPU, 128 KB flash, InstaSPIN-FOC
TMS320F28062F-Q1 — Automotive C2000Tm 32-bit MCU with 90 MHz, FPU, 128 KB flash, InstaSPIN-FOC
TMS320F28063 — C2000Tm 32-bit MCU with 90 MHz, FPU, 128 KB flash, 68 KB RAM
TMS320F28064 — C2000Tm 32-bit MCU with 90 MHz, FPU, VCU, 128 KB flash, 100 KB RAM
TMS320F28065 — C2000Tm 32-bit MCU with 90 MHz, FPU, VCU, CLA, 128 KB flash, 100 KB RAM
TMS320F28066 — C2000Tm 32-bit MCU with 90 MHz, FPU, 256 KB flash, 68 KB RAM
TMS320F28066-Q1 — Automotive C2000Tm 32-bit MCU with 90 MHz, FPU, 256 KB flash, 68 KB RAM
TMS320F28067 — C2000Tm 32-bit MCU with 90 MHz, FPU, 256 KB flash, 100 KB RAM
TMS320F28067-Q1 — Automotive C2000Tm 32-bit MCU with 90 MHz, FPU, 256 KB flash, 100 KB RAM
TMS320F28068F — C2000Tm 32-bit MCU with 90 MHz, FPU, VCU, 256 KB flash, InstaSPIN-FOC
TMS320F28068M — C2000Tm 32-bit MCU with 90 MHz, FPU, VCU, 256 KB flash, InstaSPIN-MOTION
TMS320F28069 — C2000Tm 32-bit MCU with 90 MHz, FPU, VCU, 256 KB flash, CLA
TMS320F28069-Q1 — Automotive C2000Tm 32-bit MCU with 90 MHz, FPU, VCU, 256 KB flash, CLA
TMS320F28069F — C2000Tm 32-bit MCU with 90 MHz, FPU, VCU, CLA, 256 KB flash, InstaSPIN-FOC
TMS320F28069F-Q1 — Automotive C2000Tm 32-bit MCU with 90 MHz, FPU, VCU, CLA, 256 KB flash, InstaSPIN-FOC
TMS320F28069M — C2000Tm 32-bit MCU with 90 MHz, FPU, VCU, CLA, 256 KB flash, InstaSPIN-MOTION
TMS320F28069M-Q1 — Automotive C2000Tm 32-bit MCU with 90 MHz, FPU, VCU, CLA, 256 KB flash, InstaSPIN-MOTION
TMS320F28232 — C2000Tm 32-bit MCU with 100 MIPS, 128 KB flash, EMIF, 12b ADC
TMS320F28232-Q1 — Automotive C2000Tm 32-bit MCU with 100 MIPS, 128 KB flash, EMIF, 12b ADC
TMS320F28234 — C2000Tm 32-bit MCU with 150 MIPS, 256 KB flash, EMIF, 12b ADC
TMS320F28234-Q1 — Automotive C2000Tm 32-bit MCU with 150 MIPS, 256 KB flash, EMIF, 12b ADC
TMS320F28235 — C2000Tm 32-bit MCU with 150 MIPS, 512 KB flash, EMIF, 12b ADC
TMS320F28235-Q1 — Automotive C2000Tm 32-bit MCU with 150 MIPS, 512 KB flash, EMIF, 12b ADC
TMS320F28332 — C2000Tm 32-bit MCU with 100 MIPS, FPU, 128 KB flash, EMIF, 12b ADC
TMS320F28333 — C2000Tm 32-bit MCU with 100 MIPS, FPU, 512 KB flash, EMIF, 12b ADC
TMS320F28334 — C2000Tm 32-bit MCU with 150 MIPS, FPU, 256 KB flash, EMIF, 12b ADC
TMS320F28335 — C2000Tm 32-bit MCU with 150 MIPS, FPU, 512 KB flash, EMIF, 12b ADC
TMS320F28335-Q1 — Automotive C2000Tm 32-bit MCU with 150 MIPS, FPU, 512 KB flash, EMIF, 12b ADC
插孔
    等效 F2838x 诊断库是 C2000Ware 的一部分。 您可在下找到 /libraries/diagnostic/f2838x.
    惠特尼
    谢谢。 已解决。 他在 C2000Ware 库中找到该漏洞。
