[参考译文] TPS4HC120-Q1:性能和功能相当的替代器件
Guru**** 2482805 points
Other Parts Discussed in Thread: TPS4HC120-Q1
https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/1501786/tps4hc120-q1-a-replacement-part-with-comparable-performance-and-functionality
器件型号:TPS4HC120-Q1
请建议为 TPS4HC120-Q1 IC 更换器件、该器件具有相似的性能和功能、最好具有相同的封装和引脚功能。
