[参考译文] TPS51200:功能安全时基故障率、FMD 和引脚 FMA
Guru**** 2473260 points
Other Parts Discussed in Thread: TPS51200
https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/1511903/tps51200-functional-safety-fit-rate-fmd-and-pin-fma
器件型号:TPS51200
申请 TPS51200DRCR 功能安全时基故障率、FMD 和引脚 FMA 报告。
