[参考译文] TPSM828512:功能安全时基故障率、FMD 和引脚 FMA
Guru**** 2511985 points
Other Parts Discussed in Thread: TPS628512
https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/1511919/tpsm828512-functional-safety-fit-rate-fmd-and-pin-fma
器件型号:TPSM828512
主题:TPS628512中讨论的其他器件
申请 TPSM828512RDYR 功能安全时基故障率、FMD 和引脚 FMA 报告。
