[参考译文] TPS2597:您可以共享该器件的 SOA 吗?
Guru**** 2763545 points
Other Parts Discussed in Thread: TPS25947
https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/1521000/tps2597-can-you-share-the-soa-of-this-device
器件型号:TPS2597
您好团队
能否共享 TPS25947内部 MO 的 SOA?
