[参考译文] TPS22975:散热焊盘
Guru**** 2529950 points
Other Parts Discussed in Thread: TPS22975
https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/1520824/tps22975-thermal-pad
器件型号:TPS22975
您好团队:
 TPS22975的哪个部分是散热焊盘内部连接的?
Shotaro
